ATF leak at A/T - Diff bolts
jwallis
jwallis is offline
PostPosted: Sun Jul 25, 2021 6:52 pm    Post subject: ATF leak at A/T - Diff bolts Reply with quote
I thought I'd seen this discussed before but I searched and could not find it. I'm seeing ATF come from both the upper and lower bolts which mate the AT to the diff on the passenger side. I'd say it was weeping, but it's a little more than that I'd say. Torque converter appears dry, I think it's only coming from these bolts.
video:
https://youtu.be/_zNaxFDmlqY
picture:
50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more...
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sun Jul 25, 2021 7:03 pm    Post subject: Re: ATF leak at AT - Diff botls Reply with quote
there is an o- ring and a couple of paper gaskets around the intermediate plate.
basically, you have to split the whole deal
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
jwallis
jwallis is offline
PostPosted: Sun Jul 25, 2021 11:15 pm    Post subject: Re: ATF leak at A/T - Diff bolts Reply with quote
The huge o-ring prevents ATF from escaping between the... "flanges" I guess you'd call them, where the diff fits inside the transmission. But yeah it's starting to really look like that paper gasket is all that's there to prevent ATF from coming out of those holes. I pulled them apart once and really hated it.
I was considering trying to tighten down the bolts but the spec is only 22 ft*lbs. Seems really low, I don't know why it'd be so low.
I am now wondering if anyone else has successfully used RTV, rubber washers, or anything else to seal this thing without splitting the AT/diff. I know parts of the AT run at very high pressure, but not sure about this particular area.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Mon Jul 26, 2021 6:14 am    Post subject: Re: ATF leak at A/T - Diff bolts Reply with quote
because they are only M8 studs. can't really go much higher than that.
there is a bit of an art to installing O-Rings without damage and making sure they aren't rolled over while setting them in the groove. it's also very important to make sure all surfaces are clean, smooth and corrosion free.
you can try and snug them but don't go crazy. really can't speak to pooping any RTV in there (i wouldn't personally)
Jake Raby wrote:
Brian wrote:
kourt
kourt is offline
PostPosted: Mon Jul 26, 2021 8:31 am    Post subject: Re: ATF leak at A/T - Diff bolts Reply with quote
While you're playing with the transaxle, make sure the vents on top, and the weep hole underneath that joint, are open and breathing. They're probably fine, but clogged vents might exacerbate this weeping problem.
My first Vanagon auto transaxle had silicone all over this joint, applied by the previous owner. It seemed to help keep leaks down. Of course I cleaned it up and sealed it properly when I rebuilt it.
kourt
jwallis
jwallis is offline
PostPosted: Mon Jul 26, 2021 11:20 am    Post subject: Re: ATF leak at A/T - Diff bolts Reply with quote
Thanks kourt, I did already check that the vent hole covers are wobbly and the bottom one appears clear. Actually, what are these 2 bolts?
Hm, per Bentley 37.17, the one facing up is a pressure test port. What is the one facing the rear of the van? More importantly, is it something I'll ever care about?
jlrftype7
jlrftype7 is online now
PostPosted: Mon Jul 26, 2021 12:18 pm    Post subject: Re: ATF leak at A/T - Diff bolts Reply with quote
Don't worry about those bolts, instead, go forward of your picture and look at the sealing plate that's about 1 inch or so in diameter on the casting at the front. It's a plate that seals up a passage or hole in the trans, and since the plate sits below the surface of the case in that hole, you guessed it, water likes to collect there if it can. It's pretty much at the corner, front, drivers side, of the Trans. Use a mirror and flashlight to inspect yours, as that plate sits down a bit and is hard to see with the trans installed in the vehicle.
Mine developed a pin hole leak due to rust and I had to JB Weld it.
‘84 Tin Top - Hilga....Auto
jwallis
jwallis is offline
PostPosted: Mon Jul 26, 2021 12:56 pm    Post subject: Re: ATF leak at A/T - Diff bolts Reply with quote
Interesting, will clean it out and smear some CV grease or something like that on there.
Merian
Merian is offline
PostPosted: Tue Jul 27, 2021 2:44 pm    Post subject: Re: ATF leak at A/T - Diff bolts Reply with quote
how low is your ATF from the leak?
jwallis
jwallis is offline
PostPosted: Tue Jul 27, 2021 5:45 pm    Post subject: Re: ATF leak at A/T - Diff bolts Reply with quote
That's not a big problem, I just really hate leaking, messing up driveways as well as the environment
jlrftype7
PostPosted: Tue Jul 27, 2021 5:47 pm    Post subject: Re: ATF leak at A/T - Diff bolts Reply with quote
I have two transmissions, for that same spot on my 2nd unit,I added a heavy spray of body cavity wax. Grease would probably work pretty well too though…. Think
