66 dormi Samba Member
Joined: September 06, 2006 Posts: 611 Location: Ontario Canada
Posted: Sat Apr 06, 2024 8:20 am Post subject: Steering issues 59 vs 66 steering need some help |
So I’ve owned two 66 buses that were easily steerable at 65 mph and prior to repairs 55 mph with ease
The 66 model year came with a sway bar
I now have a 59 build bus that can’t be steered with confidence over 50 mph it seemed to be happy at 45?? Now anything can be fixed but what am I missing do I need that sway bar throwing money at things doesn’t fix it so need some help
Is it the steering box? I can take the play out of it to zero so not sure
I have standard new shocks not the kyb gas adjust brand that I normally get
Quite frankly I’ve never been scared driving a bus and I’ve been driving them for over thirty years now
The bus
59 panel 1600 sp 64 big nut trans
What’s been done so far
New drag link
New tie rods
Steering dampener
New shocks
Link pins adjusted
No up down play in the centre pin lever thingy that’s on the beam (yeah I forgot what its called)
8 ply bus tires
No slop no play
I’m working on adjusting the steering box for the 10 th time but with zero play however the box is tight and hard to turn so will have to back it up a little and introduce some play _________________ DORMOBILE TOP WANTED!!!!
1978 westy daily driver
1960 panel camper project
Mini R53 bob the tomato |
![](/vw/forum/templates/subSilver/images/spacer.gif) |
Lind Samba Member
![](/vw/forum/images/avatars/76892526262ca11952718d.jpg)
Joined: November 06, 2000 Posts: 9976 Location: idaho
Posted: Sat Apr 06, 2024 9:27 am Post subject: Re: Steering issues 59 vs 66 steering need some help |
The anti-sway bar mostly helps in cornering, although it also helps reduce the inherit oversteer in crosswinds that buses have. If you are experiencing instability at speed, then something else is wrong.
The adjustment screw on the steering box is almost always not needed, and usually will just trash on your steering box by over-tightening it.
Are your wheels straight and properly balanced? Jack the bus up and spin the front wheel by hand.
Is there excessive play at the steering wheel? _________________ .
Wanted:
Posted: Sat Apr 06, 2024 10:29 am Post subject: Re: Steering issues 59 vs 66 steering need some help |
Yeah I think something is off but I’ve just run out of ideas and things to replace that are worn out hence the sway bar inquiry…. I’m jacking the front end up now to take the stress off the steering box from turning it to zero play and will report back _________________ DORMOBILE TOP WANTED!!!!
Eric&Barb Samba Member
![](/vw/forum/images/avatars/447962345514521c5abe42.jpg)
Joined: September 19, 2004 Posts: 24905 Location: Olympia Wash Rinse & Repeat
Posted: Sat Apr 06, 2024 12:27 pm Post subject: Re: Steering issues 59 vs 66 steering need some help |
Check toe in one more time. _________________ In Stereo, Where Available! |
Posted: Sat Apr 06, 2024 3:46 pm Post subject: Re: Steering issues 59 vs 66 steering need some help |
Ok with the wheels of the ground reset the steering box back 1/4 turn just so there’s a bit of drag at centre pulled all the grease fittings cleaned and checked them the one on the swing lever? was plugged and not taking grease so I did all of them… beam fully greased steering checked I got one inch play with the bus on the ground just like my 78 bus
Wheels are straight steering wheel is straight wheels have been balanced however I did note a flat spot from sitting all winter (smoothed out after the tires warmed up)
I don’t t have the Bentley handy it still hasn’t returned from lending it out so unfortunately I don’t have the toe in measurements if you got yours handy that would be awesome!
Test drive hands off at 40 no problem on a smooth surface 50 is doable and with some more time in it 55 could be a possibility but after that it in a crosswind it’s too unpredictable
On the country roads which are basically paved gravel very uneven I get bump steer and life is easy at 45 after that it’s a work out
Brake lights are stuck on and the starter bushing failed …crank starting sucks ah it never ends _________________ DORMOBILE TOP WANTED!!!!
Posted: Sat Apr 06, 2024 5:25 pm Post subject: Re: Steering issues 59 vs 66 steering need some help |
Page 158, section 15 of the other type 2 manual on thesamba:
https://www.thesamba.com/vw/archives/manuals/type2...manual.pdf
That and a lot more thru the "Technical" button at top right of thesamba webpages.
Personally prefer to measure on the rims for more precise measurement than trying to get same reading off the tires themselves. _________________ In Stereo, Where Available! |
Posted: Sat Apr 06, 2024 5:32 pm Post subject: Re: Steering issues 59 vs 66 steering need some help |
Thank you! Looks like I got some measuring to do! _________________ DORMOBILE TOP WANTED!!!!
Mile High Puma Samba Member
![](/vw/forum/images/avatars/183336649050e08e24ad920.jpg)
Joined: November 11, 2009 Posts: 214 Location: Salida, Colorado
Posted: Sat Apr 06, 2024 8:25 pm Post subject: Re: Steering issues 59 vs 66 steering need some help |
What about the rubber spring plate doughnuts? I think those often get overlooked and deform over time affecting the rear toe. _________________ 1965 Velvet Green DC |
Clara ![Premium Member Premium Member](./templates/subSilver/images/lang_english/icon_star.gif) Samba Member
![](/vw/forum/images/avatars/12841212955f430732772fc.jpg)
Posted: Sat Apr 06, 2024 9:20 pm Post subject: Re: Steering issues 59 vs 66 steering need some help |
Pickup your Muir book and turn to shimmies and shakes
Have a friend Wiggle the steering wheel while you are under the bus and look for play.
