Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10504 Location: Sunshine Coast B.C.
Posted: Wed Oct 30, 2019 9:22 am Post subject: Climate control display cover repair |
Hi folks.
Edit
Meant to say, the posts already have a hole in them. The tap fit nice, no drilling needed.
Due to multiple times accessing the cable adjustment for the heat control
valve, and some lack of attention, I eventually broke both the posts
off the climate control cove on my ' 88 westy.
On my ' 81 that never happened; cover always came off easily.
On the '88 cover, I epoxied a post back on. This held until next time cover
came off.
As a Hail Mary type repair, I threaded each plastic post with a 32 tap then used
a screw at each to hold them in place. This is working, cover stays on. If I ever
have to remove it again, who knows how they'll hold up but as I say, a Hail
Mary repair.
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Thu Oct 31, 2019 6:20 am Post subject: Re: Climate control display cover repair |
| That's good to know. The face plates are of cost-cutting, flimsy design with roughly a ten year life span to match. The climate controls are as about as archaic as anything you can find on autos that first came with heater controls. I always thought the next time I have that problem I'd use (decorative?) screws in the front going thru to the posts. Hint: use lubricant on the posts. |
Nuthin2It Samba Member
Joined: December 31, 2011 Posts: 315 Location: Marietta, GA
Posted: Thu Oct 31, 2019 7:16 am Post subject: Re: Climate control display cover repair |
I found two small headed brown screws in my miscellaneous screw and bolt box. I drilled holes in the climate control cover where the posts broke off and, using plastic wall anchors, attached the cover to the dashboard with these screws.
_________________ 1985 Westfalia 15 degree EA288 Boxeer |
jlrftype7 Samba Member
Posted: Thu Oct 31, 2019 8:24 pm Post subject: Re: Climate control display cover repair |
| Nuthin2It wrote: |
Nice, I like it... Looks Factory even _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10357 Location: N. Idaho
Posted: Fri Nov 01, 2019 8:38 am Post subject: Re: Climate control display cover repair |
Great solution with the little screws. My rear blower fan surround has been adrift for years and this is a good solution. Thanks. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
