Ljrig Samba Member
Joined: February 07, 2015 Posts: 49 Location: Charlotte
Posted: Tue Nov 03, 2020 7:59 pm Post subject: Unsolvable stutter/hesitation under load while driving... |
Hey guys, been a while since I have posted on here but I am always reading on here. Just turns out that this time I cant find the information I am looking for.
So... In my 1970 standard I have a 2027cc engine with a stroker crank, 1.25 rockers, cam, single Empi HPMX 44 carb, etc. So I recently had the engine out to replace the transmission with a late model tranny, while I had the engine out I added a full flow system using CB Performance's MAXI30 oil pump and cover, stainless lines and AN fittings, additional external oil cooler, oil temp/press. sensors and gauges, the works. Since doing this and putting the engine back in, somehow/someway the engine has developed a bad misfire and stutter while accelerating under load, and at random points while cruising just maintaining speed you can hear one or two of the cylinders missing here and there...
So far I have tried different plugs (making sure the proper gap was set), tried different plug wires, a different distributor and ignition puck (now have the Empi Accu-Fire in it), put a different coil in it (currently it has a pertronix flame thrower 3.0 ohm epoxy filled coil), I made sure the valves were all set and not tight (the gap is set at .008), I have made sure all the wiring is nice and neat and no wires are broken or anything, and most recently I put in an MSD Street-Fire ignition box in it in hopes of giving it more accurately controlled (and hotter) spark to get rid of the hesitation, but nothing has worked.
Also today I checked the plugs and they were slightly fouled, after I put the MSD box in I cleaned the plugs re-set the plug gap from .025 to .035 and the engine stutter SLIGHTLY improved (I think) but not by very much...
What else could i possibly do??? |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11507 Location: Huntington Beach, CA
Posted: Tue Nov 03, 2020 8:12 pm Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
Picture? _________________ Jimbo
| TDCTDI wrote: |
| Basically, a whole bunch of fuckery to achieve a look. |
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Ljrig Samba Member
Posted: Tue Nov 03, 2020 8:22 pm Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
| What, just a picture of the engine bay? I don't have an updated pic of it with everything added, I will have to get a pic of it in the morning. |
Posted: Tue Nov 03, 2020 8:26 pm Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
| Ljrig wrote: |
Yep! Let’s see what’s there. Then I’ll give you my 2 cents. _________________ Jimbo
| TDCTDI wrote: |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16797 Location: North Florida, USA
Posted: Tue Nov 03, 2020 8:46 pm Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
You seem to have described everything but the distributor. What make and model distributor are you running? How have you set the timing?
You mentioned cleaning the spark plugs. What method did you use? I have found the only good way to clean spark plugs is to use a dry media blast (pneumatic spark plug cleaner). If you used anything metal (eg. wire brush) to clean the fouling off the spark plug/insulator you may have opened a path for the spark to ground w/o jumping the electrode gap. Basically creating a misfire. If you cannot clean the plugs with dry media (glass bead) then just replace the plugs with new ones when they foul.
The MSD ignition is a CDI ignition system and produces very high voltage in the secondary circuit. This means the voltage passing thru the distributor and plug wires will be much higher than originally designed. The 3-ohm Pertronix coil is probably not the best coil for use with a CDI ignition. While it is not required, a coil with lower resistance will generate higher secondary current.
The MSD instructions call for non-solid core plug wires. Are you running spiral cored wires?
You should also run your engine in the dark and look for stray sparks at higher rpms. This would show where the sparks are jumping to ground. Spraying a mist of water from a bottle will also encourage the spark to jump to ground. There should be no where between the coil and the spark plug that a spark should “leak” out of the secondary circuit. Check the distributor cap/rotor looking for evidence of arcing to ground. _________________ AshMan40
frenchroast Samba Member
Posted: Tue Nov 03, 2020 8:53 pm Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
| Ljrig wrote: |
| Since doing this and putting the engine back in, somehow/someway the engine has developed a bad misfire and stutter while accelerating under load, and at random points while cruising just maintaining speed you can hear one or two of the cylinders missing here and there... |
I had those symptoms a few months back - failed condensor. I don't know too much about electronic ignitions but you might want to look into a failing module. I've had some bmw coil packs fail before but they're easy to diagnose because the fault code points you right to it. |
Ljrig Samba Member
Posted: Tue Nov 03, 2020 9:40 pm Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
| ashman40 wrote: |
You mentioned cleaning the spark plugs. What method did you use? I have found the only good way to clean spark plugs is to use a dry media blast (pneumatic spark plug cleaner). If you used anything metal (eg. wire brush) to clean the fouling off the spark plug/insulator you may have opened a path for the spark to ground w/o jumping the electrode gap. Basically creating a misfire. If you cannot clean the plugs with dry media (glass bead) then just replace the plugs with new ones when they foul. |
It's a 009 distributor with the Empi Accu-Fire ignition system instead of points, currently i have the advance set to 12 degrees at idle (which is on the list to reduce when i work on it tomorrow).
