evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Fri May 21, 2021 10:44 am Post subject: Re: New engine build backfiring out both carbs and exhaust. HELP! |
mark tucker wrote: |
bent throttel shafts? needs to adjust the air bypass screws and close the throttell plates, check the carb plugs & gaskets &body for leeks.(air /vacuum leaks) check jet stack for crack,burr,defect.or get another carb. choke plate&thingys in there? idle jet holder? pluged orifices...boosters not sealing,( I add gaskets to mine much better running& responce) |
I was able to get a good even reading across all 4 on the snail gauge vaccum carb sync tool. I did some twisting of the shafts, etc. I had to back out one bypass screw out a little to get number #3 up, but thats on the good carb. #1 is still dead at idle...
I'm going to keep looking at it today and then send it to Mcdragracer the carb guy. I figure he can either fix what I can't or worse case tell me the carb body is no good for some reason. I did check all the exterior lead plugs for leaks. Checked body for cracks or any weird stuff like that. I've sprayed carb cleaner all over the actual carb body/ progression plugs while running
The jet stack appears good but I can take a second look very closely.
Atleast I've figured out what is wrong. Compression/leakdown is good, valves have never tightened up at all on me and move freely when cranking. Problem moves with carbs when I switch side to side. The other 3 carb throats/mixture screws act perfectly normal. #1 idle circuit is the problem. I'm not getting fuel (or barely any) at idle to the point where it's not even firing at all until I bring it to about 1500, that's when the backfiring starts and get worse till around 3000 rpms. _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9842 Location: Oregon
Posted: Fri May 21, 2021 11:42 am Post subject: Re: New engine build backfiring out both carbs and exhaust. HELP! |
Evan, when you say you pulled the jet stack. Did you mean the idle jet stack?
I get that this stack removal helped the engine idle better. So no need to rehash that.
If it was just the idle jet stack. Have you tried swapping the stack from #2 to #1 to see if this cleans up the idle issue?
another question. Have you completed the cam/lifter break in? It's generally recommended to get this step complete no matter how shitty the engine is running. Then get after the tune.
I'm gonna stuff my 2180 in my car this weekend, I imagine that come Monday/Tuesday, I'll be as soar as all hell! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Fri May 21, 2021 12:20 pm Post subject: Re: New engine build backfiring out both carbs and exhaust. HELP! |
67rustavenger wrote: |
I'm gonna stuff my 2180 in my car this weekend, I imagine that come Monday/Tuesday, I'll be as soar as all hell! |
Yes I'm almost positive I switched the jet stacks around at some point and that didn't change it but I can try that again as a last ditch effort.
I just verified the idle circuit is working as it should i was able to stick a wire everywhere even all the way through the tiny passage that runs from the middle of the main jet well to idle jet well. I pretty familiar with the idle circuit at this point.
And yes I did follow through with the break-in right from start even though it didn't sound great.
Hopefully I can get this engine in my car soon too! _________________ 1967 Bug ( the daily rod )
Posted: Fri May 21, 2021 12:41 pm Post subject: Re: New engine build backfiring out both carbs and exhaust. HELP! |
I found out I'm pretty close to Mcdragracer actually so I'm going to drive over there later today and hand them off to him. I would like to know for sure the carb is bad or find whatever is wrong before I buy a replacement. _________________ 1967 Bug ( the daily rod )
txoval Samba Member
Joined: January 23, 2004 Posts: 3571 Location: The Woodlands, TX
Posted: Fri May 21, 2021 12:56 pm Post subject: Re: New engine build backfiring out both carbs and exhaust. HELP! |
You can’t go wrong with mcdragracer
You open the dictionary to Good Customer Service and Open Communication and his picture shows up. |
Posted: Fri May 21, 2021 1:18 pm Post subject: Re: New engine build backfiring out both carbs and exhaust. HELP! |
txoval wrote: |
Very true. He's been extremely helpful over the phone and helped me figure out my jetting and what parts I needed to do the rebuild myself. I highly reccomend contacting him if you need any service or parts for your Dellorto, Weber, or even some other two barrel carbs.
Unfortunately even with his help I cannot intensify anything wrong. On the bench all the circuits seem to be working perfectly but it just won't run right.
He might need just to have them in his hands...
