73 Sunroof Parts
Page: Previous  1, 2
SGKent Premium Member
SGKent is offline
PostPosted: Thu Apr 07, 2022 9:29 pm    Post subject: Re: 73 Sunroof Parts Reply with quote
that is good someone is finally making them. The fellow in MI is also selling the center part made from aviation plastic. EIS makes many of the parts but they do not show the center piece on their website. Maybe ISP had them made. A lot of people out there need them.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Redwall
Redwall is offline
PostPosted: Sun Feb 26, 2023 12:46 pm    Post subject: Re: 73 Sunroof Parts Reply with quote
I'm looking for the left and right rear guides and one adjustment screw. Somebody stole them off my 71 bus years ago. I'm talking about the metal brackets that attach to the sunroof and slide through the track. Does anyone know where I can find them? Coming up with nothing on the web. Thanks
SGKent is offline
PostPosted: Sun Feb 26, 2023 1:43 pm    Post subject: Re: 73 Sunroof Parts Reply with quote
there is the cable that has the lifting blocks on it that slides thru the tracks.
busdaddy
busdaddy is offline
PostPosted: Sun Feb 26, 2023 2:53 pm    Post subject: Re: 73 Sunroof Parts Reply with quote
I think they are talking about 27 or 28, the arm/bracket that carries the roof when it's sliding in the track.
Слава Україні!
creative native Premium Member
creative native is offline
PostPosted: Sun Feb 26, 2023 4:17 pm    Post subject: Re: 73 Sunroof Parts Reply with quote
busdaddy wrote:
To each their own, I look at a functional sunroof as a badge of honor, or perseverance, or maybe just not being smart enough to leave things alone. It gives me something to fiddle with when all the other issues on the bus are fixed too. They do work well when set up and maintained properly, but don't go rolling it back and forth 100 times to show off at a Saturday meet, consider it a limited cycle part and use it sparingly.
I agree, Mark! I suppose I was lucky when I owned my 1979 sunroof Bus 20 years ago. It worked flawlessly. One disadvantage I noticed when I used to own a 1966 21 window was that I'd have to get out of the driver's seat to operate the sunroof, but with the '79, it was convenient to operate it from the driver's seat.
About my Sun Bug, when I got it, the sunroof worked ok, but after the upholstery shop restored the interior, the sunroof was stuck in the closed position and it took TWO YEARS to find someone to fix it. It was really bringing me down, but as you said, it was a badge of honor to have a perfectly functioning sunroof and I was determined to have it repaired. I watched my upholstery buddy do most of the work on the sunroof, so I could learn. Now that it works as new, it was all worth it.
If there's anything I've learned about owning ACVWs over the past 30+ years, it is to not let NLA parts discourage me. It seems sooner or later, someone will reproduce parts. Especially now that Bay Windows are getting the recognition they've always deserved, I expect more parts will become available for them.
https://www.thesamba.com/vw/archives/manuals/1969b...Manual.pdf
https://www.jbugs.com/product/241877300.html?utm_c...I4EALw_wcB
https://www.westcoastmetric.com/c-1183256-vw-late-bus-1970-vw-bus-exterior-sunroof-seals-parts.html
"The holy land is everywhere." ~ Black Elk
1979 Westfalia P27, California FI emissions spec. 100% VW fleet: '79 Westfalia, 2013 Touareg Lux (Toffee Brown/Cornsilk Beige), 2005 Passat GLX.
Redwall
Redwall is offline
PostPosted: Tue Feb 28, 2023 10:07 pm    Post subject: Re: 73 Sunroof Parts Reply with quote
Busdaddy is right, I'm talking about #27,#28 (rear) in that diagram. They ride along the track. I can't find the left or right ones anywhere. I was considering forging them myself, but I don't have a sample. Oh where oh where can one be found? Any clues out there?
SGKent is offline
PostPosted: Tue Feb 28, 2023 11:22 pm    Post subject: Re: 73 Sunroof Parts Reply with quote
Ask Ken Madson at TheBusco or Avery's air cooled. You don't want to try to make one, The also have nylon feet on them.
Redwall
Redwall is offline
PostPosted: Thu Mar 02, 2023 11:54 pm    Post subject: Re: 73 Sunroof Parts Reply with quote
Ken Madson at TheBusco sent me this helpful diagram. Thank you. I'm looking for two of #18 and one of #11. Does anybody know where I can find these parts?
[/img]
SGKent is offline
PostPosted: Fri Mar 03, 2023 12:10 am    Post subject: Re: 73 Sunroof Parts Reply with quote
I take it neither Ken nor Avery's had the part?
busdaddy
busdaddy is offline
PostPosted: Fri Mar 03, 2023 9:13 am    Post subject: Re: 73 Sunroof Parts Reply with quote
Some of those parts are shared with Beetle and type 3, I can't suggest where to start looking, but don't go thinking everything is "bus only".
Слава Україні!
SGKent is offline
PostPosted: Fri Mar 03, 2023 11:00 am    Post subject: Re: 73 Sunroof Parts Reply with quote
If Ken at TheBusco, or Avery's Air Cooled does not have those parts, try Joe at Busted Bus or Chris Morrice in Oakland. He is always parting buses out. https://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=19586
Reproductions can be found because BusOk makes them. Part number 241-877-541. You need 2. https://www.bus-ok.de/Type2-bay-rear-sliding-roof-bracket-867-7-79-OEM-partnr-241877541 Bus-Ok also makes the front ones.
Bugster78
Bugster78 is offline
PostPosted: Tue Mar 26, 2024 2:11 pm    Post subject: Re: 73 Sunroof Parts Reply with quote
I am rebuilding a sunroof to as functioning as I can get. The PO had stripped all of the cables and the guides. I sourced a new gear, the plastic covers and the cable guid the gear inserts in, but could not find the front cable guides that route the cables from the gear cog around the front corners to the rails….so I made my own out of 1/4 inch brake line, bent around a 4 inch diameter bending form. The replacement cables do fit inside. Not functional yet, but figured I’d share in case others had alternative solutions.
Page: Previous  1, 2
Page 2 of 2
