SyncroHead Samba Member
Joined: May 23, 2005 Posts: 1160 Location: Northern Nevada
Posted: Sat Aug 28, 2021 6:23 pm Post subject: Preventing Vanagon Towing Damage and Use of T-Hooks |
I've seen way too many Vanagons with torn sheet metal underneath caused by careless tow-truck operators slinging their hook into the first hole they see! You've probably seen this too.
This is typically one of the elongated holes on the bottom side of the front diagonal braces. This metal is very thin and what happens is with just a little resistance (parking brake on, pulling up a ramp, etc.) the hook tears through this thin metal like butter. Read on for more detail and how to avoid this damage to your van.
Here's a photo of modest damage:
Here's how it might have looked with the perpetrator's hook in the slot.
Here's more severe damage, all the way through to the next slot!
Hook staged in slot:
So, there's clearly a WRONG way to do this. But there's more than one bad way. On the front-right underside of our vans is a small tie-down loop that helped secure the van during export shipping. Hooking here is better than in the elongated slot pictured above, but still not a great spot. I've also seen these loops bent out of proportion or torn all the way through. Often the tow-truck's hook might be too big to go in this loop, so the next nearest spot is the worst place, the elongated slot in the very thin metal.
Here's an example from the Owner's Manual showing an old-fashioned tow hook up with chains strewn back and forth. The important thing to note is the instruction to insert a T-Hook.
Hopefully our tows will be on a flatbed truck, or at least with better equipment than the wooden 4x4 shown in the manual. However, what's still important is where and how to attach with the T-Hooks. Even if it's just hooked up to winch the van onto a flatbed, it's still important to hoof the winch to a spot that's not going to inflict damage to our vans.
Below are photos showing that spot in the Owner's Manual sketch for the T-Hook. The metal forming the "frame" in this location appears to me to be about 3-4X thicker than the thin metal on the bottom of the diagonal brace. Additionally, it's doubled-up, making this spot probably about 6-8X stronger.
Here are a few photos of a T-Hook and a similar J-Hook.
Photos of T-Hook inserted
Photos of J-Hook inserted
The T-Hook is specifically mentioned in the Owner's Manual and that's the best device. If you (or the operator) have a J-Hook is that ok? I'd say probably yes, but with a warning. The T-Hook I have can barely be inserted in the hole in the frame and likewise can barely be removed. Almost like a puzzle, where you have to twist it "just-so" to get it in or out. The T-hook is never going to just fall out of that slot. The J-Hook on the other hand slips in and out easily. If the winch were to become slack, any backward force on the cable could cause the J-Hook to come out, so more care and attention would be needed to make certain this doesn't happen.
Here's the bottom line:
1. Make sure no one puts a hook in the thin sheet metal on the bottom of the diagonal braces. No good can come from that.
2. The tie-down loop under the front/right might be adequate for light-duty uses.
3. It's best to use a T-hook and insert it where the Owner's Manual shows.
I've recently purchased a pair of T-Hooks and a J-Hook and will keep these in my Westy. I can use it as an example to show the truck operator what's needed. The truck should be equipped with several different types and sizes. If they don't have one that fits, at least I'll have a couple on hand they can use.
These are available from online retailers and the size I got is called "5/16". If you buy your own, try them out to make sure they fit before tossing them in with your jack and lug wrench.
I think I might paint the bottom sides of my diagonal braces red or yellow and maybe add a "NO HOOKS" stencil. Also, probaly paint the side of the frame around the T-Hook slot green and add a "T-HOOK" stencil.
Jim Davis _________________ "A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
| sphet wrote: |
| I have *no* idea what the previous owner carried in his Westy... angry donkeys? |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80687 Location: Sneaking up behind you
Posted: Sat Aug 28, 2021 6:39 pm Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
You're referring to 40 year old towing technology.
Wheel lift tows only touch the wheels and nylon straps hold the wheels to the lift.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Sat Aug 28, 2021 7:07 pm Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
| Glenn wrote: |
This isn’t used when pulling a Vanagon up onto a flatbed. _________________ "A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.Vanagons.org
| sphet wrote: |
Glenn  Mr. 010
Posted: Sat Aug 28, 2021 7:13 pm Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
| SyncroHead wrote: |
| Glenn wrote: |
This isn’t used when pulling a Vanagon up onto a flatbed. |
I know a flatbed driver, he uses nylon straps wrapped around suspension pickups.. .so no damage.
