back up lights
Al Gilliland
Al Gilliland is offline
PostPosted: Sat May 22, 2004 9:43 am    Post subject: back up lights Reply with quote
Hi everyone
Has anyone ever had a problem with their backup lights. All lights in the tail light assemblies work except for the backup lights (on both sides). Have an 88westy automatic. Any help would be appreciated
Cheers
Al
[email protected]
jsdesign@thecia.net is offline
PostPosted: Sat May 22, 2004 5:36 pm    Post subject: Reply with quote
1. check the fuse.
2. The back-up light switch is located on the shifter along with the netural safety switch. Remove the consol (4 screws) and check that the wire hasn't fallen off. If the wires are in place, connect the 2 wires from the back-up switch together, turn the key on. If the lights come on, the switch is dirty or broken, if they don't, the wire is broken between there and the lights.
'65 standard bus
'87 Vanagon Westfalia
Al Gilliland
PostPosted: Sat May 22, 2004 5:53 pm    Post subject: Reply with quote
thanks for the advice..will give it a try tomorrow
Al
weinerwagen
weinerwagen is offline
PostPosted: Sat May 22, 2004 6:44 pm    Post subject: Reply with quote
Cool Yup...cross the two wires with the key on....
check further if they dont work
bet its the switch at the shifter.... Rolling Eyes
Al Gilliland
PostPosted: Sat May 22, 2004 6:50 pm    Post subject: Reply with quote
thanks for the tip..hope thats all it is. would make for an easy fix..well at least I'd know aht's wrong
Al
