Baja bug with 2.0 TDI CUAA diesel
syncrogreg
syncrogreg is offline
PostPosted: Thu Apr 18, 2019 5:38 am    Post subject: Baja bug with 2.0 TDI CUAA diesel Reply with quote
So I recently bought full production molds of VW bug as well as chassis jig. I have been running a version to Pikes peak in 2018 and going one more year this June 2019.
I'm confident that plateform on King shocks and proper control arms is going to be winning some Dakar races. Please follow along the build if you are into Motorsports.
Talk soon!
conversions: www.boxeer.com Common rail TDI and NOW PDK transmissions!!
travel pictures:
http://instagram.com/crepeattack/
- the Pastis build: http://www.thesamba.com/vw/forum/viewtopic.php?t=434656&highlight=subaru+diesel
syncrogreg
PostPosted: Mon May 13, 2019 7:28 am    Post subject: Re: Baja bug with 2.0 TDI CUAA diesel Reply with quote
The engine I'm using right now is brand new crate engine VW 2.0 TDI MK7 with just a Garrett GTB2260VK and develop (222WHP/265BHP)
I'm also about to fit the European version MK7 that come stock with 240BHP and much stronger internals and factory ported head. This will make it easy to reach 400BHP.
travel pictures:
VolkFanJefe
VolkFanJefe is offline
PostPosted: Fri May 17, 2019 7:35 am    Post subject: Re: Baja bug with 2.0 TDI CUAA diesel Reply with quote
Looks like a fun ride!
Subscribed....
Would dig seeing a diesel powered long travel baja bug!
Cody Loren
Cody Loren is offline
PostPosted: Fri May 17, 2019 10:57 am    Post subject: Re: Baja bug with 2.0 TDI CUAA diesel Reply with quote
Yea too wouldn’t mind that in my rail
syncrogreg
PostPosted: Wed Jun 19, 2019 11:56 am    Post subject: Re: Baja bug with 2.0 TDI CUAA diesel Reply with quote
Small update! We're on our way to Pikes Peak with a super updated Bug. New CV axles from The DriveShaft Shop, slick tires from BFGoodrich, and clutch and flywheel from Southbend Clutch.
The car is up to 222whp and 320wtq, wet weight with driver 1800lbs! Such a beast! Loaded up on the trailer and headed west. Our Vanagon Syncro Westy is caravanning along as our assistance vehicle, and it's got the same motor, so we've got spares!
If you're in the area, come check us out at Fan Fest in downtown Colorado Springs on June 28th! We'll be there to show off the bug and answer questions.
We're shooting for the fastest diesel time up the peak, so keep an eye out for our new record!
travel pictures:
syncrogreg
PostPosted: Wed Jun 19, 2019 12:21 pm    Post subject: Re: Baja bug with 2.0 TDI CUAA diesel Reply with quote
On our way to Pikes Peak! Lots of photos and stories to come...find us on Instagram and Facebook to follow along with the journey!
IG: @boxeer_
FB: tinyurl.com/boxeer
travel pictures:
Axitech
Axitech is offline
PostPosted: Wed Jun 19, 2019 3:37 pm    Post subject: Re: Baja bug with 2.0 TDI CUAA diesel Reply with quote
Looks like a blast!
He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.-Thomas Jefferson
cbeck
cbeck is offline
PostPosted: Wed Jun 19, 2019 5:58 pm    Post subject: Re: Baja bug with 2.0 TDI CUAA diesel Reply with quote
Heading that way next week. Daughter getting married in gunnison. Thought pikes peak was kinda closed. Cog train out of comission. Road under const. But a charter coach would run you up the hill for 67$ a head. I picture a moose saying sorry folks, we're closed. Keep us posted. Not really looking foward to kansas.
My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779
neohic
neohic is offline
PostPosted: Wed Jun 19, 2019 6:36 pm    Post subject: Re: Baja bug with 2.0 TDI CUAA diesel Reply with quote
DANG!! I’ll be sure to stop by on the 28th.
-Ben
I like to build stuff...
syncrogreg
PostPosted: Fri Aug 23, 2019 8:39 am    Post subject: Re: Baja bug with 2.0 TDI CUAA diesel Reply with quote
About to install the fresh custom made 9lbs Flywheel onto the CUAA engine! Along with the 700HP sintered South bend clutch setup.
Note this powerful engine version has 8 bolts instead of the 6 all Other TDI have Smile
Will post some installed pics later tonight!
Greg
travel pictures:
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Fri Aug 23, 2019 9:00 am    Post subject: Re: Baja bug with 2.0 TDI CUAA diesel Reply with quote
The friction material on those clutch discs wear out the pressure plate & flywheel before the pucks do.
syncrogreg
PostPosted: Fri Aug 23, 2019 9:03 am    Post subject: Re: Baja bug with 2.0 TDI CUAA diesel Reply with quote
Yes this is why the flywheel has replaceable friction disc!
Greg
travel pictures:
syncrogreg
PostPosted: Fri Aug 23, 2019 4:53 pm    Post subject: Re: Baja bug with 2.0 TDI CUAA diesel Reply with quote
All went well torqued to spec with loctite 😅
Now it's time to assemble all that good stuff in the car!!
Greg
travel pictures:
syncrogreg
PostPosted: Thu Oct 10, 2019 1:57 pm    Post subject: Re: Baja bug with 2.0 TDI CUAA diesel Reply with quote
Having maxed out the other 150HP engine to 268BHP we are now moving to the 240HP engine (the most powerful 2.0 TDI ever made in production) and hoping to make 420BHP out of that one...
Anyway here is the beast before install!
Huge intercooler!
700hp clutch!
An fittings everywhere!
150MG IQ injectors 2500Bar injection pressure system
Cp4.2 V2 high output pump!!!
I have 2x type Turbos to test G25-550 and gtb2566vk
Fixed turbo
Vgt
Talk soon!
Greg
travel pictures:
syncrogreg
PostPosted: Wed Feb 26, 2020 9:21 am    Post subject: Re: Baja bug with 2.0 TDI CUAA diesel Reply with quote
Small update, the car is doing pretty amazing! the CUAA enigne is a beast and currently running a conservative tune with only 39PSI and 820C temps EGT'S
i was limited to put power due to spining the 450 FT-LBS clutch from Southbendclutch so they just sent me a 600 Ft-Lbs version! with that in place! ( hopefully today) i'll be able to use the 45PSI and 950C EGT tune @115 MG IQ
So im running the G25-550 from Garrett and it's solid!
the car does some low 7 runs on mild tune! im looking forward the 600 ft lbs clutch capabilities! probably be in the 6sec club Shocked
the beautiful 2.0 TDI EA288:
Favorite Pikes Peak Shot Wink
Talk soon
Greg
travel pictures:
syncrogreg
PostPosted: Fri Sep 04, 2020 11:28 am    Post subject: Re: Baja bug with 2.0 TDI CUAA diesel Reply with quote
travel pictures:
syncrogreg
PostPosted: Tue Jan 19, 2021 5:42 pm    Post subject: Re: Baja bug with 2.0 TDI CUAA diesel Reply with quote
Here is the video of the run!! only 1 second away from the world record diesel time of 11:24 we did a 11:25 ;-/ 2021 is going to be with a triple turbo !!!
Please subscribe to the youtube channel for more BUG content and PDK swap content as we just start to be active on our channel again!
Thanks
Greg
travel pictures:
