Tcash Samba Member
Joined: July 20, 2011 Posts: 12846 Location: San Jose, California, USA
RocketSurgeon Samba Member
Joined: May 26, 2005 Posts: 442 Location: Roseville, CA
Posted: Wed Jan 15, 2014 9:36 pm Post subject: |
Tcash... Are you a robot?...
thanks for all the contribution! _________________ 69 Westy |
Tcash Samba Member
Posted: Sun Aug 09, 2015 4:57 pm Post subject: Dusty conditions air cleaner. |
Tcash Samba Member
Tcash Samba Member
Posted: Tue Jul 05, 2016 8:37 am Post subject: Knecht Oil Bath Air Cleaner T2a Pick Up Truck 261 129 607 A |
Knecht Oil Bath Air Cleaner T2a Pick Up 261 129 607 A
ToolBox wrote: |
These work? This is a friends truck when he first recieved it from South America. It has been un-fu#@ed now. It was so jacked when he got it.
AlanWesty Samba Member
Joined: October 25, 2017 Posts: 7 Location: Pretoria, South Africa
Posted: Fri Jun 19, 2020 10:39 am Post subject: Re: Air Cleaner ID T2 |
Hi Guys,
Hope you don't mind me posting here but this thread is the closest what I could find to ID an Air Filter.
I have a non walk through Westy from '70 and I am having problems finding the right Air Filter.
Unfortunately the Westy ewas hacked and had a Toyota engine in it which I am busy reverting to aircooled.
So from this thread an many others I googled it seems my Westy should have a filter platform onto which a filter clips that has a cable connected to the cooling flaps. BUT
My Westy does not have a platform and instead has a "pillar" . It could be that this was installed aftermarket but it actually looks genuine. There are some burn holes which could have been the welds of a platform, but I can't say.
Also on this thread there is a High Dust filter which could have been what my Westy should have had but the "pillar" is different.
So I have attached some photos and hopefully someone can shed some light.
Thanking you for responses.
Pedestal I should have?
Pillar on my Westy
Pillar top fixture looks original?
Bottom fixture
Plarform I got and position it should go?
High Dust Filter on similar pillar. |
Posted: Fri Jun 19, 2020 11:36 am Post subject: Re: Air Cleaner ID T2 |
This one if for a Type 4, T-127 industrial engine with a single center mounted carb.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52876 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jun 19, 2020 2:17 pm Post subject: Re: Air Cleaner ID T2 |
You would have to remove that vertical bracket to mount the pedestal, it attaches to the wheel well where the bottom of the pillar is now.
That looks like the mount for the dusty conditions filter, the type 181 Thing uses the same part: https://www.thesamba.com/vw/classifieds/detail.php?id=2387709
That one also has a vacuum controlled thermostat, no goofy cable system required. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jun 19, 2020 2:27 pm Post subject: Re: Air Cleaner ID T2 |
busdaddy wrote: |
That one also has a vacuum controlled thermostat, no goofy cable system required. |
The Thing air cleaners typically don't either wear out or rust out, so there are a lot of them out there and not many buyer. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13524 Location: West Coast, USA
Posted: Fri Jun 19, 2020 5:07 pm Post subject: Re: Air Cleaner ID T2 |
After hunting for cables for half a decade, I’d gladly go with the Thing/dusty conditions filter if the bracket was already there.
My two cents.. _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
Posted: Fri Jun 19, 2020 10:37 pm Post subject: Re: Air Cleaner ID T2 |
Wow, thanks guys.
And thanks for all the photos they do make things a lot clearer.
I think I will try getting a thing filter as it will fit in the same way a Splitty filter fits (which I also have but intakes point in wrong direction).
Not sure how many Things were ever in South Africa but we also have a great forum and I might just get lucky.
Kind regards and many thanks
Alan |
