Front seats
Ksmit258
Ksmit258 is offline
PostPosted: Sun Dec 06, 2020 1:36 pm    Post subject: Front seats Reply with quote
Anyone have any pictures or suggestion on material for floor where seats will be installed...should I put cross bracing under floor to help support seats...if so should I bolt to tubing or weld and so one...thanks
Ksmit258
Ksmit258 is offline
PostPosted: Sun Dec 06, 2020 1:37 pm    Post subject: Re: Front seats Reply with quote
Guess I should have states sand rail
thesatelliteguy
thesatelliteguy is offline
PostPosted: Sun Dec 06, 2020 4:47 pm    Post subject: Re: Front seats Reply with quote
Can you provide a pic of your tail and where you want to have the seats?
Toyotas are so bumpy it makes me sick, literally.
My build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=383878
dustymojave
dustymojave is offline
PostPosted: Sun Dec 06, 2020 6:36 pm    Post subject: Re: Front seats Reply with quote
The floor of a buggy should be like 16 gauge aluminum, preferably 6061 T6 or steel sheet of 18-20 ga. Some like to let sand fall out using 16 ga expanded steel.
The floor should NEVER be used to mount seats, pedals, belts, etc. There should be frame structure, such as 1" 065 wall tube to mount seats to. That's what the seats are mounted to in my Hi Jumper that you see in my avatar. Plenty strong enough for offroad racing.
Richard
SoCalBajas Member
cbeck
cbeck is offline
PostPosted: Sun Dec 06, 2020 7:48 pm    Post subject: Re: Front seats Reply with quote
First pic shows the tabs for the front of the seat mounts and a double shear tab for the crotch belt whoch points straight to the hole in the seat for that belt.
Second pic shows the bar ( tube) and tabs for the rear seat mounts.
My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779
Ksmit258
Ksmit258 is offline
PostPosted: Tue Dec 08, 2020 2:34 pm    Post subject: Re: Front seats Reply with quote
Thanks for the pictures and someone said post some pics.
I would like secure these brackets some how...the mrs want be able to drive so was going to put a slider in...thinking about the floor and gage that was mention and maybe some cross members supports all the way across.
Don’t have really any good idea to tie floor to back near Torsion bar going across
Ksmit258
Ksmit258 is offline
PostPosted: Tue Dec 08, 2020 2:35 pm    Post subject: Re: Front seats Reply with quote
Also think you can see from picture belts or already tied in frame good
thesatelliteguy
PostPosted: Tue Dec 08, 2020 3:49 pm    Post subject: Re: Front seats Reply with quote
Weld some square tube in there.
dustymojave
PostPosted: Tue Dec 08, 2020 8:56 pm    Post subject: Re: Front seats Reply with quote
No need to add extra tubes or stress what to mount the back edge of the floor to.
My Hi Jumper never had any square tube to mount the floor. No angle stock. Never had any tubes on the torsion housing. Tabs on the side tubes and on the center tube near the torsion housing takes care of the back edge of the floor panel.
Richard
SoCalBajas Member
