azbob Samba Member
Joined: April 04, 2010 Posts: 714 Location: Phoenix, AZ
Posted: Thu Jul 15, 2021 3:05 pm Post subject: ISP 120 speedo + tach wiring |
So I'm helping a friend wire this thing up and the instructions are obviously a product of a generic google translator. I'm having some problems with the flasher logic. It has a bit of WTF to it that is making me scratch my head.
So the black wire goes to battery. Does that mean key positive or straight to the battery? That doesn't make sense. And then the other goes to the key positive or the flasher relay (49a)? The text to it is confusing too as you wouldn't ever connect both the striped green/white with black/white.
Any ideas?
Also the highbeam wiring seems to be simple but its not working soooo I'll figure that out next. _________________ Bus Builder |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5606 Location: 37.5N 77.1W
Posted: Fri Jul 16, 2021 6:41 am Post subject: Re: ISP 120 speedo + tach wiring |
I'm thinking wire #15 (key-switch on) for the flasher circuit. The diodes only allow a signal from one direction to light the LED, blocks the voltage from 'crossing over' to the other side. IMO the LED will not provide enough 'excitement' to get a charge out of the gen/alt. For the headlights. Connect the LED to hi-beams and the other wire to ground.
I use a LED for my hi-beam indicator also. Too bright, then used some inline resistors to dim it enough. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
GMendoza Samba Member
Joined: November 15, 2007 Posts: 341 Location: Alta Loma, CA
Posted: Sun Jul 18, 2021 7:19 pm Post subject: Re: ISP 120 speedo + tach wiring |
It's been a while since I wired mine ... and I've slept since then but from what I remember, I wired mine as follows:
Gen, oil pressure & blinker positive (colored wires) grouped together and connected to 12V at fuse box (same terminal as 12V for stock speedo)
Gen black to gen wire
Oil black to pressure switch
Blinker black to flasher relay
high beam blue to 12v high beam source on fuse box,
high beam black to ground (I used speedo securing bolt).
If you notice, you end up with 5 connections (same connections as stock) speedo plus the high beam ground and the bulb for gauge lighting.
Also, the high beam LED is much dimmer than the others.
Hope that helps _________________ '54 Bug, '59 Speedster replica, '65 Ghia (in pieces), '66 Notch, '80 930, '85 C10, '89 928, '96 LT4 'Vette, '03.5 Esprit, '05 Elise, '06 Murcielago |
Ronneisha Samba Member
Joined: October 22, 2022 Posts: 1 Location: Simi Valley
Posted: Sun Oct 23, 2022 6:08 am Post subject: Re: ISP 120 speedo + tach wiring |
azbob wrote: |
Any ideas?
Also the highbeam wiring seems to be simple but its not working soooo I'll figure that out next. |
Installing ISP Speedo. Can you explain in detail how you wired yours up. Did you use the in-line incandescent bulb came with. All the background lights are wired up and working. The rest is confusing |
wynsgti Samba Member
Posted: Sun Mar 24, 2024 10:04 am Post subject: Re: ISP 120 speedo + tach wiring |
I know this post is a few years old. I recently purchased ISP gauges for my bug. I have to say that this is the worst wiring diagram I ever seen. The person who drawn up and wrote this wiring diagram should have their crayons taken away.
I really do like the way these gauges look but as far as the wiring end of it is crap. |