Metal on metal will leave marks if not damage.
Trust me, with all the expensive cars out there, tow truck drivers don't need to pay damage claims.
Member #1009
#BlueSquare
DanHoug Samba Member
Joined: December 05, 2016 Posts: 6025 Location: Bemidji, MN
Posted: Sat Aug 28, 2021 7:55 pm Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
for the small cost, i've considered getting a set of hooks just to avoid this problem when getting a tow out of BFE by 3 Swedes Towing. or more likely, just me winching it up onto a U-haul. _________________ -dan
www.thefixitworkshop.com |
hans j Samba Member
Joined: May 06, 2006 Posts: 2746 Location: Salt Lake City UT
Posted: Sat Aug 28, 2021 8:53 pm Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
| Glenn wrote: |
We get vans dropped off all the time at the shop, those flatbed drivers don't care. They hook wherever convenient. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
jimf909 Samba Member
Posted: Sat Aug 28, 2021 10:10 pm Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
| hans j wrote: |
| Glenn wrote: |
We get vans dropped off all the time at the shop, those flatbed drivers don't care. They hook wherever convenient. |
| Glenn wrote: |
Hmm, tell that to the tow company that paid a $600 damage claim to me after attempting to drag my low mile, spotless '65 up a ramp by hooking into a hole in the floor pan.
Your single data point doesn't negate the fact that there are countless other flatbed operators who don't give a flying fist f*%k about damaging a 30 year old van by dragging it up the bed after putting a hook in any hole that will accept it.
I carry T-hooks and clearly marked where they go on my van. More examples here...
https://www.thesamba.com/vw/forum/viewtopic.php?p=9010590
Syncrohead, great post and a good reminder. _________________ - Jim
| Butcher wrote: |
| This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
Posted: Sat Aug 28, 2021 10:30 pm Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
| DanHoug wrote: |
| for the small cost, i've considered getting a set of hooks just to avoid this problem when getting a tow out of BFE by 3 Swedes Towing. or more likely, just me winching it up onto a U-haul. |
I've gone so far as thinking about how to zip tie the t-hooks in place to ensure they're visible.
More here. See the win-win by Gnarlodious
https://www.thesamba.com/vw/forum/viewtopic.php?p=9010590 _________________ - Jim
| Butcher wrote: |
Guilty as charged.
Posted: Sun Aug 29, 2021 6:34 am Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
what about pulling backward from the rear? are there T hook holes? those axles are just Sirens beckoning to the tow truck driver with J hooks, luring them onto the rocks. _________________ -dan
Glenn  Mr. 010
Posted: Sun Aug 29, 2021 6:36 am Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
You guys need to better maintain your vehicles.
My car has almost 500,000 miles and has been towed 4 times. Once when I left the engine and once when it came home.after being repainted. _________________ Glenn
Member #1009
#BlueSquare
Posted: Sun Aug 29, 2021 7:19 am Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
| Glenn wrote: |
| You guys need to better maintain your vehicles. |
this isn't for OUR vans... it's for going out and buying OTHER people's sorry broke-down vans and towing them home!! or something. _________________ -dan
Abscate Samba Member
Joined: October 05, 2014 Posts: 24525 Location: NYC/Upstate/ROW
Posted: Sun Aug 29, 2021 7:24 am Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
Gauntlet , hook, and chain thrown ….
 _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
Glenn  Mr. 010
Posted: Sun Aug 29, 2021 8:07 am Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
Maybe someone can develop a bolt on product that give you 4 specific loops so tow hooks can be attached without damaging the frame. And if they get damaged, you just replace them.
Paint then red so they are obvious.
Maybe something like this????
Member #1009
#BlueSquare
Posted: Sun Aug 29, 2021 8:59 am Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
| Glenn wrote: |
You need to think better. The car in my example was 100% driveable but was being hauled cross-country. _________________ - Jim
| Butcher wrote: |
Guilty as charged.
