Snerk Samba Member
Joined: July 01, 2018 Posts: 25 Location: Rohnert Park, CA
Posted: Fri Jun 18, 2021 11:45 pm Post subject: Replacing throttle cable & rebuilding pedal assembly on '79 FI |
Hey y'all.
Our '79 Fuel Injected car has a rough throttle and given the age and relatively inexpensive parts, I figured I may as well just replace the lot.
I have a new cable, a pedal rebuild kit, as well as a bowden tube for the engine bay.
However, all the guides I'm seeing are for carbed cars -- I'm sure the front portions of the cable are the same, but where the cable comes through the fan shroud and connects to the throttle body appear different on my car.
Are there any guides for performing this service on a late fuel injected car?
Thanks. |
Michael Ambrozik Samba Member
Joined: October 17, 2020 Posts: 656 Location: San Jose, CA
Posted: Sat Jun 19, 2021 8:03 am Post subject: Re: Replacing throttle cable & rebuilding pedal assembly on '79 FI |
Have you checked the service manual? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52770 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Jun 19, 2021 9:18 am Post subject: Re: Replacing throttle cable & rebuilding pedal assembly on '79 FI |
I'm fairly sure it's covered in the Bentley, if not it's not much different than a carb, adjust the cable for 1mm gap from the WOT stop on the throttle body when the pedal is mashed hard to the floor.
If it's still sticking closed afterwards you may have to find a better used throttle body, they get sticky when worn badly. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
