RBEmerson Samba Member
Joined: November 05, 2011 Posts: 2208 Location: SE PA
Posted: Fri Jul 05, 2024 2:32 pm Post subject: Air Intake Hose - '90 Westy |
The accordion hose between my air cleaner and the air intake sheet metal has failed. The part number on the hose is 025-129-626. Unfortunately, all I seem to find with this part number is a silicon boot about 3" long, while the hose with the same part number is about 7" long - clearly not the same part.
The part I'm after is #11, but all I get on GW, etc. is #13. Look here
Is this hose NLA? _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5668 Location: Bemidji, MN
Posted: Fri Jul 05, 2024 2:45 pm Post subject: Re: Air Intake Hose - '90 Westy |
#11 isn't a real critical hose, it can be anything that fits over the hose barb. even wrapping the old one with a bunch of electrical tape is fine. that hose allows the motor to draw cooler, less dusty air but leaks and cracks won't be any sort of show stopper. _________________ -dan
www.thefixitworkshop.com |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15344 Location: Syracuse, NY
Posted: Fri Jul 05, 2024 3:24 pm Post subject: Re: Air Intake Hose - '90 Westy |
measure the fittings and there should be some aluminum pre-heater hose that'll fit it at a reasonable value
https://www.google.com/search?q=heat+riser+aluminum+hose _________________
Abscate wrote: |
Posted: Fri Jul 05, 2024 3:32 pm Post subject: Re: Air Intake Hose - '90 Westy |
For the time being, I've used Flex-Seal tape (y'know, the kind the guy in the TV ads makes boats with) to join the hose at the split. I 'm hoping to come up with the real part "just because it looks right", but, yeah, worse comes to worse, there are are alternatives. _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
