carcrazed Samba Member
Posted: Mon Oct 19, 2020 7:50 pm Post subject: 1961 with antenna and radio delete |
I have been curious to an answer for this. When I got my '61 it was all original right down to the radio delete plate, but it had an antenna. I understand that the dealers installed the antennas, but WHY install one if there is no radio to begin with? It seems like a waste of time and money for the dealer and customer to have an antenna installed. I suppose if someone wanted one added after the fact it would be ready. I restored my '61 bug back to stock with the radio delete plate and didn't even install an antenna back on the car. Any insight will cure my curiosity. _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1049 Location: Germany
Posted: Tue Oct 20, 2020 12:56 am Post subject: Re: 1961 with antenna and radio delete |
I own two model year 1961 sedans and in both cases, a radio and antenna have been installed and in both cases (!) the original delete plates heve been kept with the car!
In your case, perhaps a previous owner did not want a radio (like me) and reused also the original delete plate. For the antenna, he probably had no idea how to remove it without leaving the hole in the body.
One of my cars, I deleted the antenna and welded the hole, as it was at a very eye catching place over the wind shields top. The other car, I have already installed the delete cover plate but kept the hole of the antenna, still has to be welded. |
Posted: Tue Oct 20, 2020 4:54 am Post subject: Re: 1961 with antenna and radio delete |
Thanks for the reply. I am still curious though as I have traced back the car to the owner after it was new and he said there was never a radio in it, just the delete plate. _________________ 1965 Herbie Replica. 1776cc dual Kads.
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Tue Oct 20, 2020 1:33 pm Post subject: Re: 1961 with antenna and radio delete |
Overzealous dealer tech... drilled the antenna hole in the wrong car.....
Easier to add an antenna and possibly upsell the radio rather than repair the hole.
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34023 Location: Conejo Valley, CA
Posted: Tue Oct 20, 2020 1:44 pm Post subject: Re: 1961 with antenna and radio delete |
One possible explanation...
If he bought it off the lot, but didn't want a radio, it may have been removed by the dealer before he took delivery.
Back in the day, the radio was worth money but the antenna may not have been worth the trouble of closing/plugging the hole, at dealer rates. |
Posted: Tue Oct 20, 2020 3:56 pm Post subject: Re: 1961 with antenna and radio delete |
Some great input. I guess your guess is as good as mine. Just found it odd as I was thinking about it. Like putting bluetooth in without a source to run it these days. _________________ 1965 Herbie Replica. 1776cc dual Kads.
stale air Samba Member
Joined: August 23, 2007 Posts: 5155 Location: Senoia Ga, formally NorCal
Posted: Tue Oct 20, 2020 4:09 pm Post subject: Re: 1961 with antenna and radio delete |
pastellgreen wrote: |
Same thing on my 58, dealer installed radio, with the original block off plate still in the glovebox. A nice little piece to have. _________________ WANTED: Henry Veale Santa Rosa plate frames
EverettB Administrator
Joined: April 11, 2000 Posts: 69831 Location: Phoenix Metro
Posted: Tue Oct 20, 2020 4:33 pm Post subject: Re: 1961 with antenna and radio delete |
I like these guesses because I've had 2 VWs that had antennas but no evidence of any radio ever and I always thought that was weird.
Radio antenna installed but original block offs still in place.
One of them even had speakers cut into the door panels but no evidence of any wiring to the doors.
I think a previous owner did that one and then gave up when he either didn't want to or couldn't figure out how to run the wiring.
I should probably that but at least they didn't hack anything further, it was easy to fix the door panels. _________________ How to Post Photos
Posted: Wed Oct 21, 2020 4:31 am Post subject: Re: 1961 with antenna and radio delete |
Ok. Sounds like Everett had the same thing. I am 99% sure the plate had never been removed just by looking at the patina on the dashboard when I got it. I am assuming that it was part of the dealer prep list when the car arrived at the dealership...no radio...oh well. Install the antenna anyway since it is part of our list. _________________ 1965 Herbie Replica. 1776cc dual Kads.
splitjunkie Samba Member
Posted: Wed Oct 21, 2020 5:27 pm Post subject: Re: 1961 with antenna and radio delete |
If the delete plate was never removed there should be grey putty over the retaining tabs. _________________ Chris
Slow 1200 Samba Member
Posted: Thu Oct 22, 2020 6:38 am Post subject: Re: 1961 with antenna and radio delete |
same here, radio delete plate and antenna on my 67 |
