gregburb Samba Member
Posted: Fri Sep 13, 2019 6:55 am Post subject: No crank |
When trying to start my vanagon for the past year or so there was sometimes a delay of 4-5 seconds from turning key before any cranking would occur. There would be a delay, then crank and start with no problem. This morning when I tried to start, it would not crank at all. I could hear the fuel pump doing its thing, but no crank. What should I check first?
Thanks, Greg |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2941 Location: North Carolina
Posted: Fri Sep 13, 2019 7:22 am Post subject: Re: No crank |
Ignition switch first, I'd then start checking the wiring going to, coming off the starter. Does the starter make an audible click, but no crank or is it dead silent? _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Posted: Fri Sep 13, 2019 7:28 am Post subject: Re: No crank |
I don't hear anything except the fuel pump.
Greg |
Posted: Fri Sep 13, 2019 8:01 am Post subject: Re: No crank |
I'd check your battery voltage too- it may be producing enough power to cycle the relay for the pump but not enough to turn over the starter.
I should add, I'm just a driveway hack mechanic, not a pro. As always, refer to the Digijet/fant pro training manual for a actual pro guidance. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
Posted: Fri Sep 13, 2019 8:23 am Post subject: Re: No crank |
Thick old grease in the solenoid can cause this. It warms up as you hold the key and once the grease is warmed a bit the plunger in the solenoid will break free and move. |
Posted: Fri Sep 13, 2019 11:36 am Post subject: Re: No crank |
Is it possible to clean the grease? |
Posted: Fri Sep 13, 2019 2:14 pm Post subject: Re: No crank |
gregburb wrote: |
Yes, with certain style of solenoids it is very easy as they come apart as you remove them, while others you can just use a spray to clean them and then lube them with something like a Superlube working the plunger repeatedly to get the grease where you want it. |
Luckyphil Samba Member
Joined: March 07, 2011 Posts: 156 Location: Australia
Posted: Sat Sep 14, 2019 2:29 pm Post subject: Re: No crank |
I had this exact problem that would come & go over a couple of years. I installed this relay kit after a mate had the same problem diagnosed by his auto electrician and no further issues and as a bonus it protects your ignitian switch which is a known weak point in these vans. I have no commercial interest in this product.
https://www.thesamba.com/vw/classifieds/detail.php?id=1066289 |
