Lind Samba Member
Joined: November 06, 2000 Posts: 10212 Location: idaho
Posted: Thu Jun 18, 2020 8:57 am Post subject: Broken steering column |
I had the good fortune to borrow a '51 panelvan last summer. I drove it about 800km through Europe. It drove just fine for me, but right after I dropped it off, the owner went to drive it into his warehouse, and the steering column broke in two. I feel lucky that it didn't happen a few KMs before when I was driving at speed.
I recently talked to a friend who had the exact same thing happen to him on his '52 bus. Not rusty, it just snapped.
Both were early BDs with the separate box and column. Both columns broke in the middle, not at the end or the junction.
Has anyone else had this happen or heard of this? I am a bit concerned as I don't want this to happen on my '50. _________________ .
Wanted:
busben Samba Member
Joined: March 07, 2008 Posts: 539 Location: Somerset, UK
Posted: Thu Jun 18, 2020 3:05 pm Post subject: Re: Broken steering column |
Wow! Lind! No experience of this personally but that’s a pretty scary thought ...... especially with the various modified, big engined, early buses out there on the roads using stock front ends  |
andre b Samba Member
Joined: August 10, 2004 Posts: 810 Location: San Jose C.A.
Posted: Thu Jun 18, 2020 4:49 pm Post subject: Re: Broken steering column |
yep.my 52 steering rod snapped. I want to say almost half way point.luckily i was only going up a driveway,i think the pressure of the angle and the stiff front springs might have something to do with it,and is it just my barndoors..lol or do all the barndoors have a really stiff front end? |
Scotty Samba Member
Joined: July 02, 2003 Posts: 1553 Location: Northampton - Uk
Posted: Fri Jun 19, 2020 6:16 am Post subject: Re: Broken steering column |
First I've heard of this, you got me worried now!
andre b wrote: |
Given the square cross section of BD torsion leaves (due them all being the same size) I suspect they do. There is obviously a reason why vw changed the torsion leaves on later buses to the star cross section with different sized leaves _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
Posted: Fri Jun 19, 2020 6:25 am Post subject: Re: Broken steering column |
Scotty wrote: |
andre b wrote: |
Given the square cross section of BD torsion leaves (due them all being the same size) I suspect they do. There is obviously a reason why vw changed the torsion leaves on later buses to the star cross section with different sized leaves |
makes sense.my 53 kombi rides ok but still a stiff ride,i grease the crap out of too.the steering pin bushing is wore out and dreading pulling the front beam.if there's a way to put a later beam in lets see it?oh and deferentially not lowered ones,lol |
Lowdown Dirty Rat Samba Member
Joined: June 25, 2005 Posts: 891 Location: Cornwall, UK
Posted: Fri Jun 19, 2020 1:31 pm Post subject: Re: Broken steering column |
You got me freakin’ out
But I have a split beam in my Barndoor so softer leaves. Tell me I’m not going to die  _________________ 1951 Samba 20-017894
1952 Samba 20-028952 |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 842 Location: Oregon
Posted: Fri Jun 19, 2020 7:54 pm Post subject: Re: Broken steering column |
WOW!!! Hearing about 3 failures just here in this thread, SCARRY!! Thats an extremely high failure rate for such a critical part. Sound like they've all been with the 2 piece steering column systems.
In aviation we would send items like that out for a full NDI (non-destructive inspection), Magnaflux or etc looking for hairline cracks and corrosion pitting on the inside and out. These Services are available at many machine shops.....of course an upgraded column of some sort could be a better option. _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Lind Samba Member
Posted: Sun Jun 21, 2020 6:42 am Post subject: Re: Broken steering column |
Mr. OGPaint wrote: |
In aviation we would send items like that out for a full NDI (non-destructive inspection), Magnaflux or etc looking for hairline cracks and corrosion pitting on the inside and out. These Services are available at many machine shops.....of course an upgraded column of some sort could be a better option. |
Just two failures, Andre was the second one that I referred to in the original post.
I like your idea on the NDI. I don't know why I didn't think of that since I have a little experience with that from when I was a building inspector. We would do magnafluxing, and dye penetrant. There is also the good old ring it like a bell test also.
Both failures happened at slow speeds, which makes sense since the steering input has more stress on it the lower the speed. _________________ .
Wanted:
55samba Samba Member
Joined: June 21, 2002 Posts: 805 Location: CA Bay Area
Posted: Thu Aug 06, 2020 10:35 pm Post subject: Re: Broken steering column |
Probably a 2 piece shaft friction welded. That is a common manufacturing process. |
CaLiBus Samba Member
Posted: Fri Aug 07, 2020 4:26 pm Post subject: Re: Broken steering column |
So Lind, what did you decide to do? pics?  |
Lind Samba Member
Posted: Sat Aug 08, 2020 6:24 am Post subject: Re: Broken steering column |
CaLiBus wrote: |
we are going to inspect the column, and test it. Probably magnaflux it, definitely ring it like a bell and see if it makes a live sound or a dead sound. _________________ .
Wanted:
vintage water Samba Member
Joined: September 17, 2020 Posts: 81 Location: CONCARNEAU
Posted: Sat Sep 28, 2024 2:02 am Post subject: Re: Broken steering column |
hello,
I am looking for a photo showing the steering box in position under the chassis or even in section or in real life
thank you very much _________________ my job is reparing the steering box
https://www.facebook.com/profile.php?id=100057138233258 |
finster Samba Member
Joined: May 26, 2012 Posts: 9960 Location: not far from the madding crowd
Posted: Sat Sep 28, 2024 5:57 am Post subject: Re: Broken steering column |
this is a photo of a barndoor steering box as viewed from the rear looking forwards.
this is the area it fits to
_________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
