grewp Samba Member
Posted: Mon Aug 19, 2019 4:56 pm Post subject: 69 doesn't like to accelerate |
My 69 beetle starts fine, idles fine but when I accelerate, even a tiny bit, it coughs and gasps. It has been running well until now. I filled the tank the day before.
Any ideas are greatly appreciated.
Pat _________________ 69 Beetle |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26632 Location: Douglas, WY
Posted: Mon Aug 19, 2019 5:09 pm Post subject: Re: 69 doesn't like to accelerate |
Sounds like the carburetor's "accelerator pump" is not functioning properly. This is a nozzle that should start to shoot extra fuel down the carburetor whenever you open the throttle.
Also sounds like a carburetor/distributor mismatch.
Add the two together and you get  _________________ Andy T.
"What is Glutamodo, Horror of Toyko, besides total, fiendish, quality-a-you brain!" |
grewp Samba Member
Posted: Mon Aug 19, 2019 5:16 pm Post subject: Re: 69 doesn't like to accelerate |
Thank you. I will look into the pump. Any advice on how to test this?
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16813 Location: State College, PA
Posted: Mon Aug 19, 2019 5:46 pm Post subject: Re: 69 doesn't like to accelerate |
Yeah - take the air cleaner off. You will see a nozzle or two toward the top of the carb. When you work the throttle, you should see a stream of gas coming out shooting down the throat of the carb. Should be a nice spray.
But you said it was fine until now, correct? _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
sb001 Samba Member
Joined: May 19, 2011 Posts: 10472 Location: NW Arkansas
Posted: Mon Aug 19, 2019 5:53 pm Post subject: Re: 69 doesn't like to accelerate |
| grewp wrote: |
| I filled the tank the day before. |
This is absolutely the only thing you did before it started acclerating poorly? You did not touch or replace anything at all? _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Mon Aug 19, 2019 5:55 pm Post subject: Re: 69 doesn't like to accelerate |
| sb001 wrote: |
| grewp wrote: |
This is absolutely the only thing you did before it started acclerating poorly? You did not touch or replace anything at all? |
Yeah, I think I see where this line of inquiry is going as I've twice over the years been affected by contaminated fuel - both times I strongly suspect diesel got mixed in with gasoline _________________ Andy T.
grewp Samba Member
Posted: Sat Oct 05, 2019 10:02 am Post subject: Re: 69 doesn't like to accelerate |
| andk5591 wrote: |
But you said it was fine until now, correct? |
Sorry for being so late in responding ... yes, I have done no repairs at all. Been driving it all summer. Just jumped in the one day and as I was driving it began acting up. Idled it in first gear all the way home. _________________ 69 Beetle |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11449 Location: Huntington Beach, CA
Posted: Sat Oct 05, 2019 10:10 am Post subject: Re: 69 doesn't like to accelerate |
| glutamodo wrote: |
| Sounds like the carburetor's "accelerator pump" is not functioning properly. This is a nozzle that should start to shoot extra fuel down the carburetor whenever you open the throttle. |
Super easy to check!
Plugged up acceleration circuits are very common. Probably the most common complaint with carburetored cars. _________________ Jimbo
| TDCTDI wrote: |
| Basically, a whole bunch of fuckery to achieve a look. |
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
