sweden Samba Member
Posted: Mon Apr 27, 2020 10:49 am Post subject: Problem with Grant piston rings. |
I rebuild a 25 hp engine and have bought a set of new piston rings.
The oil control ring is made of 3 parts and the expander/spacer ring is soo hard, soo it´s impossible to get in the cylinder.
All other piston rings i have used before you can push easily together, but this model is hard as steel.
The piston is 74,96 and the piston rings are 75 mm.
Have any of you used this model before?
_________________ Me and my sons cars Typ1 -49 -50 -51 -52 -52 -53 -53 -54 -55 -55 -56 -56 -57 -58 cab -64 cab
T3 TriStar airride with Audi 1,8T engine and Porsche 996 gearbox. |
pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1140 Location: Germany
Posted: Tue Apr 28, 2020 12:01 am Post subject: Re: Problem with Grant piston rings. |
On the pictures it looks as if all the rings are too big in diameter. Have you checked the ring gap before, putting the rings in an empty cylinder, 5 mm from its downside??? They should have 0,3 to 0,45 mm, measured by feeler (thickness) gauge.
sweden Samba Member
Posted: Tue Apr 28, 2020 6:44 am Post subject: Re: Problem with Grant piston rings. |
Hi Pastellgreen!
That is what i use to do with others piston rings.
But i have never seen any oil control ring like this before.
The ends are marked with red and green color and both ends should sit tight together and not overlap, tells the manual.
When everything is mounted you should see both the red and green ends. Should i grind on the green end, the small edge will disappear and then nothing will hold up anymore and it will be able to slip under the red end.
sweden Samba Member
Posted: Tue Apr 28, 2020 1:03 pm Post subject: Re: Problem with Grant piston rings. |
Iam in contact with the manufacter now.
But i don´t have all information to them until tomorrow.
But the first anwser was.....PLEASE DO NOT GRIND OR MESS WITH THE OIL RINGS _________________ Me and my sons cars Typ1 -49 -50 -51 -52 -52 -53 -53 -54 -55 -55 -56 -56 -57 -58 cab -64 cab
Posted: Tue Apr 28, 2020 11:12 pm Post subject: Re: Problem with Grant piston rings. |
looking forward their answer. Had installed new piston rings from them on my 1200 40hp without any problems. The only thing is, that I am "trained" on installing the piston rings with their gaps in direction as the VW manual says. With the oil retaining ring from Grant, it changes all the directions, as their gaps are showing to the side and not upside as usual. |
sweden Samba Member
Posted: Tue Apr 28, 2020 11:35 pm Post subject: Re: Problem with Grant piston rings. |
pastellgreen wrote: |
Grants manual is not specail made for boxer engine soo allways put them as VW say. _________________ Me and my sons cars Typ1 -49 -50 -51 -52 -52 -53 -53 -54 -55 -55 -56 -56 -57 -58 cab -64 cab
Bengt H Samba Member
Joined: September 11, 2005 Posts: 334 Location: Sweden
Posted: Wed Apr 29, 2020 1:21 am Post subject: Re: Problem with Grant piston rings. |
If I remember correct Hans Landelius here in Sweden had the same problem as you lateley. |
sweden Samba Member
Posted: Wed Apr 29, 2020 8:27 am Post subject: Re: Problem with Grant piston rings. |
Bengt H wrote: |
Thanks Bengt i will mail him now. _________________ Me and my sons cars Typ1 -49 -50 -51 -52 -52 -53 -53 -54 -55 -55 -56 -56 -57 -58 cab -64 cab
sweden Samba Member
Posted: Wed Apr 29, 2020 1:34 pm Post subject: Re: Problem with Grant piston rings. |
Now i have been in contact with Hans and he had exacly same problem as me!!!!
Soo now we are two with same problem.
Iam still in contact with Grant and they want more measure from me.
Inside the piston box there is an date stamp 16 february 2017. But i bought them for 14 days ago. _________________ Me and my sons cars Typ1 -49 -50 -51 -52 -52 -53 -53 -54 -55 -55 -56 -56 -57 -58 cab -64 cab
sweden Samba Member
Posted: Mon May 25, 2020 12:16 pm Post subject: Re: Problem with Grant piston rings. |
It was wrong piston oil rings from Grant in the box.
I had very good mailcontact with the manufacter Grant and they solved the problem in best way.
Now the engine is done and runing.
Posted: Tue May 26, 2020 7:59 am Post subject: Re: Problem with Grant piston rings. |
Congrats on the running engine and you could solve the problem! |
sweden Samba Member
Posted: Tue May 26, 2020 10:05 am Post subject: Re: Problem with Grant piston rings. |
Thanks, on this problem i did spent many unnecessary hours on. The first two hours i thought i was the problem haha. But Grant compensated me in a very professional way. _________________ Me and my sons cars Typ1 -49 -50 -51 -52 -52 -53 -53 -54 -55 -55 -56 -56 -57 -58 cab -64 cab
Manfred58sc Samba Member
Posted: Fri May 29, 2020 7:27 pm Post subject: Re: Problem with Grant piston rings. |
I had same problem with 85.5 Grants, too big and won't fit. I only use Hastings now. _________________ Fat chick owner/operator |
