1967 door/ignition key
theduck
theduck is offline
PostPosted: Mon May 03, 2021 10:00 pm    Post subject: 1967 door/ignition key Reply with quote
Shocked Hello all.Say I am in the process of making my door key fit my ignition.I can not locate a video I seen on this forum. That explains how to re-key both items(door ,ig,switch).Does anyone recall this video,or have other videos ,on "How DIY". Thx all theduck. Cool
ashman40
ashman40 is offline
PostPosted: Mon May 03, 2021 10:13 pm    Post subject: Re: 1967 door/ignition key Reply with quote
Hopefully you have the original '67 K-code ignition switch? The aftermarket replacement ignition switches for Beetles ~'67 often use a single cut key common on pre-'67 ignitions. This key is not the same key shape as the door keys.
Here is a quote from an article on the 1967Beetle.com site:
The 1967 Beetle (US Spec), when new, came with One Key that would open both Doors and operate the Ignition. This new-for-1967 Key has a Profile name of “K”. It has cuts on both edges, something new for the 1967 Beetle. Previous years have cuts only on one edge
See the pics in the article and you will understand if your ignition switch has the correct key type.
AshMan40
theduck
theduck is offline
PostPosted: Mon May 03, 2021 10:18 pm    Post subject: Re: 1967 door/ignition key Reply with quote
Shocked Hello,my ignition is a different key.I located on this forum,last night how to re-key your door and ignition key to be one key only.I just can't locate it.I am trying different topic words but no luck
theduck
theduck is offline
PostPosted: Mon May 03, 2021 10:38 pm    Post subject: Re: 1967 door/ignition key Reply with quote
Cool Hello ,Found the video I need !! THX ALL,theduck Cool
ashman40
ashman40 is offline
PostPosted: Tue May 04, 2021 5:39 am    Post subject: Re: 1967 door/ignition key Reply with quote
Great! Why not post the link here so the next person looking for how to do it can find it?
AshMan40
aa390392
aa390392 is offline
PostPosted: Tue May 04, 2021 7:24 am    Post subject: Re: 1967 door/ignition key Reply with quote
^^^^^^^^^^^^^what he said^^^^^^^^^
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet
theduck
theduck is offline
PostPosted: Tue May 04, 2021 10:51 pm    Post subject: Re: 1967 door/ignition key Reply with quote
Very Happy I found the link on Georgia dubs. Someone else had posted it.And I just happen to recall it.So check it out.Hope this helps.theduck Shocked
-lecroix-
-lecroix- is offline
PostPosted: Mon Jun 16, 2025 11:35 am    Post subject: Re: 1967 door/ignition key Reply with quote
sure wish you had posted that link as suggested ... 4 years later Crying or Very sad
MrGoodtunes
MrGoodtunes is offline
PostPosted: Mon Jun 16, 2025 1:09 pm    Post subject: Re: 1967 door/ignition key Reply with quote
-lecroix- wrote:
... wish you had posted that link ...
Can't help with the video link, but there's an excellent re-key tutorial right here on theSamba:
https://www.thesamba.com/vw/forum/viewtopic.php?t=456974
-lecroix-
PostPosted: Mon Jun 16, 2025 1:40 pm    Post subject: Re: 1967 door/ignition key Reply with quote
Awesome! Thanks for helping out a "new guy" ... much appreciatted! Thumbs Up
