tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Mon Nov 18, 2019 11:56 am Post subject: Terminals for 14-pin dash connector |
Does anybody have a source for these?
Working with a friend, we've added a tach & coolant temp gauge to the cluster of his engine-swapped '81 Adventurewagen. Used a cut-down JAMMA edge to mate with the factory plug for the warning lights and fuel gauge,and would like to use some of the otherwise unused pins for the tach and coolant temp gauge signals for neatness and ease of use if possible.
Thanks |
t3 kopf Samba Member
Joined: October 22, 2012 Posts: 1115 Location: over by 'der
Posted: Tue Nov 19, 2019 1:42 am Post subject: Re: Terminals for 14-pin dash connector |
No, those particular spring pins are no longer available anywhere. What you can do however is find a junkyard van and cut the connector from 6 inches from the back of the seat belt dash warning light connector and use those pins because they are the same. Or if you don't care about your own seatbelt warning light, you can take them from there and splice them into your application. Don't forget to cap off the cut wires. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
space Samba Member
Posted: Tue Nov 19, 2019 8:28 am Post subject: Re: Terminals for 14-pin dash connector |
What enegine are u installing?
If subie what terminals are u using for tach and temp on subie harness?
I may have an extra 14 pin (with short leads)
T |
beach_creature Samba Member
Posted: Tue Nov 19, 2019 9:54 am Post subject: Re: Terminals for 14-pin dash connector |
Engine that went in is an ABA block with an early GTI big-valve head, installed with diesel Vanagon carrier bars, oil pan and bellhousing.
Thanks for the Brickwerks link, that gives me a part number and some clues -- I didn't even know where to start looking for this, TBH.
More digging. |
Posted: Wed Nov 20, 2019 3:40 am Post subject: Re: Terminals for 14-pin dash connector |
good luck. I went down this rabbit hole a long time ago. Brickwerks must have found some since then. I was in contact with amp with the discontinued part number and everything. Thats when i realized i could get them out of junker vans for free. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1647 Location: Budapest Hungary, Europe
Posted: Wed Nov 20, 2019 7:17 am Post subject: Re: Terminals for 14-pin dash connector |
I have found them in an AMP terminal catalog a few years ago. I will search through my files. _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
GreggK Samba Member
Joined: May 17, 2008 Posts: 898 Location: Colorado/Philidelphia
Posted: Wed Nov 20, 2019 7:50 am Post subject: Re: Terminals for 14-pin dash connector |
I'm sure I have a few 14 pin connectors with short leads. PM me if you don't have any luck finding one. |
Posted: Wed Nov 20, 2019 1:11 pm Post subject: Re: Terminals for 14-pin dash connector |
ZsZ wrote: |
I have found them in an AMP terminal catalog a few years ago. I will search through my files. |
Yeah, I found something that looks similar from AMP/TE Connectivity on Digikey in the the "Card Edge Connectors - Contacts" category this morning and threw a half dozen (more than I'll need) on an order I was placing anyway. We'll see how they compare when they show up.
5-583853-3 in case anyone's curious. If they're wrong no big deal. |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Wed Nov 20, 2019 1:26 pm Post subject: Re: Terminals for 14-pin dash connector |
This original drawing and photo may be helpful.
_________________ Schau in das Buch |
Posted: Thu Nov 21, 2019 3:23 am Post subject: Re: Terminals for 14-pin dash connector |
That's a good find. I was going in circles with TE connectivity over those. But i was referencing the -2 part which was obsolete and they were telling me they weren't replaced. Glad to see they're back in action. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
Posted: Thu Nov 21, 2019 7:12 pm Post subject: Re: Terminals for 14-pin dash connector |
Hopefully the -3 is the right thing, or at least workable. We'll see when they get here... |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Thu Nov 21, 2019 10:13 pm Post subject: Re: Terminals for 14-pin dash connector |
I’ve got a dealer case with bags of nos connectors some of which I’ve never seen. I’ll post pictures with oem part numbers this weekend. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
rmcd Samba Member
ZsZ Samba Member
Posted: Wed Nov 27, 2019 11:42 pm Post subject: Re: Terminals for 14-pin dash connector |
tristessa wrote: |
ZsZ wrote: |
I had a busy week so I forgot to answer.
Cannot find my notes with the AMP nr but I remember that I had the drawing sheet in PDF downloaded. Found the connectors and the sachet with a nr but it was the local dealers own partnr. Checked their webpage but its not listed now.
I hope that your nr is the one.
EDIT:
Checked your partnr online and found that page: https://www.digikey.com/catalog/en/partgroup/twin-leaf-series/56112?mpart=5-583853-3&vendor=17
Either 5-583853-3 or 5-583649-3 looks the one that VW used. I'm not sure whats the difference. Probably one is a ribbon style for automated crimping machines while the other is for the independent connector. _________________ Zoltan
MootPoint Samba Member
Joined: September 16, 2006 Posts: 862 Location: ABQ, NM
Posted: Fri Oct 20, 2023 10:05 am Post subject: Re: Terminals for 14-pin dash connector |
Anybody know if these are still available and did the fit the 14-pin terminal connector? "Something similar" might not be "similar' enough.
Or any other source other than junker Vanagon?
Thanks
tristessa wrote: |
ZsZ wrote: |
_________________ 1984 Westy with tencentlife power! |
ZsZ Samba Member
Posted: Fri Oct 20, 2023 11:41 am Post subject: Re: Terminals for 14-pin dash connector |
MootPoint wrote: |
Thanks
tristessa wrote: |
ZsZ wrote: |
You are lucky. Brickwerks just announced last week that they managed to have them reproduced.
They already appeared in other european webshops, so it is just matter of time to have them in the US too.
https://brickwerks.co.uk/product/electrical-terminal-instrument-panel-edge-connector/
https://tk-carparts.de/crimpkontakt-n0171914 _________________ Zoltan
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6365 Location: Honolulu,Hawaii and France
Posted: Fri Oct 20, 2023 1:16 pm Post subject: Re: Terminals for 14-pin dash connector |
Thanks. at £1.00 each that's a bit pricey, but if nothing else is available...
I've written them to ask about shipping to the US. _________________ 1984 Westy with tencentlife power! |
