KlassicBus79 Samba Member
Joined: January 10, 2010 Posts: 121 Location: Nova Scotia
Posted: Thu Apr 25, 2013 12:47 pm Post subject: RPM idle drop when headlights on |
My idle is usually pretty steady at 900 rpm, but when I turn on the headlights it drops to about 800 rpm then fluctuates quite a bit.
Is this normal?
Some background I installed a new 55 amp alternator supposedly rewound for 70 amps. A new positive battery cable and a new 8 gauge wire run from the alternator to the battery as well.
The battery is good. It charges fine with my battery charger.
The headlights are the H4 headlight conversion with running lights (running lights not hooked up yet).
Looking for input. I will be mounting a voltage meter to the dash through the cigarette lighter from a suggestion I saw on here. _________________ 79 Cal Transporter 2L |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52824 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Apr 25, 2013 3:01 pm Post subject: |
A little drop when a load is added isn't too abnormal, get that volt meter and see what it says, maybe the regulator won't start charging until the system drops below battery voltage? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Apr 25, 2013 5:40 pm Post subject: |
So I figure the voltage at the dash is regulated. When I started it and let it idle I got 13.8 volts. Turned on the lights got 12.8 volts.
Went for a drive and while driving it went to about 13.2 no lights then 12.4 with lights.
Got back in the driveway and it was idling with 12.1 with lights and 12.8 with no lights. After about 5 min of idling without lights it went back to 13.1
I never did any voltage measurements before while driving, but I put in the new alternator because of the RPM drop I got when turning on the lights. _________________ 79 Cal Transporter 2L |
Posted: Thu Apr 25, 2013 6:46 pm Post subject: |
That's incredibly lame for a 70 AMP alternator, sounds like you got a dud  _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Mr spoons Samba Member
Posted: Thu Apr 25, 2013 7:24 pm Post subject: |
Quote: |
Got back in the driveway and it was idling with 12.1 with lights and 12.8 with no lights. After about 5 min of idling without lights it went back to 13.1 |
have you checked the voltage at the battery? maybe you have some resistance at the positive for the gauge. I have the same thing going on with my bus: 12.1 with lights on, but at the battery I have 13.4
guess I need to clean some grounds...  |
mnskmobi Samba Member
Joined: February 28, 2005 Posts: 536 Location: Melbourne, Australia
Posted: Thu Apr 25, 2013 8:38 pm Post subject: |
Sounds like the same problem JamesV74VW is having in another thread I just responded to. Here is my response:
mnskmobi wrote: |
JamesV74VW wrote: |
Hello,
...The alternator is functional, the voltage gauge is showing 13.5 but if the turn signal is on, the voltage gauge drops to 12 with every click of the light. ... |
A likely cause is corrosion in the wiring. Good places to start are the battery terminals, where the battery ground strap joins the body, the ground strap between the body and the gearbox (transmission), and the positive terminal on the solenoid. Take each of these apart and clean with a wire brush or sandpaper until you see bright metal, then reassemble and coat with an anti-corrosive coating such as a battery terminal protector.  |
Posted: Thu Apr 25, 2013 11:00 pm Post subject: |
The rpm drop is telling you the alternator is taking load, so I don't think there is necessarily anything wrong with the alternator. Are you running high wattage lights or extra bulbs which could increase the load on the alternator? You could use a clamp on ammeter to see what the actual load on the alternator is. If the load is normal, maybe tweaking the idle mixture screw a bit would keep the idle from dropping as much. |
Posted: Fri Apr 26, 2013 4:10 am Post subject: |
Going out this morning to do voltage checks right at the battery. Might even wire it up so I can see voltage right from the battery while driving. Last night was a just a quick check with a voltmeter wired to a cigarette lighter plug.
I did notice from the schematic that the heavy gauge red wire that attaches to the alternator is supposed to go to the starter. On my bus it goes right to the battery. Same point electrically just a different spot. I replaced that wire ( it had a cut in it from the tin where the grommet slipped off) when I installed the alternator and put on new lugs and dual wall heat shrink.
I routed it to the battery because I assumed it was going to the right spot. Didn't check Bentley mostly because it worked previously and I didn't want to get my Bentley all dirty with grease and grime.
I replaced the starter when I replaced the alternator and made sure all the wires and terminal lugs at the starter were cleaned or replaced.
Unfortunately I didn't count the wires or follow them back too far.
So now I have to check to see if the PO left an orphan wire on there.
Update
12.9 volts at the battery not running. 14.06 volts at the battery when started and at 950 rpm. 13.6 volts after a short drive and warm. _________________ 79 Cal Transporter 2L |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3625 Location: San Diego (Encinitas)
Posted: Fri Apr 26, 2013 9:24 am Post subject: |
Diet Pepsi King wrote: |
12.9 volts at the battery not running. 14.06 volts at the battery when started and at 950 rpm. 13.6 volts after a short drive and warm. |
Seems OK [regulator voltage is supposed to drop slightly with increasing temperature]. How about when the headlights are on? _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Sat Apr 27, 2013 6:56 am Post subject: |
This morning battery voltage no lights 12.6 with lights on 11.8
Started it and at 950 rpm 13.6 with lights on and 14 with lights off.
