Oil pressure sensor 1/8”npt vs M10x1.0.
craigolio1
craigolio1 is offline
PostPosted: Sun Dec 14, 2025 11:21 am    Post subject: Oil pressure sensor 1/8”npt vs M10x1.0. Reply with quote
Hey everyone.
I’m learning about sensors and gauges.
Regarding the oil pressure switch and adding an oil pressure gauge…. I see there are some senders threaded for M10x1.0 and some for 1/8NPT. Not as much selection with the M10x1.0 though. CIP1 says they’ve been putting 1/8NPT in to the VW case for decades, just don’t tighten it too much.
So what I’m gathering is the threads are so close it doesn’t matter. Just curious to hear opinions on that. If I add one I don’t want to ruin my case.
Also… what’s the opinion on getting a sender with the dual output for the light, vs getting a T and using the factory pressure switch as well as a sender?
Thanks!
Craig
Located in the Toronto area.
1971 Ghia Convertible
Join me on my Karmann Ghia journey.
https://www.thesamba.com/vw/forum/viewtopic.php?p=10441921#10441921
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Dec 14, 2025 11:56 am    Post subject: Re: Oil pressure sensor 1/8”npt vs M10x1.0. Reply with quote
The threads are almost identical so yes, it's very common to to install a 1/8 NPt into a M10x1.0 thread.
Note that the NPT is tapered so don't "crank" it in, just until it stop and snug.
A M10x1.0 is meant to go all the way in with a crush washer to seal it.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
craigolio1
PostPosted: Sun Dec 14, 2025 12:43 pm    Post subject: Re: Oil pressure sensor 1/8”npt vs M10x1.0. Reply with quote
Ahhhh I had to google the difference between a tapered and straight thread. Now I understand. Makes complete sense now. Thank you.
Craig
runamoc Premium Member
runamoc is offline
PostPosted: Mon Dec 15, 2025 10:42 am    Post subject: Re: Oil pressure sensor 1/8”npt vs M10x1.0. Reply with quote
a sender
Don't use Teflon wrap or any pipe 'dope' sealants. An electrical connection is needed between the sender and ground. I have used a crimp on ring connector between the sensor and the case for this connection because a PO made the threaded hole too big from over tightening and I had to use tape to keep if from leaking.
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
craigolio1
PostPosted: Mon Dec 15, 2025 12:12 pm    Post subject: Re: Oil pressure sensor 1/8”npt vs M10x1.0. Reply with quote
runamoc wrote:
a sender
Excellent tip. I did read that the sensors/sender grounds to the case and yet you still see people using tape and sealants.
I had wondered about using a ring terminal to over come this.
Craig
