Help Locating a Fuel Pump Rebuild Kit (A. PIERBURG KG - neuß)
dwig0618
dwig0618 is offline
PostPosted: Sat Nov 07, 2020 5:38 pm    Post subject: Help Locating a Fuel Pump Rebuild Kit (A. PIERBURG KG - neuß) Reply with quote
I have a 1964 beetle with a A. PIERBURG KG - neuß fuel pump. The pump works fine, but the gasket for the top lid and set screw has deteriorated and gas is seeping.
I have drained all the gas from the car and hope to rebuild the fuel pump as a winter project. Does anyone know where I can locate a rebuild kit for the pump? I've checked Wolfsburg West, Cip1, etc. with no luck. Of course I can replace with pump, but it has worked great, I like the look of it, and would love to keep it working.
This site has always been great and helped me many times. Thanks for your help!
PostPosted: Sat Nov 07, 2020 6:09 pm    Post subject: Re: Help Locating a Fuel Pump Rebuild Kit (A. PIERBURG KG - neuß) Reply with quote
Wolfsburg West sells one but it says out of stock right now:
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111198553
Is the problem you can't find a kit or all or are they all out of stock?
67rustavenger
67rustavenger is offline
PostPosted: Sat Nov 07, 2020 8:53 pm    Post subject: Re: Help Locating a Fuel Pump Rebuild Kit (A. PIERBURG KG - neuß) Reply with quote
I happen to have a spare WW Kit.
Likely I bought the last two. Wink
dwig0618, If you don't want to wait for WW to get kits back in stock.
PM me and we can work out the details of getting a rebuild kit to you.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
bus guy
bus guy is offline
PostPosted: Mon Nov 09, 2020 10:17 am    Post subject: Re: Help Locating a Fuel Pump Rebuild Kit (A. PIERBURG KG - neuß) Reply with quote
BBT in Belgium make a nice kit. If you struggle to find one stateside I could hook you up with my supplier in the UK
mukluk
mukluk is offline
PostPosted: Mon Nov 09, 2020 1:36 pm    Post subject: Re: Help Locating a Fuel Pump Rebuild Kit (A. PIERBURG KG - neuß) Reply with quote
Grab a sheet of fuel proof gasket material and make new gaskets for the top cover and screw. You could even make new ones from a cereal box if you thoroughly coat them with gasket shellac before installation.
kreemoweet
kreemoweet is offline
PostPosted: Tue Nov 10, 2020 10:02 am    Post subject: Re: Help Locating a Fuel Pump Rebuild Kit (A. PIERBURG KG - neuß) Reply with quote
The WW kit mentioned above contains several parts that do not apply to your pump. Only WW can tell
you why they are in that kit.
There are excellent fuel screen/gasket kits for your pump available inexpensively from the vendor below,
they are shown about half-way down the page: http://www.type356a.com/services.html
'67 bug: seized by the authorities
