*** Updated 2021 FAQ ***
Brian
Brian is offline
PostPosted: Wed Mar 31, 2021 11:41 pm    Post subject: *** Updated 2021 FAQ *** Reply with quote
See below for the updated FAQ for this year. Note that this is all user generated content and is not actual advice. More so guidelines.
How to close and lock 1968-1973 vw bus sliding door from inside
How to open and close your oem bus antenna
How to remove your front floor mat and how to install front mat
How to add a auto drive feature or 10mph or less in 1st gear
How to lock your 1968 to 1973 volkswagen bus
How to repair your vw busses ignition switch video
How to install new mirrors on your baywindow bus 1968-1979
how to install the front seats into your 1968-75 volkswagen bus
How to fix that old canvas or vinyl in your bus
how to check a used oil cooler to see if it works before install
Best way to get the snow off your westy
How to remove your 1969-72 vw bus headbanger cabinet
How to install a new engine seal in your 1968, 1969, 1970, 1
How to install a clutch on a 1600 motor for your bus
How to remove your muffler on your 1968, 1969, 1970, 1971 vw
How to replace a cv boot on a 1968,1969-1979 vw bus
How to install the crossbar mustache bar onto your beetle mo
How to install alternator wiring in your 1969 bus
How to remove a stuck stud how to change your tire on a 1969
How to install a 1600 dp motor into a 1969, 1970, 1971 bus
How to keep the snow off your bus in the winter time
How to adjust the brakes on your 1968,1969,1970 bus"
How to adjust the brakes stars on your 1964-1968, 1969, 1970
how to insulate your vw bus
How to make front door panels for your bus
how ot rebuild your rear brakes on a 65-76 bus
how to make a cargo door and rear hatch interior panel
how to remove the motor from your 1969 vw bus
How to install starter on 1968 ,1969, 1970, 1971 vw bus
How to install an inlet (i'd say outlet) into a camper
How to install a speedometer cable in your 1968-1979 bay bus
how to install your headliner in your 1968, 69, 70, 71 vw westfa
How to install you potop canvas in your 1968-72 vw bus
how to install a crankstart on a 1600 motor
how to remove your old poptop tent or canvas in a 1968-1973
how to replace your wiper arm on your vw bus
how to clean your mustard vinyl and where to put roof trims
How to remove a rusted on 68-71 vw bus rear bumper
how to straighten your busses bumper
how to install an engine mount adapter to fit a 1200-1600 motor
How do you repaint the bottem of the bus
How to remove a 1600 motor out of a 1968 vw bus
Drive education How to roll start your vw bus
how to replace your busses ground strap
Hw to change the oil on a stock 1700cc 1972 vw bus engine
How to replace your fuel sending unit in your baywindow bus
How to replace the front door handle on your vw bus
How to fix a loose or missing rear engine stud
How to close a 1968-1973 vw bus sliding door
How to clean your Buses seats
How to change the oil in a 1973-75 vw bus 1800 engine
How to roll start backwards
how to install a crossbar support on your 1600 to install in bus
How to install the original 38 amp generator on a vw bus
What is the difference between a 1600 single port and dual port
How to fix your VW Bus ignition switch module
how to use the busses campstove
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Hobdar
Hobdar is offline
PostPosted: Wed May 29, 2024 5:47 pm    Post subject: Re: *** Updated 2021 FAQ *** Reply with quote
Hi - is there any guidance on double cabs? And what parts are similar to the Bus?
PostPosted: Wed May 29, 2024 8:41 pm    Post subject: Re: *** Updated 2021 FAQ *** Reply with quote
Most parts are the same unless it's something Double Cab specific like parts for the gates.
I found this one old thread with some details:
https://www.thesamba.com/vw/forum/viewtopic.php?t=146455
There maybe others but it might take some searching through lots of threads with either Double Cab or Crew Cab or maybe Truck in the title.
Do a title only search in this section.
Double Cab threads
https://www.thesamba.com/vw/forum/search.php?searc...=titleonly