Glenn  Mr. 010
Posted: Sun Aug 29, 2021 9:46 am Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
| jimf909 wrote: |
| Glenn wrote: |
You need to think better. The car in my example was 100% driveable but was being hauled cross-country. |
Sorry, i thought the joy of ownership is actually driving it to where you're going.
When my 2016 Subaru needed to be towed they simply drove it on the flatbed and then strapped it down without adding scratch. Was yours not able to move under its own power?
Again, adding bolt on tow tabs eliminates the chance of frame damage. Race cars add them all the time since they are not driven to where they are used.
Here's a smart owner from the other topic.
| Gnarlodious wrote: |
Uhhh… yeah. Mine were yanked on also, by a PO, and were bent down. I guess they somehow put a hook in there. I had them straightened and my welding guy put these bad boys on all 4 corners along with a fish plate:
Also further forward on the bottom of the frame there seems to be another T-hook hole. Punchy punchy! |
Member #1009
#BlueSquare
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15416 Location: Syracuse, NY
Posted: Sun Aug 29, 2021 10:38 am Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
buncha pedantic posturing here..
shit happens and shyt breaks or fails no matter how well YOU maintain your vehicle
had the coil go out on my 80 yr old mom's van this weekend.. had to tow it into camp.. cause like it's not good to have her on the side of the road till the autoparts deliver.
thing is. this was the NEW coil that replaced the bad (arcing) coil last week.
new part lasted 50miles..
at camp and proper no spark diagnosis.. we put the old arcing coil on and hit it with wiredry spray to get her home the 70miles.
as for towing.. we do our own arrangement.. carry the rescue towbar and bolts.. we try to stay away from gorilla Jim and his wrecking chains. _________________
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
kamzcab86 Samba Moderator
Posted: Sun Aug 29, 2021 10:42 am Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
| DanHoug wrote: |
| those axles are just Sirens beckoning to the tow truck driver with J hooks |
If a tow truck driver puts J-hooks on the axles of any vehicle (that's not wrecked and destined for the junkyard), the driver should be fired. Tow operators are supposed to pull using the control arms, not the axles.
Good tow companies will have endless loop straps/slings and should be using those when possible.
When my van was flatbedded for the first time a few years ago, I ensured the guy didn't hook to the improper sheet metal locations before he began pulling (I was glad to see that he used the aforementioned slings, not directly-connected hooks).
| Glenn wrote: |
Oh, [bleep] off! How much more egotistically arrogant can you possibly get?
Breakdowns happen even in the best maintained vehicles. J...T...C...
(Edit: Photo update.) _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
Posted: Sun Aug 29, 2021 10:50 am Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
Kamz-- where did the tow attach the slings to? _________________ -dan
Glenn  Mr. 010
Posted: Sun Aug 29, 2021 10:57 am Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
| kamzcab86 wrote: |
| Glenn wrote: |
Breakdowns happen even in the best maintained vehicles. J...T...C...🤦🏻♀️ |
Oh trust me... i'm still in 1st gear.
I truly doubt any current tow truck drivers have read the Vanagon owners manual and know where the factory wanted you to hook it up.
But seriously, that red steel tab on the bottom shock bolt of the Porsche looks like an easy solution that anyone with and adjustable wrench can do in their driveway. Then you just need to tell the tow truck driver that they are there and to use them.
Or is there something i'm missing and you have to use the factory slots with T hooks?
Unless you're broke in the middle of the highway, most drivers don't want to damage your vehicle and deal with insurance claims. If you give them an accessible and clearly marked point they only need nylon straps to drag it onto a flatbed. _________________ Glenn
Member #1009
#BlueSquare
9.5isCanadian Samba Member
Joined: September 16, 2017 Posts: 465 Location: In your blind spot.
Posted: Sun Aug 29, 2021 11:55 am Post subject: Re: Preventing Vanagon Towing Damage and Use of T-Hooks |
| DanHoug wrote: |
| Glenn wrote: |
this isn't for OUR vans... it's for going out and buying OTHER people's sorry broke-down vans and towing them home!! or something. |
You mean like this?
_________________ 9 1/2 - missing a few pieces.
1987 Getaway Hightop
1980 Sunroof Vanagon
2018 BMW R Nine T
2012 Golf tdi |
