GratefulPhish Samba Member
Joined: July 20, 2020 Posts: 175 Location: Philadelphia
Posted: Tue May 11, 2021 9:13 pm Post subject: 73 SB no spark |
Back again...
I’ve been chasing this issue for a few months dealing with intermittent starting issues. Replaced the idle solenoid, accelerator pump, plugs and wires, removed the aftermarket digital ignition with a Bosch coil, adjusted the valves, etc.
it started two days ago reluctantly after finally jumping it with my other car. Tonight it started without jumping and drove fine but wouldn’t start after sitting for three hours. Tried and tried but it seems I’m not getting a spark. I think I’ve narrowed it down to the ignition switch? Not sure where else to go with this...I’m ready to put a for sale sign on it. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 10004 Location: Huntington Beach, CA
Posted: Tue May 11, 2021 11:47 pm Post subject: Re: 73 SB no spark |
You can bypass the ignition switch to test. Sounds like it may be going bad. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Igpoe Samba Member
Joined: February 24, 2019 Posts: 853 Location: South Boston, VA
Posted: Wed May 12, 2021 3:26 am Post subject: Re: 73 SB no spark |
Are your battery posts clear of corrosion? Ground strap on clean metal, etc? _________________ '73 super. |
Posted: Wed May 12, 2021 6:39 am Post subject: Re: 73 SB no spark |
Brand new battery, battery cables and ground, yes. Thanks! |
Posted: Wed May 12, 2021 11:40 am Post subject: Re: 73 SB no spark |
Started today within seconds of being jumped by my other car. Symptomatic of a failing ignition switch? |
Igpoe Samba Member
Posted: Wed May 12, 2021 11:47 am Post subject: Re: 73 SB no spark |
Old battery with weak cells. Check alternator output next time you jump it off _________________ '73 super. |
Posted: Wed May 12, 2021 2:43 pm Post subject: Re: 73 SB no spark |
Brand new battery |
Starbucket Samba Member
Posted: Wed May 12, 2021 2:47 pm Post subject: Re: 73 SB no spark |
Run a jumper wire from battery + to coil + and start it (remove jumper to stop it), this will tell you if it's the switch. |
Posted: Wed May 12, 2021 3:24 pm Post subject: Re: 73 SB no spark |
Do I need to disconnect anything from the coil to do this? |
Posted: Wed May 12, 2021 3:44 pm Post subject: Re: 73 SB no spark |
GratefulPhish wrote: |
Nope just use an alligator clip. When my switch went bad I put a toggle switch in the area below the front of rear seat and ran the wire with wire connectors and used that with my old switch until I changed the electrical part. |
Posted: Wed May 12, 2021 4:54 pm Post subject: Re: 73 SB no spark |
Thanks, I think Ashman may have made this suggestion or something similar in another thread. |
Posted: Wed May 12, 2021 7:06 pm Post subject: Re: 73 SB no spark |
Not sure about that but he is the electrical ghiru |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16002 Location: North Florida, USA
Posted: Wed May 12, 2021 10:11 pm Post subject: Re: 73 SB no spark |
From your descriptions I take it the ignition switch will get the engine cranking without any problem, but for some reason it appears there is no spark reaching the cylinders?
Start by testing the voltage at the ignition coil #15 (+) terminal. Test with the ignition switch in the ON/RUN position. Then test while the key is in the START position (might need a buddy for this test). Not uncommon for the ignition switch to work while in the ON/RUN position but not provide current WHILE in the START position. All your testing while standing behind the engine will not help since it is only an issue while the key is in the START position.
A similar issue is when the voltage is fine while in the ON/RUN position but the voltage drops while the starter is cranking the engine. If the voltage at the ignition coil drops below 10.0v the coil could stop firing. If you have an electronic ignition and the voltage drops below 11.0v the module may stop working.
Test and report back the voltage at the coil when the key is in both positions.
Also test the voltage at the battery terminals when it is at rest, while the ignition switch is ON and while the starter is cranking the engine. The starter is the #1 larger current drain on the battery. While it is cranking the engine most of the battery’s current is being pulled thru the battery cable to the starter motor. The voltage of almost every other device on the car will drop while the starter motor is cranking the engine. Report back the voltage reading at these three states. _________________ AshMan40
Cusser Samba Member
Joined: October 02, 2006 Posts: 31414 Location: Hot Arizona
Posted: Thu May 13, 2021 7:47 am Post subject: Re: 73 SB no spark |
I'm good at auto electrical, but I typically do not post often about that, I wait for Ashman to reply, as he is more patient with folks.
And - to be blunt - Ashman does a better job of this all than I do. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
stevebaz Samba Member
Joined: March 14, 2008 Posts: 189 Location: El Monte CA
Posted: Sat May 15, 2021 6:36 am Post subject: Re: 73 SB no spark |
Bypassed the ignition switch this morning as mentioned above and it started right up! Hoping the ignition switch was the problem all along.
Appreciate all the patience and support! |
Posted: Sat May 15, 2021 8:57 am Post subject: Re: 73 SB no spark |
It was!
These cars are famous for bad switches! I have replaced thousands of them! _________________ Jimbo
TDCTDI wrote: |
Posted: Sat May 15, 2021 10:08 am Post subject: Re: 73 SB no spark |
I’ve been hunting this ghost for 3 months |
