Alstrup Samba Member
Joined: July 12, 2007 Posts: 7976 Location: Videbaek Denmark
Posted: Sat Mar 20, 2021 2:34 pm Post subject: Optical difference between HPMX gen I & II? |
As header.
Can annyone tell the difference by looking at them? I was never much into these carbs in the first place, so i do not remember the optical differences, if there are any.
Thanks _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
DeathBySnuSnu Samba Member
Posted: Sat Mar 20, 2021 2:55 pm Post subject: Re: Optical difference between HPMX gen I & II? |
My first gens had the enrichment pistons and springs with the blank off plate.
The newer ones I have seen (not owned) do not have any of the enrichment circuit or block off plate at all....never cast in or machined.
I think that is where gen 2 came in.....at the die re-tool. _________________
| modok wrote: |
| And look at the SHAPE of the curves, just smooth, like gods own slingshot. . |
Joined: May 17, 2003 Posts: 4877 Location: Harmony, PA
Posted: Sat Mar 20, 2021 10:12 pm Post subject: Re: Optical difference between HPMX gen I & II? |
| Gen 1, and 2 aren’t much different. It wasn’t till the 3rd gen did they start the solid enrichment circuit with the 4 progression holes. Then the 4th gen had the idle jet vent tubes. |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4368 Location: Los Angeles, CA 90016
Posted: Sun Mar 21, 2021 8:15 am Post subject: Re: Optical difference between HPMX gen I & II? |
Yes. Gen I and II both had plates. Gen I had some faulty screw-in pieces that could be remedied by swapping with Weber parts. Gen II fixed those issues. Gen III eliminated the enrichment circiut with a cast-in boss. I've had good luck with Gen IIIs. Gen IV has jet doctors and another progression port. I've used one set. They're just as good. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
