edhnb Samba Member
Joined: December 02, 2011 Posts: 288 Location: El Dorado Hills, California
Posted: Sat Jan 30, 2021 1:58 pm Post subject: 091 Transmission differential bearing |
I am changing out the oil seals in the trans and it appears one of my differential bearings is a bit loose. The other side is solid as Sears (or what Sears use to be).
Anyway, can someone take a look at this short video and all me if it warrants replacement?
https://youtu.be/LflZDv2RQWg
Thank you. _________________ 1977 Asi Riviera |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1244 Location: San Angelo, Texas
Posted: Sat Jan 30, 2021 3:38 pm Post subject: Re: 091 Transmission differential bearing |
Yes, it warrants replacement. Those bearings are actually preloaded. Should be no play in the bearing, actually the opposite _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42958 Location: at the beach in Northern Wokistan
Posted: Sat Jan 30, 2021 3:56 pm Post subject: Re: 091 Transmission differential bearing |
| rugblaster wrote: |
| Yes, it warrants replacement. Those bearings are actually preloaded. Should be no play in the bearing, actually the opposite |
rugblaster has lots of transmission experience. I'd go with his call. Normally the differential bearings have a slight amount of preload on them. Be sure to check the last before and after. Don't preload the bearings until the bell housing is on. You'll need a tool like this to hold the case properly with the bell housing removed.
| SGKent wrote: |
381/8 self-designed tool. It has to hold the transmission case pins tight together with no slop or free play.
VW factory approved tool
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
edhnb Samba Member
Posted: Sat Jan 30, 2021 7:06 pm Post subject: Re: 091 Transmission differential bearing |
I should have mentioned that this is with the bell housing off. Should I replace the bell housing and adjust the rings back to their position and then check the bearing before replacing it, or is it obvious the bearing is bad? _________________ 1977 Asi Riviera |
SGKent  Samba Member
Posted: Sat Jan 30, 2021 9:07 pm Post subject: Re: 091 Transmission differential bearing |
the bell housing should not come off until the preload is marked and reduced. Right side as I recall is the one to loosen. Best to buy Rick Long's CD on how to set up the preload with new bearings. You can't set the pre-load with nothing holding the case from spreading. Have to make that tool, and it has to be installed before taking measurents. If you have never set ring and pinion lash you may be getting in over your head. Just my 2 cents worth. _________________
George Carlin:
