thefladge Samba Member
Joined: July 25, 2005 Posts: 1290 Location: Anaheim, CA
Posted: Thu Oct 14, 2021 4:18 pm Post subject: Spring Compressor for Push Rod Tubes. Is There Such a Thing? |
Is there such a tool as a spring compressor for push rod tubes?
It would certainly make removing and installing them easier.
I have a set of Bugpack or Empi tubes on my spare engine.
_________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate. |
74 Thing Samba Member
Posted: Thu Oct 14, 2021 4:35 pm Post subject: Re: Spring Compressor for Push Rod Tubes. Is There Such a Thing? |
long zip ite |
Posted: Thu Oct 14, 2021 5:53 pm Post subject: Re: Spring Compressor for Push Rod Tubes. Is There Such a Thing? |
Maybe something like this, but for a aftermarket VW push rod tube.
https://www.aircraft-tool.com/shop/detail.aspx?id=CST173&AspxAutoDetectCookieSupport=1 _________________ 1957 Vintage Baja Bug.
dogmeat Samba Member
Posted: Thu Oct 14, 2021 10:44 pm Post subject: Re: Spring Compressor for Push Rod Tubes. Is There Such a Thing? |
ha ha... yeah, what he said^^^
we've had them in aviation forever. a clever guy could make something like that. I've given it some thought...
anyway, before I bough the real (aircraft) tool I used to use safety wire. put the spring in a vice & compress it, tie it closed with a couple pieces of .032 wire. install it and clip the wire |
nsracing Samba Member
Posted: Fri Oct 15, 2021 7:47 am Post subject: Re: Spring Compressor for Push Rod Tubes. Is There Such a Thing? |
What you need is something to hold the tube so you can move it down by hand. Not a spring compressor. The spring is so short not much to squeeze.
a vise-grip tool modified to clamp the tube w/o squashing it will be a nice tool. Push down on the tube and install the tube. |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5605 Location: 37.5N 77.1W
Posted: Fri Oct 15, 2021 7:59 am Post subject: Re: Spring Compressor for Push Rod Tubes. Is There Such a Thing? |
I wrapped some tape around the curved jaws of a pair of vice grips. Adjusted the pliers to where they just wouldn't slip and pushed down hard and tilted the tube out of the way. I was able to removed some CB anodized tubes without scratching them or removing the head to fix my boo-boo
I forgot to put in the heat deflector between the jugs on one side and took out two tubes and reinstalled them the same way
missing tin...
_________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7229 Location: Videbaek Denmark