And I also need to know I'm not going crazy
Perhaps my swap meet find wasn't such a good deal after all... _________________ 1967 Bug ( the daily rod )
Posted: Fri May 21, 2021 2:32 pm Post subject: Re: New engine build backfiring out both carbs and exhaust. HELP! |
evanfrucht wrote: |
txoval wrote: |
Perhaps my swap meet find wasn't such a good deal after all... |
Well, Dell doesn't make new 45's anymore to my knowledge. So it's always a crap shoot when you buy a used set.
The guy I bought mine from doesn't have a good rep here. But, they worked, after cleaning them up and jetting correctly.
I think you lost your mind awhile back. Lol! _________________ I have learned over the years.
Buy Once, Cry Once!
txoval Samba Member
Posted: Fri May 21, 2021 2:50 pm Post subject: Re: DRLA 45 backfiring out carb and exhaust. Only 1 throat acts lean |
Not many others will text you at each step including the weekends.
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Fri May 21, 2021 2:59 pm Post subject: Re: DRLA 45 backfiring out carb and exhaust. Only 1 throat acts lean |
txoval wrote: |
My lord. And people try to tell me EFI is complex _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 10024 Location: Huntington Beach, CA
Posted: Fri May 21, 2021 3:25 pm Post subject: Re: DRLA 45 backfiring out carb and exhaust. Only 1 throat acts lean |
Chickensoup wrote: |
txoval wrote: |
My lord. And people try to tell me EFI is complex |
Have you ever taken a fuel injector apart! Not too terribly complex but TINY! _________________ Jimbo
TDCTDI wrote: |
Posted: Fri May 21, 2021 3:27 pm Post subject: Re: DRLA 45 backfiring out carb and exhaust. Only 1 throat acts lean |
VW_Jimbo wrote: |
Have you ever taken a fuel injector apart! not too terribly complex but TINY! |
No not yet. I will be when i rebuild the injectors on my TDI but hear all the LS guys talk about it.
Most people buy injectors already working or new as you already know _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
74 Thing Samba Member
Posted: Fri May 21, 2021 4:13 pm Post subject: Re: DRLA 45 backfiring out carb and exhaust. Only 1 throat acts lean |
Rick does good work so hopefully he finds the problem. A second set of eyes is sometimes a good thing.
I am pretty sure it is not an ignition problem since you swaped carbs side to side but what kind of distributor clamp are you using. The aluminum colored aftermarket ones can sometimes create a grounding issue.
In the future do not use 150 psi or air to blow threw the carb. That can create issues with all of the lead plugs. As you know the idle jet circuit is pretty simple in those carbs. From the top there are fixed idle air inlets (are they all the same and is the hole clear from the top into the idle jet holder thread area). Then there are the idle jets and holders (are the jets the same as well as the holders (check the holes) and the rubber o-rings). From the top view down it goes into the bowl but towards the top near the threaded area there is a hole where the gas goes down to the progression ports to the mixture screws. You can put a car cleaner tube in there and spray some fluid down there. You can remove the progression port plug (big phillips screw head on the side of the carb above the mixture screw) and see if the carb cleaner comes through. Then there is the mixture screws (check the o rings on these and the seating area. Finally there is the air bypass (how are the o rings on these and is it not leaking air.
When I clean a Dellorto carb idle jet circuit I will remove the jet from the holder and use carb cleaner and air to blow it out. I will also remove the progression port plug and put the carb cleaner straw in the downward port and spray and make sure carb cleaner is going through that. Then I will replace the progression port plug and remove the mixture screw and again spray carb cleaner down the circuit passage and make sure it flows down. I will also spray through the mixture screw passage into the carb barrel. Finally I will spray air upwards from the mixture screw through the open idle jet holder area. Then replace the mixture screw and idle jet holder.
Again, I am sure Rick will hook you up. |
Posted: Fri May 21, 2021 5:41 pm Post subject: Re: DRLA 45 backfiring out carb and exhaust. Only 1 throat acts lean |
This thread is becoming a how to diagnose Dell issues thread.
And it has some great content.
After reading the last two pages. I feel like I have a better understanding of the inner workings of Dell DRLA carbs. I've had mine for 3-4 years.