Do the other diagnostics as well
Sloppy tie rods etc add up
You may have more than one worn part
My 56 had a quarter turn of the steering wheels of slop when we got it
Old crappy tires also are a thing. Crack?
Also, How’s the tire pressure?
Bump steer sounds like a worn dampner. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Sun Apr 07, 2024 8:49 am Post subject: Re: Steering issues 59 vs 66 steering need some help |
Clara wrote: |
Bump steer sounds like a worn dampner. |
Tires a new same with drag link tie rods steering dampener I’ve got the box set up now
30 psi up front
40 psi rear
I just did the muir book checklist looks like I got my camber set up messed up I will need to get shims
I do not have the gauge they are referring to in the archive book to set toe in up somewhere there’s a string method but I can’t remember where I seen that so what’s the measurement between the front wheels supposed to be set at
This is a first for me never had one this bad learning as I go thanks for your patience _________________ DORMOBILE TOP WANTED!!!!
nlorntson Crazy VW Lady
![](/vw/forum/images/avatars/274725357556602144af90.jpg)
Joined: March 13, 2004 Posts: 3802 Location: Twin Cities, MN
Posted: Sun Apr 07, 2024 9:00 am Post subject: Re: Steering issues 59 vs 66 steering need some help |
Also check the play at the output shaft on the steering gear |
chrisflstf Samba Member
![](/vw/forum/images/avatars/97752708445d3c78b9eb3e.jpg)
Joined: February 10, 2004 Posts: 3502 Location: San Diego
Posted: Sun Apr 07, 2024 9:07 am Post subject: Re: Steering issues 59 vs 66 steering need some help |
You can check toe in with a tape measure. Measure the tread width at the front, compare to the rear. 1/16 to 1/8 inch is good |
Posted: Sun Apr 07, 2024 9:14 am Post subject: Re: Steering issues 59 vs 66 steering need some help |
String/rope stretches, which is why land surveyors used metal chains as far back as the 1700s.
Better to use two pieces of thin wood like 1" by 1", or even bamboo and a pencil to mark the wood. _________________ In Stereo, Where Available! |
Posted: Sun Apr 07, 2024 9:20 am Post subject: Re: Steering issues 59 vs 66 steering need some help |
nlorntson wrote: |
Good idea, also the pitman arm is tight to the shaft. Had one found loose, needed a non-stock shim added to press the arm tight to the shaft taper. _________________ In Stereo, Where Available! |
Joey Samba Member
![](/vw/forum/images/avatars/4496086975df04dd87ac5e.jpg)
Joined: August 12, 2005 Posts: 5371 Location: Nova Scotia - Canada
Posted: Tue Apr 09, 2024 9:38 am Post subject: Re: Steering issues 59 vs 66 steering need some help |
I find the new steering dampners too stiff and don’t allow the steering to return to centre easily. I don’t run them on any of my VWs. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
BulliBill Samba Member
![](/vw/forum/images/avatars/135726568249dcd284c3ce5.jpg)
Joined: July 09, 2004 Posts: 4590 Location: St Charles, MO
Posted: Fri Apr 12, 2024 6:36 am Post subject: Re: Steering issues 59 vs 66 steering need some help |
I'm grateful to be lucky enough to have bought the VW dealership tool for checking/adjusting toe-out/toe-in decades ago.
But before scoring that cool tool, I used two wooden yard sticks sliding against each other. Didn't the Muir "Idiot Book" show how to use a pair of yardsticks to adjust/set toe-in?
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Posted: Fri Apr 12, 2024 7:16 am Post subject: Re: Steering issues 59 vs 66 steering need some help |
Park on a flat surface.
Put a piece of duct tape on the rear face of each front tire
Make a dot on the tape.
Measure the distance between the dots.
Roll the bus forward so the dots are now in the front.
Measure between the dots again.
This will show toe in or toe out. Adjust as necessary. |
BarryL ![Premium Member Premium Member](./templates/subSilver/images/lang_english/icon_star.gif) Samba Member
![](/vw/forum/images/avatars/1835978701653d492c328a4.png)
Joined: November 01, 2004 Posts: 14376 Location: Casa de Oro, California
Posted: Fri Apr 12, 2024 6:16 pm Post subject: Re: Steering issues 59 vs 66 steering need some help |
What are the chains for? |
Posted: Sat Apr 13, 2024 7:29 am Post subject: Re: Steering issues 59 vs 66 steering need some help |
66 dormi wrote: |
This is a first for me never had one this bad learning as I go thanks for your patience |
Toe in is 1/8”.
I use a pair of yard sticks to measure this. I measure at the edge of the rim, not the tire
(Btw, there are step by step directions in Muir’s book)
Toe needs to be set if the tie rods were off or changed.
Did you have the knuckles off? When they are off, that’s when you check offset and put the shims in the right place. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Thu Apr 18, 2024 6:27 pm Post subject: Re: Steering issues 59 vs 66 steering need some help |
Thank you yes I have way too much toe in so will adjust that and report back dealing with a new master cylinder issue for the third time first before I can drive it again
Bullibill that’s a really neat tool by the way!! _________________ DORMOBILE TOP WANTED!!!!
