Carb plugs
Dan2973
Dan2973 is offline
PostPosted: Wed Oct 04, 2023 9:41 am    Post subject: Carb plugs Reply with quote
I am trying to set my timing with a vacuum advance distributor. What do you guys use to plug off the vacuum line on the carburetor?
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Oct 04, 2023 10:03 am    Post subject: Re: Carb plugs Reply with quote
Finger.
Or if I need my other hand to adjust the distributor, a short hose with a screw plugging it, or pull it off the advance unit and gently stick a golf tee in it.
Or your FLAPS may have plastic/rubber caps that will fit.