I also checked the starter terminals and I have 6 wires on there so there seems to be an extra one on there if I have the big red alternator wire going directly to the battery instead of the starter. Will have to do some more investigation. _________________ 79 Cal Transporter 2L |
Posted: Sat Apr 27, 2013 8:59 am Post subject: |
Sounds like everything is working properly, except that the lights seem to be pulling a lot of current.
Anything unusual about the lights?
If you can find a suitable meter (something that can measure upwards of 40 amps), I'd recommend measuring the alternator output with lights off and on.
One of those magnetic hold-it-near-the-wire type meters could work for this. _________________ '71 panel, now with FI
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42614 Location: at the beach
Posted: Sat Apr 27, 2013 11:13 am Post subject: |
It doesn't sound all that abnormal depending on how the engine is tuned as you are close to the cut off speed of the alternator. You might try tweaking the idle mixture a bit richer or leaner to see if the engine runs a little smoother when under load. Use a CO tester if you have access to one. If you have duals instead of FI, check the sync on the carbs. Very late buses with an automatic have an idle speed stabilizer on them that may need adjustment too.
I agree with Wildthings that the engine slowing shows that the alternator is taking the load. And as suggested, maybe there are larger amperage bulbs in the headlights. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
airkooledchris Samba Member
Posted: Sun Apr 28, 2013 9:46 am Post subject: |
How is the battery itself? I had the same issue as you and when I finally put in a new battery the behavior went away. |
Posted: Sun Apr 28, 2013 2:53 pm Post subject: |
My bus is a 79 California bus that has been switched to federal heater boxes, as far as I can tell the FI is mostly stock as the part numbers seem to match up, although there is no oxygen sensor (wire is still there and it is on my to do list).
I don't have access to a CO tester off hand.
The battery can possibly be changed out when Momma Bear decides that I can have some more money for the bus. Already spent my allowance for the spring
I also noticed that my rpm drop corresponds with both the lights and brake application when I come to a stop. I found that the lights have a voltage drop but the rpm doesn't fluctuate too badly and that the brakes don't affect it too bad by themselves either. It is when they are done together.
I bought some clamps for the rubber t where the brake booster hose goes to the intake plenum. Maybe there is an air leak there. _________________ 79 Cal Transporter 2L |
Posted: Sun Apr 28, 2013 3:00 pm Post subject: |
For what it's worth, I also run a 79CA with federal heater boxes, and with or without the sensor connected you won't see any difference in this behavior (I only disconnect mine when I hit the highway, connected while in town.)
not to say I think it's definitely the battery, it's just that the battery seemed to really make the difference in my case for RPM drops under electrical loads. |
Posted: Sun Apr 28, 2013 3:20 pm Post subject: |
I bought some clamps for the rubber t where the brake booster hose goes to the intake plenum. Maybe there is an air leak there. |
This new info is making it sound more like a brake booster problem. Try plugging the port for the breather on the plenum and see if the rpm drop goes away. Mamma bear just may have to let loose of a bit more dough.  |
Posted: Sun Apr 28, 2013 5:18 pm Post subject: |
I thought I would go over all the suggestions again in this post after I blocked the port and didn't see the big change in rpm I was expecting. The headlights still seem to be the main culprit. So I hooked everything back up and I installed the clamps on the hoses.
I decided the easiest and least expensive one to try for now was to adjust the idle mixture screw.
So here is the result; on about a 1/4 turn clockwise on the idle screw.
Idle smoothed out with not much of an increase in rpm (around 950) lights off.
Lights on with brakes applied idle dropped between 25 and 50 rpm, but was steady at that rpm with no fluctuation.
Short drive and every time I stopped it seemed a lot better.
I will drive it to work tomorrow and will let you know if this worked out.
Thanks for all the suggestions.  _________________ 79 Cal Transporter 2L |
Posted: Sun Apr 28, 2013 5:36 pm Post subject: |
Out of curiosity what does the idle speed do when you pump the brakes rapidly? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Apr 28, 2013 6:00 pm Post subject: |
When I pump the brakes rapidly (3-4 pumps per second) with headlights on or off it takes about 6 pumps to start making the rpm drop and after about 15 to 20 pumps it drops from steady idle of 950 to about 800. With the back hatch open I can even hear the change in the exhaust. _________________ 79 Cal Transporter 2L |
Posted: Sun Apr 28, 2013 6:48 pm Post subject: |
So that indicates a slightly lean idle, good......better than too rich but not an explanation for the electrical load drop.
What happens if you connect up to another car with booster cables?, leave the other car turned off and give the systems 5+ minutes of bus running to equalize before proceeding with the drop test. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
