Rmvr53 Samba Member
Posted: Sat Oct 05, 2019 10:16 pm Post subject: 40 Ford hood - which one? |
I picked up a 40 Ford hood a while back and finally have a project to use it on. My question is this - how do I tell if its a hood for an early or late body? Or is there a difference? (meaning the hood is adaptable to either striker). Since the car is a Baja I'm converting back to full body, I can put on which ever front clip I need, Just need to know which to get if it matters
thanks
Bill |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16802 Location: State College, PA
Posted: Sun Oct 06, 2019 4:34 pm Post subject: Re: 40 Ford hood - which one? |
The big thing is if its for a Super or not. Pretty sure it doesnt matter on an early or late since they usually hang pretty low over the apron. BUT there were several people that made them and its hard to tell. If it fits the car at the cowl, then you are probably OK with either front clip, but I can't say definitively. _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
Rmvr53 Samba Member
Posted: Sun Oct 06, 2019 5:31 pm Post subject: Re: 40 Ford hood - which one? |
I do know it wasn't for a Super, and it fits the cowl on my 70. |
Posted: Mon Oct 07, 2019 5:03 am Post subject: Re: 40 Ford hood - which one? |
What sucks is that I have never seen identification marks on these hoods. On my 40 Ford Vwoodie, it was based on a 69, so I uses a late apron, but since I used early fenders, I had to modify them to accept the late bumper mount locations. I have another car with a different 40 Ford hood and I think it had teh early apron and mounts. Not sure without looking. This is an area of concern for you depending on the hood you have....will it clear early apron if you go that route? I think that is all you need to worry about. One other thing - I ran across a hood that was simply mounted OVER the stock hood. Have one seen that once, but you also don't run across a lot of these to compare. _________________ D-Dubya Manx clone 1914. Ex wifes car.
