Cruise Control Inop on 2011 Jetta SE 2.5L Auto
Forum Index -> Water-cooled VW Share: Facebook Twitter
Buenos Diaz
Buenos Diaz is offline
PostPosted: Wed Aug 12, 2020 8:38 am    Post subject: Cruise Control Inop on 2011 Jetta SE 2.5L Auto Reply with quote
Ladies and Gentlemen,
The cruise control on my daughter’s 2011 Jetta SE 2.5L automatic is inoperative. It does not function at all. I can’t get the lights to come on or set speeds. Last year, I replaced all for wheel speed sensors due to a fault with one of them. I hoped that would solve the cruise control issue as well but it didn’t. I then replaced the brake pedal switch to no avail. I’ve checked all the fuses I could think of and they all checked out. There are no warning lights on the dash and everything else functions perfectly including tpms and brake lights.
Does anyone have any insight or more troubleshooting procedures I could use? Perhaps there is something wrong with the stalk although it seems to be in good condition and turn signals function. I’ve used the search function and other than what I’ve done it seems like the ecu may need to be reprogrammed to enable that function. I’d like to make sure that is the problem before I spend the money for that capability.
Thanks for the assistance,
Buenos
1967 21 Window Bus
1965 Beetle
2019 Atlas
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Wed Aug 12, 2020 8:56 am    Post subject: Re: Cruise Control Inop on 2011 Jetta SE 2.5L Auto Reply with quote
Multifunction switch, brake light bulb (yes, really), & brake light switch are the usual suspects.
Buenos Diaz
PostPosted: Wed Aug 12, 2020 8:59 am    Post subject: Re: Cruise Control Inop on 2011 Jetta SE 2.5L Auto Reply with quote
Thanks, I’ll double check the bulbs. Is there anyway to ops check the multifunction switch or just remove and replace?
Thanks again!
1967 21 Window Bus
1965 Beetle
2019 Atlas
Buenos Diaz
PostPosted: Wed Aug 12, 2020 10:18 am    Post subject: Re: Cruise Control Inop on 2011 Jetta SE 2.5L Auto Reply with quote
Bulbs are working. I’ll research replacing the multifunction switch.
1967 21 Window Bus
1965 Beetle
2019 Atlas
Buenos Diaz
PostPosted: Wed Nov 20, 2024 1:55 pm    Post subject: Re: Cruise Control Inop on 2011 Jetta SE 2.5L Auto Reply with quote
All,
Back at it with my daughter’s Jetta. Cruise control is still inop. Do I need VCDS to diagnose/repair? The horn is inop as well. Could the clock spring cause both issues? I don’t want to throw the parts cannon at it so any help diagnosing would be appreciated.
Thanks,
Buenos
1967 21 Window Bus
1965 Beetle
2019 Atlas
blankc72
blankc72 is offline
PostPosted: Fri Nov 22, 2024 5:07 pm    Post subject: Re: Cruise Control Inop on 2011 Jetta SE 2.5L Auto Reply with quote
Yes VCDS would tell you what codes all of the control modules have. If the clockspring has failed then there will be an airbag light on aswell. Without a good clockspring the car turns off the driver's airbag.
When my clockspring failed on my 2009 Jetta at 17k miles cruise still worked fine. All I lost was horn & steering wheel airbag until it got replaced.
Buenos Diaz
PostPosted: Fri Nov 22, 2024 5:22 pm    Post subject: Re: Cruise Control Inop on 2011 Jetta SE 2.5L Auto Reply with quote
blankc72,
Thanks for the reply! I don’t have an airbag light but the horn doesn’t work. I should probably have mentioned that before. I have a Carly code reader and I have code DTC_03591. Control circuit klaxon, which I’m guessing is the horn but I haven’t started looking into that.
I have no airbag codes or light. Maybe this narrows the cruise control problem down to the multifunction switch.
Thanks again,
Buenos
1967 21 Window Bus
1965 Beetle
2019 Atlas
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
