Identify Top Boot and Tie Down Fastener
restcon
restcon is offline
PostPosted: Fri Apr 09, 2021 2:30 pm    Post subject: Identify Top Boot and Tie Down Fastener Reply with quote
I purchased a 74 Thing that came with a boot for the top. I am trying to identify the boot mfg. and figure out how the inside (the car) boot cover is secured to the top frame/car.
Per the attached picture there are two oblong grommets on the front side flap with two nylon straps, each with a plastic snap connector (female and female). I am assuming that these grommets and snap connectors are used for strapping down the boot flap up and under the top frame or to the body. But, I do not have the nylon strap that connects to the snap connectors - assuming that there is one.
Can anyone shed some light about the boot mfg and how the inside flap is secured?
Thanks.
74 Thing
74 Thing is offline
PostPosted: Fri Apr 09, 2021 3:28 pm    Post subject: Re: Identify Top Boot and Tie Down Fastener Reply with quote
https://www.thethingshop.com/TOP-FRAME-BOOT-WITHOUT-SHOW-BAR-CUTOUTS/productinfo/181+FB/
https://www.thethingshop.com/TOP-FRAME-BOOT-WITH-SHOW-BAR-CUTOUT/productinfo/181+FB-B/
Contact The Thing Shop
