Subaru E20 with Megasquirt
av8shunmeckaneck
av8shunmeckaneck is offline
PostPosted: Sat Dec 05, 2020 2:25 am    Post subject: Subaru E20 with Megasquirt Reply with quote
Is anybody running an EJ20 with Megasquirt? I'm looking to compare tune files. Stock and/or modified tunes are available all day long for a Subaru ECU on places like Nasioc but nobody there really uses Megasquirt. Stock setup uses MAF but I'm using speed density since the JDM engine didn't come with the MAF sensor.
My engine is a stock EJ205 with a modfied aftermarket intercooler.
Bad bug
Bad bug is offline
PostPosted: Sat Dec 05, 2020 6:06 am    Post subject: Re: Subaru E20 with Megasquirt Reply with quote
Morning the best place to get this is over on the megasquirt forum.
gprudenciop
gprudenciop is offline
PostPosted: Sat Dec 05, 2020 10:27 am    Post subject: Re: Subaru E20 with Megasquirt Reply with quote
Most tunes I have seen for a subaru are way off. I am running a megasquirt with a 2.5 but using very non standard parts. I have been running this tune for years without change at 27psi. Post up a screen shot with what the problem is and I will help.
Never look down at anybody unless you are helping them up..
Loaning someone your strength instead of reminding them of their weakness = kindness..
panel
panel is offline
PostPosted: Sat Dec 05, 2020 7:58 pm    Post subject: Re: Subaru E20 with Megasquirt Reply with quote
av8shunmeckaneck.......what did you need ? I'm with the comments from above also. I have a tune....actually a few from lots of guys.
My '65 Bus~Subaru EJ20 Megasquirted Turbo conversion
