Tom Mohr Samba Member
Posted: Fri Feb 12, 2021 10:21 am Post subject: Double cab passenger door pop out latch mount |
I've seen a lot of the doors with metal torn / deformed where latch mounts to the door.....what have people done to secure a repair to eliminate this from happening. It appears that the geometry of the latch closing puts pressure on this area tearing away the latch mount.
Thanks |
Braukuche Samba Member
Posted: Fri Feb 12, 2021 10:28 am Post subject: Re: Double cab passenger door pop out latch mount |
Tom Mohr wrote: |
Thanks |
I’ve only seen this on the long panel window behind the drivers seat. Not sure why.
You’d think the mounting point on the pop out frame would give before the mount on the body. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Fri Feb 12, 2021 7:53 pm Post subject: Re: Double cab passenger door pop out latch mount |
Is it because of how the driver realizes they are sweltering so they reach back there and manhandle it open at a traffic light- often out of anger?
I can't see this as being unique to double cabs in the slightest. But I sure can see it if it is consistently the windows directly behind the front seat(s). _________________
EverettB wrote: |
FU#5 |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10199 Location: Petaluma, CA
Posted: Sat Feb 13, 2021 8:55 am Post subject: Re: Double cab passenger door pop out latch mount |
hitest wrote: |
Yes, probably. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14274 Location: Casa de Oro, California
Posted: Sat Feb 13, 2021 6:48 pm Post subject: Re: Double cab passenger door pop out latch mount |
It seems like when that particular scoop window is popped there is an increased snap when the air hooks into it. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69832 Location: Phoenix Metro
Posted: Sat Feb 13, 2021 6:58 pm Post subject: Re: Double cab passenger door pop out latch mount |
campingbox wrote: |
hitest wrote: |
Yes, probably. |
My theory is it's the most opened window - it's only popout the driver can easily crack open
Increased wear + the welding of the mounting bracket sucks compared to some of the others and it snaps off. _________________ How to Post Photos
Posted: Wed Mar 31, 2021 1:35 pm Post subject: Re: Double cab passenger door pop out latch mount |
OK, I wasn't to clear about this so......let me try again. Repairing the latch mount area on my cargo/pass door.
What I started with.
Patched.
Triangle spacer held in place with tape.
What I'm trying to duplicate. Is that a spacer under window latch mounting point?
What I have mocked together.
I think the the base of the mounting points (door and window) need to be even to each other. Because if I hold the base down to triangle taped down and try to operate the latch, it won't close. (So does the spacer on window frame make the latch base flush with door base. The driver side bases are flush to each other.
Hope I have made this clear enough? |
Posted: Sun May 30, 2021 8:58 pm Post subject: Re: Double cab passenger door pop out latch mount |
Validated that there is a spacer (circled) on window side of the latch, to keep window side of the latch and door side of the latch on same plane.
Thanks gents ! |
Posted: Mon May 31, 2021 6:38 am Post subject: Re: Double cab passenger door pop out latch mount |
Very cool Everett, I'll be making that soon.
Thanks again! |
Matthew Tolbert Samba Member
Posted: Fri Aug 25, 2023 5:43 pm Post subject: Re: Double cab passenger door pop out latch mount |
EverettB wrote: |
Yes, here it is apart too, as we discussed earlier today
Anyone with originals able to measure the thickness of the spacer in the above photo? Mine are missing and I can make them I just need the thickness. From the earlier picture with it mounted it looks thicker than the threaded part that is welded to the frame. _________________ Matthew Tolbert
1958 ragtop
1961 doublecab
1965 Notchback S |
Posted: Fri Aug 25, 2023 7:41 pm Post subject: Re: Double cab passenger door pop out latch mount |
Matthew Tolbert wrote: |
EverettB wrote: |
Anyone with originals able to measure the thickness of the spacer in the above photo? Mine are missing and I can make them I just need the thickness. From the earlier picture with it mounted it looks thicker than the threaded part that is welded to the frame. |
A picture, a bit blurry, of the final product, I’m not near to give you the thickness, but you can see it’s close to 2X the threaded latch mount.
Posted: Sat Aug 26, 2023 6:06 pm Post subject: Re: Double cab passenger door pop out latch mount |
Tom Mohr wrote: |
EverettB wrote: |
Thanks Tom. I found a piece of metal today that’s around 4mm thick I’m going to make some out of to try. _________________ Matthew Tolbert
1958 ragtop
1961 doublecab
1965 Notchback S |
El Guero Samba Member
Joined: January 03, 2004 Posts: 1197 Location: I.E. Y-QUE
Posted: Wed Nov 29, 2023 3:49 pm Post subject: Re: Double cab passenger door pop out latch mount |
So my 60 dbl cab should only have that spacer on rear door window and not the other side? 🤔 _________________ Praise the Lowered... |
Posted: Wed Nov 29, 2023 3:56 pm Post subject: Re: Double cab passenger door pop out latch mount |
El Guero wrote: |
So my 60 dbl cab should only have that spacer on rear door window and not the other side? 🤔 |
Just on the door side, you are correct |
Posted: Wed Nov 29, 2023 3:57 pm Post subject: Re: Double cab passenger door pop out latch mount |
Ok. Thank you! _________________ Praise the Lowered... |
