Headlight rings (?) for 65 bus
rogercelliott
rogercelliott is offline
PostPosted: Tue Jul 28, 2020 7:07 pm    Post subject: Headlight rings (?) for 65 bus Reply with quote
So I have new headlights but they don't have the same notches to match my headlight rings or whatever you call those things that hold the headlights in place. It appears that the previous headlights weren't stock either and so there are extra notches cut into the rings. Seems the only I can get the rings is to buy the WHOLE headlight housing! Where can I get new rings? And what is the best way to get your new headlights mounted properly so they don't wind up out of whack? Thanks for your help!
Miskeroo
Miskeroo is offline
PostPosted: Tue Jul 28, 2020 8:01 pm    Post subject: Re: Headlight rings (?) for 65 bus Reply with quote
Are you looking for these? Check out the classified. I saw a few singles and pairs, basically anything you need for headlights
https://www.thesamba.com/vw/classifieds/detail.php?id=2376928
rogercelliott
PostPosted: Tue Jul 28, 2020 9:02 pm    Post subject: Re: Headlight rings (?) for 65 bus Reply with quote
[quote="Miskeroo"]
Hi Miskeroo
No I need the rings that retain the sealed headlight. They're inside the housing.
Roger
volkswagen60
volkswagen60 is offline
PostPosted: Tue Jul 28, 2020 9:51 pm    Post subject: Re: Headlight rings (?) for 65 bus Reply with quote
These?
$40 shipped for both. Let me know. Baaaarp!!
PostPosted: Tue Jul 28, 2020 10:57 pm    Post subject: Re: Headlight rings (?) for 65 bus Reply with quote
If you are looking for those inside rings make sure you verify they are Bus.
Bus vs. Bug holds the sealed beam headlight at 90 degrees from each other since they mount different in the Bug fender vs the Bus nose.
You can trim off one of the little mounting tabs though, in a pinch
hitest
hitest is offline
PostPosted: Wed Jul 29, 2020 9:10 am    Post subject: Re: Headlight rings (?) for 65 bus Reply with quote
I don't know from what part of the earth the ad two posts above mine hails, but those are a $2-$5 item at any junkyard or swap meet, anywhere, any time FYI
The inner aiming rings that Everett refers to are easily spotted in the wild as being for bug, bus left side or bus right side when facing the vehicle. Turn the complete unit toward you. There are 3 slots punched in the inner aiming ring. Mounting a headlight upright in a bug the 3 tabs are oriented (using a clock face as reference) exactly 9 and 12 o'clock, with the third being at approx. 4:30 (there are others with more than 3 slots- but you are looking at the main 3 in orientation). Using that as a base...
Rotate the unit until the ring slots are oriented as described above. It will quickly show whether the assembly will hold a bulb upright in one of the 3 configurations described. Ex: bus driver's side in America would have slots at 6, 9, and approx. 2:30 (o'clock). Passenger side- 12, 3 and about 7:30.
You easily spot these in the wild or at a swap meet using this simple criteria.
FU#5
volkswagen60
PostPosted: Wed Jul 29, 2020 9:51 am    Post subject: Re: Headlight rings (?) for 65 bus Reply with quote
I was just trying to help. There are very few aircooled vehicles in junkyards these days, if any. And spending hours scouring swap meets for these sounds like a waste of time to me. Also, most swaps are shut down.
I figured $10 each + shipping would put it at about $30-$35 depending on location. I don’t think $40 shipped is out of this world. Again, just trying to help with what I can, how I can. Thanks. Peace, keep vdubbin.
PostPosted: Wed Jul 29, 2020 11:16 am    Post subject: Re: Headlight rings (?) for 65 bus Reply with quote
I agree my outside rings ad above might be overpriced.
Someone had emailed me about them though so maybe not? No word back yet.
I changed it to OBO anyway Smile
What junkyard can you find decent Bus headlight rings in though?
I rarely see undented Bus ones at swap meets, I have more but they are all dented.
Restorable buckets are a dime/dozen though
Clean glass lenses are hard to find too
The inside rings... it's harder to find Bus ones.
I wouldn't pay that much but it wouldn't surprise me if someone did if they lived in a rusty area and wanted clean ones
Side rant: "Shipped" can get expensive these days, they keep jacking up the post office rates.
