volkswagen60 Samba Member
Posted: Fri Dec 06, 2019 9:03 pm Post subject: Re: Tinkering With My 66...Sea Blue |
A little wet sanding today. Sea Blue, we missed you.
L360
Posted: Mon Dec 09, 2019 10:47 am Post subject: Re: Tinkering With My 66... |
More Sea Blue.
I tried a few different sandpaper grits and tried dry and wet sanding. Dry sanding by hand with 240 grit worked best.
-Motor is out to be rebuilt.
-Will replace fuel tank, brakes, and ts switch next.
Posted: Thu Dec 12, 2019 11:32 am Post subject: Re: Tinkering With My 66... |
So I bought rear seat clamps from WW but they came with little nubs. My seats don’t have holes so my neighbor grinded the nubs down for me.
Also starting to disassemble rear brakes...
Posted: Tue Dec 17, 2019 9:27 am Post subject: Re: Tinkering With My 66... |
Gas tank is out and big rust flakes pouring out! Good thing I’m replacing it before getting motor done. More things I found done incorrectly:
- There is no gasket between tank and body.
- Fuel tank strap is missing the bolt and being held with strapping material.
Up next:
Replace engine to body seals, tranny cradle mounts, transmission oil seal, tank.
Also going to go through all the brakes soon to see what’s up... oh and need to paint rims and should get new tires ... oh and more body sanding...🤷🏽♂️💵🤷🏽♂️
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24770 Location: Olympia Wash Rinse & Repeat
Posted: Tue Dec 17, 2019 9:48 am Post subject: Re: Tinkering With My 66... |
Rear brake lines need to be attached to the axle tube brackets, and you are missing the brackets that go onto the RGBs. _________________ In Stereo, Where Available! |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Tue Dec 17, 2019 9:58 am Post subject: Re: Tinkering With My 66... |
Eric&Barb wrote: |
Rear brake lines need to be attached to the axle tube brackets, and you are missing the brackets that go onto the RGBs. |
For the sake of reference, these are what E&B's referring to at the RGBs: http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211598600
In the image on WBW site, you can also see the setup for the axle tubes. Yours are welded on (like mine), but you get the picture...literally. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
Posted: Tue Dec 17, 2019 10:23 am Post subject: Re: Tinkering With My 66... |
Thanks for the reminder. My buddy mentioned it when he took the motor out. I'll add it to the list. Thanks! |
Posted: Tue Dec 17, 2019 10:41 am Post subject: Re: Tinkering With My 66... |
Would not bother with the lock plates. VW dropped them later due to needing to retorque those bolts later after so many miles. _________________ In Stereo, Where Available! |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
nineteensixtyfiveVG Samba Member
Joined: August 03, 2009 Posts: 456 Location: San Diego
Posted: Tue Dec 17, 2019 11:05 am Post subject: Re: Tinkering With My 66... |
Eric&Barb wrote: |
Would not bother with the lock plates. VW dropped them later due to needing to retorque those bolts later after so many miles. |
if you dont use the lock plates what do you use? I just have the bolts and lock washers on mine but i got under there not to long ago and noticed one had loosened up a bit which was disheartening. |
Posted: Tue Dec 17, 2019 11:06 am Post subject: Re: Tinkering With My 66... |
volkswagen60 wrote: |
More Sea Blue.
Have you tried easy off? man I feel like that paint would just fall right off with easy off and you would end up with all the fine scratches in the original paint. |
Posted: Tue Dec 17, 2019 11:20 am Post subject: Re: Tinkering With My 66... |
nineteensixtyfiveVG wrote: |
Eric&Barb wrote: |
Use a lock washers as shown in the 1963-67 workshop manual. Personally tend to retorque RGB bolts about 10 miles, 100, miles, and 300 miles after installing a transaxle. Even then not a bad idea to check those again 30,000 or 50,000 miles later.
Also helps to drill and tap the RGB bolt holes deeper to be able to use 40% longer bolts. Using old grease or anti-seize on the bolts helps to keep the rust out of the holes. Have packed old used grease between the RGBs and swing plates to keep rust out even more. _________________ In Stereo, Where Available! |
Posted: Tue Dec 17, 2019 1:38 pm Post subject: Re: Tinkering With My 66... |
Eric&Barb wrote: |
Eric&Barb wrote: |
Also helps to drill and tap the RGB bolt holes deeper to be able to use 40% longer bolts. Using old grease or anti-seize on the bolts helps to keep the rust out of the holes. Have packed old used grease between the RGBs and swing plates to keep rust out even more. |
ok, thank you, that is how I have it setup. Ill just remember to check them again in a few thousand miles. One of the holes is stripped unfortunately so I will have to look into rethreading that at some point. Im sure that must be somewhat common. |
Posted: Tue Dec 17, 2019 2:11 pm Post subject: Re: Tinkering With My 66... |
https://www.thesamba.com/vw/forum/viewtopic.php?t=195934&highlight=time-sert+rgb _________________ In Stereo, Where Available! |
Posted: Thu Dec 19, 2019 7:32 pm Post subject: Re: Tinkering With My 66... |
More Sea Blue.
I tried Easy Off and I tried an aircraft paint stripper but neither interacts with the grey paint like other paints. There’s no bubbling or softening. The grey gets wet, and then just dries. It’s the weirdest thing. |
Posted: Fri Dec 20, 2019 7:23 am Post subject: Re: Tinkering With My 66... |
More Sea Blue.
The last time I did this there was a big difference between spray can Easy-Off and spray bottle Easy-Off. If it's still available in a can, make sure you use that.
Good Luck! _________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263 |
Posted: Fri Dec 20, 2019 12:32 pm Post subject: Re: Tinkering With My 66... |
Bruce Amacker wrote: |
More Sea Blue.
Good Luck! |
Ahhhh ok. I'll pick up a 'can' today, and maybe a different paint stripper and try it one more time before sanding the entire bus.... THANKS! |
Posted: Fri Dec 20, 2019 12:43 pm Post subject: Re: Tinkering With My 66... |
Bus is on jack stands and this is the last wheel I need to take off. It won’t come off no matter what I do!! I adjusted the pads in, hit it with hammer, and stared at it. It spins freely but does not nudge at all.
Next step, drum puller extractor from my buddy.
Posted: Sun Dec 22, 2019 7:03 pm Post subject: Re: Tinkering With My 66... |
Started a YouTube channel for the 66. I'll continue to update this thread and upload YouTube videos too. I'm no mechanic, but maybe something I post will help someone.
https://youtu.be/x1XHd9EIRTM |
Posted: Sun Dec 22, 2019 7:26 pm Post subject: Re: Tinkering With My 66... |
When you post a youtube video link, first left click on the [youtube] button at the upper right of the message box you type your next post in. Then paste the video web address, and again left click on the [/youtube] button. _________________ In Stereo, Where Available! |
