engine seal
johnnyvw164
johnnyvw164 is offline
PostPosted: Fri Jan 15, 2021 1:52 pm    Post subject: engine seal Reply with quote
So who makes a good quality rubber seal for the engine compartment (the one that seals off the upper part of the engine from the lower part when it's in the car). The one I got this past summer was shaped like a "J", really doesn't seal well like the OEM that has two lips that go above and below the sheet metal.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Jan 15, 2021 2:22 pm    Post subject: Re: engine seal Reply with quote
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
johnnyvw164
PostPosted: Fri Jan 15, 2021 2:56 pm    Post subject: Re: engine seal Reply with quote
Thanks for posting that Glenn. It's interesting, the car as I got it had the early style seal. What would be the actual years that was used? Mine is a late 69 M.Y.
The late style seal I got doesn't hook onto anything....the breast plate doesn't sit down low enough for the "J" to catch the edge of the sheet metal. Maybe I'll just have to get clever and figure out something to attach them together.
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Fri Jan 15, 2021 11:09 pm    Post subject: Re: engine seal Reply with quote
Model year 1967 was then they went to the 111813705D rear engine cover plate seal.
Andy T.
2type2
2type2 is offline
PostPosted: Sat Jan 16, 2021 5:25 am    Post subject: Re: engine seal Reply with quote
I'm experiencing rather same problem with the late seal. I made my rear apron removable and did not have a seal issue.Then went and replaced the entire bottom seal. The only place it doesn't fit well is across the back where it doesn't quite seem wide enough to push against the plate. I did not ever have that issue with the first rubber I put in when first modifying the apron. Im thinking of trying a heat gun to force it to fit, but just miffed... more shitty parts again!
Does anyone know of any particular maker/brand of better-sealing rubber? I think many of us have a less than perfect fit .Although I don't like the foam material, it is interesting how well a bay bus lower engine foam piece
fits and seals. One of us has to find a solution I suppose.
"A life of peace and happiness depends on your own gratefulness"