Thanks to Modok and Evan. Props to Ohio Tom and 74 thing too. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Fri May 21, 2021 7:29 pm Post subject: Re: DRLA 45 backfiring out carb and exhaust. Only 1 throat acts lean |
Well, Rick has my carbs now. He couldn't find anything on the bench majorly wrong with them and is going to test run them on an engine he has by mid next week.
So I guess we will see what's up
He was able to tell me I've been setting my float level like a dipshit
And he found one idle fuel delivery hole to be a hair smaller or with a tiny burr or something but it was insignificant enough neither of us are convinced that was the issue _________________ 1967 Bug ( the daily rod )
Posted: Fri May 21, 2021 7:57 pm Post subject: Re: DRLA 45 backfiring out carb and exhaust. Only 1 throat acts lean |
well until you get your carbs back just slap a stock intake and carb on there. maybe it will make you appreciate the power increase once you install the dells afterwards _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Fri May 21, 2021 9:09 pm Post subject: Re: DRLA 45 backfiring out carb and exhaust. Only 1 throat acts lean |
Here are the guys at Blackline (formerly Art Thraen's shop) showing how to set floats on IDF's-the process is similar to Dells.
https://www.youtube.com/watch?v=54uPwTZ3DJw
Also since your carbs and manifolds are off look down the ports to see if your valve guides have walked any. Brian E suggested earlier to pay attention to the seats as well so may as well check the intake guides visually for movement and a possible intake leak.
Posted: Fri May 21, 2021 9:32 pm Post subject: Re: DRLA 45 backfiring out carb and exhaust. Only 1 throat acts lean |
74 Thing wrote: |
Also since your carbs and manifolds are off look down the ports to see if your valve guides have walked any. Brian E suggested earlier to pay attention to the seats as well so may as well check the intake guides for movement and a possible intake leak. |
I did go buy a leakdown tester to test valves and they check out. Also it did swap sides with carb. But I will take another look down the manifold _________________ 1967 Bug ( the daily rod )
Posted: Tue May 25, 2021 8:31 pm Post subject: Re: DRLA 45 backfiring out carb and exhaust. Only 1 throat acts lean |
I talked to Rick today. He fixed my float height and reamed/cleaned up/evened out in size the idle circuit fuel delivery holes (the ones that the mixture screw go into) on one carb so far. He then ran them on his test engine. He said he immediately new it sounded lean and was popping like I said and that it was the worst on number one. He said it sounded like it wanted bigger idle jets. Like way bigger! I had 63's in their which he sold and initally recomended to me but after running it on his test engine he said it sounds good with three 76 idles and one sized 80 in the cylinder number one.
He also said that it seems like the throttle bearing on the #1 cylinder seems to be acting like it has a slight vaccum leak even tho that is apparently very rare. But he also said that he wouldn't worry about. It still kinda bugs me tho...
He sent me a video and they sound good on his test engine. I'm still kinda frustrated with this particular set of carbs tho. Why do they want huge idle jets? Won't my gas mileage be shit?
Anyway, in the mext couple days he is going to check the idle fuel delivery hole size on the other carb and try a few other things and fine adjustments so we will see how it goes. _________________ 1967 Bug ( the daily rod )
modok Samba Member
Joined: October 30, 2009 Posts: 26823 Location: Colorado Springs
Posted: Tue May 25, 2021 9:03 pm Post subject: Re: DRLA 45 backfiring out carb and exhaust. Only 1 throat acts lean |
Your killing me with all the suspense.
There must be a reason |
Posted: Tue May 25, 2021 9:08 pm Post subject: Re: DRLA 45 backfiring out carb and exhaust. Only 1 throat acts lean |
modok wrote: |
Not really. That's it I guess. They just want bigger idle jets then most normally do for some reason. Somehow one of my new throttle bearings might be slightly leaking but I know the shaft and hole in carb body were both a tight fit so maybe I messed up the seal in the bearing somehow when I installed it? Somehow I don't even think that's really part of the problem?
I don't know what to think anymore... fuck these carbs I want a different pair lol
I'm glad someone else has been caught in the suspense as well lol
We'll see how my final jetting ends up. Still not sure why three of the cylinders were dying and one was speeding up (w/ shot of cleaner) if all of them were running lean? Wouldn't they all speed up? I guess not _________________ 1967 Bug ( the daily rod )
