oil viscosity 73 Beetle
2381Buggy
2381Buggy is offline
PostPosted: Sat Jun 19, 2021 7:07 am    Post subject: oil viscosity 73 Beetle Reply with quote
What oil do you guys recommend using in a stock 73 rail buggy 1600 dual port? I 've been told to use straight 30w, but some say to use a much thicker oil like 20w50. Just light pasture and slow trail riding. I do have a remote filter.
sgmalt46
sgmalt46 is offline
PostPosted: Sat Jun 19, 2021 7:33 am    Post subject: Re: oil viscosity 73 Beetle Reply with quote
check the sticky in the performance/ engine/transmission section .
official "what oil/additives should I use" topic. 230 pages to sort through . Shocked hope you got nothing else to do today! Laughing I will start .30w is fine
that is what vw recommended .
Steve
55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG
gt1953
gt1953 is offline
PostPosted: Sat Jun 19, 2021 7:34 am    Post subject: Re: oil viscosity 73 Beetle Reply with quote
I use Rotella 10 ~ 30. Run what you want as long as it has zinc in it.
72 type 1
72 Squareback
AutoMechanic
AutoMechanic is offline
PostPosted: Sat Jun 19, 2021 7:53 am    Post subject: Re: oil viscosity 73 Beetle Reply with quote
For your location either of the ones you listed will be fine for summertime. I personally use Valvoline 20W-50 High Zinc Racing Oil. I’m also going to try the new Castrol formula they just released called Castrol Classics that has high zinc as well. Smile
sgmalt46
sgmalt46 is offline
PostPosted: Sat Jun 19, 2021 8:01 am    Post subject: Re: oil viscosity 73 Beetle Reply with quote
+ 3 on zinc ! it is missing in most motor oils. a must have for flat tappet engines in my opinion. I use valvoline mostly because it is easy to find most anywhere.
64 crew cab
55 rag top beetle
66 beetle
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Jun 19, 2021 9:07 am    Post subject: Re: oil viscosity 73 Beetle Reply with quote
Steve
This.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Beetle - Late Model/Super - 1968-up All times are Mountain Standard Time/Pacific Daylight Savings Time
