johnbrunt Samba Member
Joined: May 16, 2020 Posts: 16 Location: lancashire, UK
Posted: Tue Mar 30, 2021 6:31 am Post subject: electrical help |
i have a single stalk indicator assembly which has the following functionality
up / down - left right turn
pull - dip / main beam
i have the following coloured wires connected as follows
brown / white - connected to lighting relay
brown - earth
black / white - indicator
black / green - indicator
black / white / green - indicator relay
black / grey - not connected
white - not connected
my question revolves around the three unconnected wires - what are they for as by having all the other wires connected as detailed everything works as intended.
i’m not sure what year this stalk is off but it’s on the shorter indicator / ignition switch assembly - the unconnected wires aren’t part of the ignition system as again these are all wired up as they should be.
thanks in advance |
Murmsk Samba Member
Joined: February 24, 2019 Posts: 368 Location: Illinois
Posted: Tue Mar 30, 2021 6:36 am Post subject: Re: electrical help |
I believe the newer switches have extra wires that go unused.
S _________________ 1970 Convertible
1972 super
1946 Willys Jeep |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16791 Location: North Florida, USA
Posted: Tue Mar 30, 2021 6:47 am Post subject: Re: electrical help |
In some European countries cars require an extra lamp during turns. From my understanding these do not flash so are connected to a constant power source like the ignition circuit and power an extra set of lights on the L and R. I’m not certain if they are meant to light up the roadside on the turning side of the car, or just as indicators? Those three extra wires are for that system which is not used in most countries. The aftermarket turn switch assemblies include the extra wires so a single turn signal switch can be used in all countries. VW probably had two different part#s.
Just loop them up and tuck them away. If your main turn signal switch ever fails, you can make use of them as a spare turn signal switch cricuit. Just check if they are the same wire gauge. The ones I have seen are a smaller wire and may not carry the current load for two 21W bulbs. LEDs lamps in the front or rear may be needed to reduce the current load if you use these as a spare turn signal circuit.
If your turn signal switch assembly has loose wires (not in a plastic tray) and has a large brass contact(s) on the face of the switch for horn contact ring on the bottom of the steering wheel... it is a ‘71 Beetle turn signal switch. The ‘70-earlier switch did not have the brass horn contact on the switch. The ‘72-later switches were for cars that had the turn signal and wiper switches on the steering column. The wires were laid in plastic trays and used two plugs at the bottom of the steering column housing. _________________ AshMan40
raydog Samba Member
Joined: February 09, 2006 Posts: 1208 Location: Cape Cod
Posted: Tue Mar 30, 2021 6:52 am Post subject: Re: electrical help |
I think the unused wires you have are for the European market which requires the roadside parking lamps.
Ashman beat me to it. _________________ Come on, It's not rocket science. KISS |
Posted: Tue Mar 30, 2021 7:13 am Post subject: Re: electrical help |
| raydog wrote: |
Ashman beat me to it. |
ok i’ll just tidy them out the way.....
just wanted to eliminate them and ensure they weren’t anything to do with the horn....which i need to resolve the |
Posted: Tue Mar 30, 2021 9:00 am Post subject: Re: electrical help |
| johnbrunt wrote: |
You didn't mention having the horn wire in your turn signal switch wires? This is a 3rd brown wire.
If your turn signal switch does not have the brass contact(s) on the face of the switch it is likely a '68-'70 Beetle turn signal switch. Between '68-'70 the horn circuit ran thru the upper steering column bearing instead of the turn signal switch and made the steering wheel shaft and the steering wheel part of the horn (-) circuit.
Find the brown wire coming from the horn (-) terminal and trace it into the steering column housing. For the '68-'70 steering column, it should end at the upper steering column bearing:
You can see the OD of the bearing is insulated from the steering column housing while the ID has metal contacts to pass current from the horn to the steering column shaft and eventually the steering wheel itself.
If you have this arrangement you should have a ground wire coming out of the center of the steering shaft that connects to the horn button. When you press on the horn button/ring you bring the ground wire into contact with the steering wheel which closes the path to ground for the horn (-) terminal.... "BEEEP"  _________________ AshMan40
