4mymalamute Samba Member
Posted: Wed Dec 09, 2020 7:57 am Post subject: Slider door difference between power locks and non power? |
I am about to purchase a slider door off another late model van (my syncro is a 1989)...question though...I have factory power locks and not sure the donor door had them (all items are stripped off the door). Is there a way I can see if it did OR if it did not, can I just switch over all my components from original door to donor door? Thanks for the clarification. _________________ 1989 Sally the Syncro.....she is a work in progress. |
Timwhy Samba Member
Timwhy Samba Member
bobbyblack  Samba Member
Joined: May 21, 2015 Posts: 2949 Location: United States, Iowa
Posted: Wed Dec 09, 2020 8:43 am Post subject: Re: Slider door difference between power locks and non power? |
Tim(why?)
I've purchased a contactor pad you show in the door for a project, not for power locks. I still need to find the pin/spring plate for the frame, I suspect it may be similar to another VW/Audi part... Could i beg you to take a picture of the frame side, please?
Thanks,
-bobby _________________ '87 Westy 'Flossie','83.5 Vanagon L 'ZoomBus','74 Karmann Ghia, '63 Notch |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1007 Location: Budapest Hungary, Europe
sliding doors with power lock have a cutout for the contact plate and a welded in bracket to hold the actuator
You can cut out the hole measured from the old door and you can buy a bracket:
https://www.brickwerks.co.uk/cdl-bracket-kit-t3-sliding-door.html _________________ Zoltan
1.9 MTdi Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
kiltedhiker Samba Member
Posted: Wed Dec 09, 2020 10:42 am Post subject: Re: Slider door difference between power locks and non power? |
Bobby,
Is this what you are looking for?
Steven _________________ 1989 Syncro Westfalia (bought new) sold
1990 Syncro Westfalia sold
1990 Syncro TinTop |
Posted: Wed Dec 09, 2020 12:56 pm Post subject: Re: Slider door difference between power locks and non power? |
Steven, yes perfect!! Thanks! (now I need to see if there is a hole already in that spot on my frame, or if the holes/threads need to be cut)
Posted: Wed Dec 09, 2020 2:55 pm Post subject: Re: Slider door difference between power locks and non power? |
Thank you for the pictures and clarification. I will check the slider and see if it has it cut out already...I hope so.
Thanks again everyone. _________________ 1989 Sally the Syncro.....she is a work in progress. |
