Removing Front brake drum,wheel bearing won’t release come out??
59 dormi
59 dormi is offline
PostPosted: Thu Mar 11, 2021 1:04 pm    Post subject: Removing Front brake drum,wheel bearing won’t release come out?? Reply with quote
Has anyone had this issue before? I’m trying to remove the brake drum usually undo the lock nuts wiggle drum it pops out
This bus hasn’t been on the road in over 40 years the bearings roll like they were installed yesterday so I don’t want to destroy the bearings any ideas???
1959 Dormobile
Mini R53 bob the tomato
Range Rover L322
aa390392
aa390392 is offline
PostPosted: Thu Mar 11, 2021 1:32 pm    Post subject: Re: Removing Front brake drum,wheel bearing won’t release come out?? Reply with quote
How are you holding your mouth? Are you using the correct cuss words? Other than that I have no answers for you Laughing
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet
campingbox Premium Member
campingbox is offline
PostPosted: Thu Mar 11, 2021 1:57 pm    Post subject: Re: Removing Front brake drum,wheel bearing won’t release come out?? Reply with quote
Sometimes you need to back off the brake shoes.
59 dormi
59 dormi is offline
PostPosted: Thu Mar 11, 2021 5:10 pm    Post subject: Re: Removing Front brake drum,wheel bearing won’t release come out?? Reply with quote
Yep already swore at it
Shoes are backed off and the wheel spins freely I take the drum off with the wheel still attached
With the bearings being on there for so long it may be stuck to the spindle but how do I get it free without damaging the bearings or the spindle
1959 Dormobile
Range Rover L322
Lind
Lind is offline
PostPosted: Thu Mar 11, 2021 7:41 pm    Post subject: Re: Removing Front brake drum,wheel bearing won’t release come out?? Reply with quote
Drum puller?
Wanted:
59 dormi
59 dormi is offline
PostPosted: Thu Mar 11, 2021 10:33 pm    Post subject: Re: Removing Front brake drum,wheel bearing won’t release come out?? Reply with quote
Got it Very Happy so I did get the drum puller out but what I actually did was tap the rim from the back in four places (tap not pound) eventually it started to move off the spindle with the help of a little pb blaster and the bearings survived!
However is there not supposed to be a dust seal on the inner bearing ?
Sorry I lent out the Bentley a few years ago and it hasn’t returned so I’m trying to go off memory Confused
1959 Dormobile
Range Rover L322
ToolBox
ToolBox is offline
PostPosted: Fri Mar 12, 2021 11:33 am    Post subject: Re: Removing Front brake drum,wheel bearing won�t release come out?? Reply with quote
Sorry I lent out the Bentley a few years ago and it hasn�t returned so I�m trying to go off memory Confused
Did the bearing stay on the spindle? The grease seal presses onto the drum and will be behind the bearing if it is still on the spindle.
59 dormi
59 dormi is offline
PostPosted: Fri Mar 12, 2021 5:19 pm    Post subject: Re: Removing Front brake drum,wheel bearing won’t release come out?? Reply with quote
Yes the inner bearing stayed on the spindle once the drum came off ,but there’s no dust seal on the drum seems odd I’m pretty sure 66 had a seal there but these earlier bus I don’t know
1959 Dormobile
Range Rover L322
Busted-bolt
Busted-bolt is offline
PostPosted: Fri Mar 12, 2021 5:51 pm    Post subject: Re: Removing Front brake drum,wheel bearing won’t release come out?? Reply with quote
It is probably still on the spindle behind the bearing, if the bearing is still on the spindle. You will still have to get the bearing of the spindle to properly re install the bearing and then the seal in the Drum before reassembly.
Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
I do all my own work,body,engine and transmission.
59 dormi
59 dormi is offline
PostPosted: Fri Mar 12, 2021 6:05 pm    Post subject: Re: Removing Front brake drum,wheel bearing won’t release come out?? Reply with quote
Inner bearing is off the spindle now there’s no sign of a seal to be found so I’m guessing someone has just put this together so it would roll at some point...there were no linings left on the shoes ether
1959 Dormobile
Range Rover L322
Busted-bolt
PostPosted: Fri Mar 12, 2021 10:17 pm    Post subject: Re: Removing Front brake drum,wheel bearing won’t release come out?? Reply with quote
Yes You are probably right, the brake shoes linings usually just fall off when a stuck drum is removed. Be sure that the spacer is still there on the spindle behind the bearing when re assembling. If the bearing was exposed to moisture because of the seal being gone it could have rusted. Even a small amount of rust can be detrimental to a bearing surface so an intensive cleaning and inspection is recommended .
Stocknazi
Stocknazi is offline
PostPosted: Tue Jun 03, 2025 8:52 am    Post subject: Re: Removing Front brake drum,wheel bearing won�t release come out?? Reply with quote
Most front drums seem to retain the inner bearing/seal as they are removed; assuming from years of on/off wear.
Should the inner bearing (55-63) stay pressed on the spindle when you remove the drum, pulling itself and the dust seal out as the drum is removed???
The Bently mentions having to pull off the inner bearing and checking the spindle races for wear, so I assume the inner race of the inner bearing should be a snug fit on the spindle?
I prefer the bearing/seal to come off with the drum as it creates more of a grease mess to pull the inner bearing off the spindle each time you remove the drum. Add to that the extra risk of bearing contamination. The lock plates work well, but are consumables. However, if you have 64-67 spindles, the bay window Porsche style lock nuts work more better. They really make bearing adjustment a breeze.
WANTED:
Thomas Jefferson
pom2ter
pom2ter is offline
PostPosted: Fri Jun 06, 2025 1:44 am    Post subject: Re: Removing Front brake drum,wheel bearing won’t release come out?? Reply with quote
maybe you can put the wheel on the brake drum and it will help to remove ... have same issue
Stocknazi
PostPosted: Mon Jun 09, 2025 8:27 am    Post subject: Re: Removing Front brake drum,wheel bearing won’t release come out?? Reply with quote
Ni issue at all getting the drum loose as I have the adjusters backed off. The inner wheel bearing (and early felt seal) stays pressed on the spindle when I remove the drum. Most front drums will pull off by hand with the inner bearing/seal still inside the race.
I was asking if this was OK or should the inner bearing race be such a tight fit to the spindle race to require a puller to remove???
WANTED:
Thomas Jefferson
timjames722
timjames722 is offline
PostPosted: Mon Jun 09, 2025 11:35 am    Post subject: Re: Removing Front brake drum,wheel bearing won’t release come out?? Reply with quote
This just happened to a friend of mine. We had to cut the bearing off.. we found a lip on the spindle holding it in place.
66 SO42 L87
What's the point in callin shots? This cue ain't straight in line.
