harrycrown Samba Member
Joined: September 02, 2020 Posts: 13 Location: scranton pa
Posted: Mon Jun 07, 2021 11:06 am Post subject: Front beam bushings. |
Quick question, that perhaps someone could shed some light on... I have a 71 Ghia. It came with a new EMPI 2" narrowed adjustable balljoint beam, that the previous owner never got around to installing. I'm to the point now, where I'm ready to put it in. The beam only has the needle bearings on the outer edge of the upper and lower tubes of the beam. Is there supposed to be additional bushing inside to support the back end of the torsion arms, once they slide into the beam? I'm getting conflicting info. Some say additional bushing are not needed if it has the needle bearings. Some others are telling me bushings are a must? Anyone out there with some experience on this? Thank you. |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3820 Location: Georgia
Posted: Mon Jun 07, 2021 2:34 pm Post subject: Re: Fron beam bushings. |
Yes. There should be another set of bearings further in.
I’ve seen many rebuilt beams come with one long bushing instead of the bearings.
I’ve never put anything EMPI on my Ghia except my current wheels so I don’t know how they do their beams. My stock ‘71 beam has inner and outer bearings. Maybe there is a bushing back there. Stuff a control arm in there see if there is any play. _________________ Volkswagen!
(Compression 8.7:1) |
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1137 Location: Melbourne Australia
Posted: Mon Jun 07, 2021 4:27 pm Post subject: Re: Fron beam bushings. |
if there is the needle roller on the outside, there definitely needs to have an inner bearing, it's Mica in a stock beam. I don't think the material matters as long as it is there.
this is the Wolfsberg West one that I have used: https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=131401311 |
simon varley Samba Member
Joined: March 12, 2020 Posts: 175 Location: Geelong Australia
Posted: Tue Jun 08, 2021 3:49 am Post subject: Re: Front beam bushings. |
I think the conflicting information is that the outer can be either bush or bearing, but in both cases an inner is required.
I confess i wimped out on mine. I bought the outer bearings but couldn't figure an easy way to remove the old ones or the inners. Since there was no movement I passed. Hope I don't regret it later |
Posted: Wed Jun 09, 2021 5:56 pm Post subject: Re: Front beam bushings. |
Thanks for the responses and the info. |