I have looked at it at night for any spark discharge coming from the distributor seems to be in perfect shape.
I cleaned the plugs with fine sand paper in between the point and contact on each plug... And I do have (I think 8mm, maybe 7mm) Pertronix spiral wound plug wires on there. |
vwoldbug Samba Member
Posted: Tue Nov 03, 2020 10:07 pm Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
| Have you tried cleaning carb jets. |
Ljrig Samba Member
Posted: Tue Nov 03, 2020 10:18 pm Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
| vwoldbug wrote: |
Yes sir i have made sure the jets are all free and clear, I actually completely rebuilt the carburetor a few months ago so I don't suspect that to be a problem. It is a little bit rich with the idle jets I have in it right now but have also tried swapping to leaner jets the other day but did not have any affect on the problem. |
Posted: Wed Nov 04, 2020 9:02 am Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
Have you taken a look at the underside of your distributor cap? Does it look anything like this:
Ok, that’s an extreme example of arcing at the distributor cap. The lines are examples of arcing. Any lines would suggest sparks are jumping between posts and not flowing thru the normal path thru the plug wires.
As a secondary test to the in the dark test, take a length of grounded wire and pass the exposed end along the plug wires in the dark/shade. Keep the wire a few mm away from the spark plug wire. You could even create a loop that wraps around the plug wire and pass it over the entire length of each wire. The ground wire offers a ground path for sparks to jump to. Any cracks in the spark plug wire will allow the spark to “escape” and jump to the ground wire.
The last thing to check is fuel. How long ago since you replaced the fuel filter? More than 2yrs or can’t remember when you replaced it... time to install a new filter. Most fuel filters are metal canisters and not see-thru. They get changed after a set time to ensure a clean fuel delivery system.
Also confirm the carb accelerator pump is discharging immediately upon movement of the throttle arm. If there is any delay it appears as hesitation on acceleration. Just look down the carb opening while you quickly pull on the throttle arm. You should see a stream of fuel from the carb discharge nozzle. _________________ AshMan40
Starbucket Samba Member
Posted: Wed Nov 04, 2020 9:33 am Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
| Sounds like raw fuel getting to the plugs. Feel under the manifold under the carb (careful it should be real hot after running a few min.s) and if its ice cold, that's the problem (cold weather will bring on the symptoms). |
Ljrig Samba Member
Posted: Wed Nov 04, 2020 4:17 pm Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
| Starbucket wrote: |
Thanks for the reply. This seems to be the main problem now actually...
So today while working on the engine I set the timing back down to 5 degrees at idle and it is around 30 degrees total advance at RPMs, it seemed to fix the spark knock sound I think I was hearing on hard acceleration. I then took the distributor cap I had on there off to take a picture to upload here for you guys to get a better look (but can't figure out why Samba says "photo upload successful" but then I can't see what I just uploaded to post on here...) and that distributor cap's pin in the center inside was smashed all the way up into the cap not springing back and seemed to be worn down from use.
So, I put on a cap I had laying around and drove it to the parts store to buy a new new cap and when I changed it in the store parking lot after buying the cap, that other cap that I had put on it to drive to the store had the same thing, the center pin inside was smashed in again. So, I took out this spacer ring off of the shaft of the distributor that was supposed to keep enough space between the magnetic puck and the pickup for the Accu-Fire ignition system, and that seemed to fix the spacing between the rotor cap and the point inside the distributor cap and all was well with the dist. cap after that.
I then felt the center intake manifold under the carburetor after I got back from the parts store and, sure enough, it was very cold to the touch and not hot like it is supposed to be. I know this means the heat risers must be blocked and that is why they aren't feeding hot air through the manifold. BUT, when I installed the manifold and did all of that this summer I made sure the heat risers had a clear hole (I drilled them out to be free and clear from crappy aftermarket welds) so there shouldn't be a problem with them being blocked. Is it possible that the manifold just isn't getting ENOUGH hot air through it? Is there anything I can do or add to get better hot airflow through the heat risers and into the manifold? Thanks for the help. |
Posted: Wed Nov 04, 2020 5:45 pm Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
| After market exhaust manifolds do not feed hot air well because the spacing from exhaust ports to the heat riser doesn't draw the hot air through the heat riser pipes. Compare to a stock one and you will see. The answer is probably a stock muffler. |
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1574 Location: Westfield, MA.
