brake upgrade for 69 bug
johnnyvw164
johnnyvw164 is offline
PostPosted: Wed Jul 29, 2020 5:41 am    Post subject: brake upgrade for 69 bug Reply with quote
Just getting back into aircooled VWs after 30+ years away. I just purchased a 69 Bug, and am already sorting through ideas for upgrades. I plan to put disks on the front, using OEM parts. Does anyone have info on upgrading the rear brakes to type 3 drums? (which I understand to be wider than type 1 brakes)
Thanks!
Relyt
Relyt is offline
PostPosted: Wed Jul 29, 2020 8:53 am    Post subject: Re: brake upgrade for 69 bug Reply with quote
I’ve been meaning to do this, it should be a straight swap from the backing plates to drum.
So you need backing plates, wheel cylinders, shoes, hardware, inner and outer bearings, and drums.
69 Beetle - Daily driver
1600 SP (unknown history)
30 PICT 1 w/power circuit (Volkzbitz)
205T (Bill)
johnnyvw164
PostPosted: Wed Jul 29, 2020 12:29 pm    Post subject: Re: brake upgrade for 69 bug Reply with quote
So inner and outer bearings? You do understand I'm talking about rear brakes only?
Relyt
Relyt is offline
PostPosted: Wed Jul 29, 2020 2:37 pm    Post subject: Re: brake upgrade for 69 bug Reply with quote
Sorry about that, you are right the bearings do not need to be pulled. I just have it on my list when I get around to swapping them.
205T (Bill)
