Porsche 911 pulley ratio calculation
ottobevis
ottobevis is offline
PostPosted: Fri Mar 12, 2021 12:16 am    Post subject: Porsche 911 pulley ratio calculation Reply with quote
Hello,
I'm trying to understand how the commonly quoted ratios for 911 pulleys are calculated. I searched but could not find an explanation.
For example, 1965-74/75 use a 110mm crank pulley and 95mm alternator pulley. The ratio usually quoted for this is 1.3:1. When I calculate it (1/95*110) I get 1.16:1.
1980-89 uses a 120mm crank pulley and a 83mm alternator pulley. The ratio quoted is 1.67:1. The ratio I get is 1.45:1.
I'm assuming the measurements above are outside diameters. Is the difference due to using inside diameter measurements or using an average for the alternator diameter because of the spacers?
Otto
Starbucket
Starbucket is offline
PostPosted: Sat Mar 13, 2021 4:11 pm    Post subject: Re: Porsche 911 pulley ratio calculation Reply with quote
You use the middle diameters of the pulleys, calculate outer diameters then calculate inner diameters add the two together then divide by 2 and you will get their numbers.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Mar 13, 2021 4:16 pm    Post subject: Re: Porsche 911 pulley ratio calculation Reply with quote
Please use your original topic: https://www.thesamba.com/vw/forum/viewtopic.php?t=751300&highlight=
If you want it moved, PM me and i'll move it.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Porsche - 911/912/914 All times are Mountain Standard Time/Pacific Daylight Savings Time
