Ulu Samba Member
Posted: Sat Jan 27, 2024 7:13 pm Post subject: Re: SS100 "replica" Kit Kar |
Mocking up the crossmember with filler plates.
_________________ SS100 kit kar
1600cc DP |
Ulu Samba Member
Posted: Wed Jan 31, 2024 9:47 am Post subject: Re: SS100 "replica" Kit Kar |
The paint stripping took a few hours. I didn’t want any paint chemistry issues here, so I took it all off.
The red powder paint was a pain.
These filler plates were cut with my fake chinese sawzall, from the bottom of an old harbor freight welding cart.
Now they’re stripped & it’s all ready to weld up.
1600cc DP |
Ulu Samba Member
Posted: Wed Jan 31, 2024 9:20 pm Post subject: Re: SS100 "replica" Kit Kar |
When you think you are done cleaning, you need to look again. I wasn’t yet finished with the paint.
I also had to make a sleeve and these two shims.
These tubes have to be spliced, & I clamped them with some angles for alignment.
I put a sleeve inside for backup. I drilled thru the sleeve & used a little wire clip to keep it centered until welding.
There wasn’t enough clearance to install the crossmember, so I also had to modify my jig a little.
I spent some time preparing for impending rain, so no actual welding was accomplished _________________ SS100 kit kar
1600cc DP |
Ulu Samba Member
Posted: Sat Feb 10, 2024 12:05 am Post subject: Re: SS100 "replica" Kit Kar |
The rains dried up and I finally started welding again. I worked on this until I ran out of argon.
1600cc DP |
Ulu Samba Member
Posted: Sun Feb 11, 2024 12:26 am Post subject: Re: SS100 "replica" Kit Kar |
A 300amp bronze ground clamp and #2 cable rrplace my cheap stamped clamp and short #4 cable.
I got the rest of the crossmember welded.
Just hanging there…
I had some seam splitting on the electro-seam-welded tubes. I TIG’d them out. _________________ SS100 kit kar
1600cc DP |
Ulu Samba Member
Posted: Tue Feb 27, 2024 3:21 pm Post subject: Re: SS100 "replica" Kit Kar |
I needed to straighten out the floor pan before I welded to the crossmember and it was rather curled up from all the mishandling.
In order to straighten it out I made this set of fluting pliers, from some harbor freight welding clamp and random pieces of old steel.
Roughing out the dies
Welded to the clamp
I did a lot of grinding, filing, and sanding to get this profile smooth. It raises the panel a bit more than stock, if you clamp it all the way. If you crank the knob in until the clamp won’t latch, the process is totally controlable.
They straightened up the pan edge a lot. I’ll do the fine touches as I tack it to the frame.
1600cc DP |
Ulu Samba Member
Posted: Fri Mar 01, 2024 10:21 am Post subject: Re: SS100 "replica" Kit Kar |
Fitting up the new frame rails.
I must now square it up a bit and tack it all together. There will be other closures and gussets. _________________ SS100 kit kar
1600cc DP |