Posted: Thu Nov 05, 2020 4:10 am Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
| Your describing almost exactly what my symptoms were on my '75. After much hair pulling it turned out to be a faulty capacitor! Brand new NON German bosch...and I had a second one fail . Both lasted about 200 miles. Now running an old used bosch made in Germany and no problems. I need to do some research on who makes a good one! |
anthax Samba Member
Joined: October 21, 2016 Posts: 318 Location: Hälsingland, Sweden
Posted: Thu Nov 05, 2020 10:33 am Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
Ground strap between tranny and pan?
Your spark have nowhere to go if you don't have a good ground. |
Posted: Thu Nov 05, 2020 1:40 pm Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
| Ljrig wrote: |
So, I put on a cap I had laying around and drove it to the parts store to buy a new new cap and when I changed it in the store parking lot after buying the cap, that other cap that I had put on it to drive to the store had the same thing, the center pin inside was smashed in again. |
I suspect you have the same issue I ran into with AccuFire and CompuFire magnetic discs... they are too thick and cause the rotor to sit too high.
Check this... remove the rotor from the center shaft of the distributor. Measure how much of the center shaft extends above the electronic ignition black magnetic disc. Now measure the distance from the bottom edge of the rotor into the inner surface where the top of the distributor shaft would come to rest. The shaft length and rotor depth should be nearly the same. I think you will find the rotor is too tall (exposed shaft is now too short since the disc takes up some height) to allow the rotor to fully seat onto the top of the shaft. To fix this you will need to cut down the height of the rotor by shaving the bottom. A few minutes using some 40grit sandpaper on a flat surface will quickly grind down the bottom of the rotor. You ideally want the rotor to hold the disc down but not ride so high that it compresses the button in the center of the cap so far. A small gap between the disc and the bottom of the rotor is fine and confirms the rotor is fully seated.
If your magnetic disc is supposed to have a spacer below the disc you should put it back. The disc should spin just above the electronic module and never make contact. Without the spacer the disc will be resting on the top of the electronic module. I wouldn't be surprised if the top of your module now has signs of rubbing from the disc. If so, replace the spacer and cut the rotor even more.
In my case I noticed this after first installing the electronic ignition and when I started the engine and went around to the rear to look at the running engine I saw the distributor cap "dancing"! The rotor would lift the cap just a little as it hit each of the 4 posts as it rotated around. _________________ AshMan40
Ljrig Samba Member
Posted: Thu Nov 05, 2020 3:41 pm Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
| Starbucket wrote: |
Well a stock muffler for my motor would definitely not be best so I've looked at old mufflers and alternative options and am going to modify one side's heat riser flange and weld a pipe on to reroute that side to a pipe on the merged header where there is low pressure and good flow so it will draw air through from the other side's heat riser and should give consistent flow. |
Ljrig Samba Member
Posted: Thu Nov 05, 2020 3:45 pm Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
| anthax wrote: |
Oh yeah I have gone through grounds so many times on this car, plenty of ground straps from engine/tranny to pan and chassis and battery. Even have a grounded bus bar under the front hood that is grounded directly to the chassis that I connect any electrical things to to make sure they have the best ground possible. |
Ljrig Samba Member
Posted: Thu Nov 05, 2020 3:51 pm Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
Ashman, I appreciate the feedback. The magnetic disc for the Accu-Fire doesn't sit on the magnetic pickup as of now, the small ring was only there to give ADDITIONAL space between the disc and the pickup, I assume different distributors might need the spacer ring but mine does not seem to need it. The instructions that came with the module said, I think, around .010 was the correct spacing between the disc and the pickup.
I had the same problem you describe with the distributor cap "dancing" while the car was running! Until i removed the spacer ring of course. It's a wonder that doesn't do more damage or create worse running problems than it does when that happens... Seems now my only problem is getting the headers modified to get good airflow through the heat risers to keep my intake manifold hot and keep the fuel vaporized. |
Posted: Fri Nov 06, 2020 9:22 am Post subject: Re: Unsolvable stutter/hesitation under load while driving... |
That spacer ring that sits below the magnetic disc is there to maintain the air gap between the magnetic disc and the top of the electronic module for some distributor models. If you were running the spacer when not needed it means the magnets in the disc were being held further away from the pickup that senses them. I could see how this could cause a misfire especially at higher rpms as the pickup would have a harder time sensing the magnet passing by.
Also, based on your timing settings from earlier (12BTDC @idle) and your updating timing (5BTDC @idle and 30BTDC total)... it sounds like you were running 37BTDC total timing earlier? That is way too much total timing and will likely result in detonation when under load (acceleration) at higher rpms. This is further supported by you saying after you reduced the timing you can no longer hear the “knock sound”. It appears you were running too much timing advance. This is one of the problems with the OO9 distributors... inconsistent advance curves between makers. This is why their timing is set at total advance to make sure they don’t take you past 32BTDC where you risk detonation. Depending how long you were running with this ignition timing and how often you took the engine into detonation you could have physically damaged your engine. _________________ AshMan40
