Nessal Samba Member
Joined: May 08, 2005 Posts: 345 Location: CA Bay Area
Posted: Mon May 11, 2020 3:48 pm Post subject: Confused here....is this rust or something else? |
I decided to remove the rust on the pans so that I can start the rustproofing process. As I sanded down the pan and the brown "rust" area was disappearing, I started to see something black under it. When I sanded through the black stuff, that is when it hit steel. At that point, I'm not so sure that what I'm sanding away is actually rust. I'm starting to think that it is actually the aging adhesive that used to hold the original carpet padding down. I then decided to vacuum the entire pan before going any further. As you can see, it actually looks like the pans have very minimal rust if any and that I was actually sanding through another layer before hitting the pan. The black stuff feels like tar when I scrapped it with a razor blade. See second picture below. If this is the case, then I might have lucked out and it appears that I have less work in front of me than I initially thought.
What do you guys think? Is it still worth stripping the entire floor down to the steel and then recoating? It sounds like it's already pretty rust proof as it stands.
Nessal Samba Member
Posted: Mon May 11, 2020 8:20 pm Post subject: Re: Confused here....is this rust or something else? |
Nm. It's gunk from the tar boards. I'm going to start scrapping. Fun. |
halfassleatherworks Samba Member
Joined: December 09, 2018 Posts: 799 Location: Reno NV
Posted: Mon May 11, 2020 9:06 pm Post subject: Re: Confused here....is this rust or something else? |
J1 Samba Member
Joined: February 10, 2014 Posts: 707 Location: Bottom left
Posted: Mon May 11, 2020 10:36 pm Post subject: Re: Confused here....is this rust or something else? |
I went thorough a bunch of razors, mineral spirits and paper towels. Then afterwards discovered the below post about using dry ice for tar removal. Whatever means you use, good luck and as the kids these days say, “It’s oddly satisfying”
https://www.thesamba.com/vw/forum/viewtopic.php?p=3592038#3592038 _________________ 1971 Ghia coupe. Assume I know nothing and you'll be pretty darn close to the truth. |
Nessal Samba Member
Posted: Tue May 12, 2020 9:16 pm Post subject: Re: Confused here....is this rust or something else? |
It sounds like they are using it to remove the tar board itself. On mine, the tar board is already gone but it looks like there is residue EVERYWHERE. Literally, the entire pan is covered with this tar residue. It seems as if it was sprayed on or something. But I'll give this method a try when I get a chance. |
simon varley Samba Member
Joined: March 12, 2020 Posts: 175 Location: Geelong Australia
Posted: Tue May 12, 2020 10:15 pm Post subject: Re: Confused here....is this rust or something else? |
I had pretty good results with just a paint scraper to be honest. Seemed to be fairly brittle and just chipped off |
misterh Samba Member
Joined: May 03, 2018 Posts: 23 Location: Central Texas
Posted: Wed May 13, 2020 9:19 am Post subject: Re: Confused here....is this rust or something else? |
I use one of those oscillating tools with a flexible scraper blade. |
