ntngman Samba Member
Posted: Sat Jun 20, 2020 10:08 am Post subject: WW Okrasa CSP linkage |
Can someone post a top view close up pic of the CSP linkage. Appreciate your time. |
6T5 square Samba Member
Joined: September 15, 2005 Posts: 1084 Location: Dover, DE
Posted: Sun Mar 17, 2024 12:07 pm Post subject: Re: WW Okrasa CSP linkage |
Instead of starting another topic , I figured I’d just leave this here.
Anyone with the CSP linkage for the kit. Do you have an issue with the linkage arm rubbing the bottom of the generator? Is there a remedy for this?
Thanks _________________ John
65 square 1500S (weezer) sold but always on my mind
60 beetle (Ned)
Quoting John Muir -- Open the rear boot. Get out the stool and sit down. Contemplate the air-cooled beauty before you. - How to Keep Your Volkswagen Alive -- Step-By-Step Procedures for the Compleat Idiot |
Vedderism Samba Member
Joined: October 02, 2020 Posts: 28 Location: Paramount
Posted: Sun Mar 17, 2024 8:37 pm Post subject: Re: WW Okrasa CSP linkage |
I had the issue, check to see that pushrods are fully seated on the bellcranks ball heads. |
esde Samba Member
Joined: October 20, 2007 Posts: 5971 Location: central rust belt
Posted: Mon Mar 18, 2024 6:14 am Post subject: Re: WW Okrasa CSP linkage |
6T5 square wrote: |
Thanks |
What engine? which CSP linkage, and what intake manifolds/ carburetors are you using?
There are a number of different kits offered
https://www.csp-shop.com/en/engine/fuel-system/carburetor-linkages/bellcrank-linkages/
If the intake manifold is too tall, sending the linkage under the generator might be out of the question. Hard to say without a little more info _________________ modok wrote:
Posted: Tue Mar 19, 2024 3:09 pm Post subject: Re: WW Okrasa CSP linkage |
Original 1200 36hp engine. I have had this kit since about 2010 so I would guess that it would be the original linkage kit. Running the carbs that came with the kit. Original manifolds that again , came with the kit _________________ John
60 beetle (Ned)
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 727 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Fri Mar 22, 2024 6:59 am Post subject: Re: WW Okrasa CSP linkage |
Thanks for posting the pictures Dan. The main difference I see is that I am running the balance tube behind the fan shroud. I never noticed but is one of the manifold pipes shorter than the other? That would make some sense because then if I flipped it around so the tube is in front of the shroud, the linkage would be a few mm lower and thus clear the generator.
60 beetle (Ned)
