Skim Rants Master
Joined: April 15, 2001 Posts: 17036 Location: GFK 30 Year Vet
Posted: Thu Jul 01, 2004 5:15 pm Post subject: |
Mr. Electric Wizard wrote: |
Well here's my pics of the "Graffiti Remover" on my bus...
I had a really bad layer of primer below that belt line that I couldn't stand. I about busted a nut when I found what lies beneath...
The stuff definately works!!! Thanks for the suggestion!!! |
I guess I better go to Home Depot and get some cryptonite. _________________ GFK
1953 Kabriolet
1954 Sunroof
1961 Deluxe SWR / BG 15 Window
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
Mr. Electric Wizard Samba Member
Joined: August 07, 2003 Posts: 2846 Location: Smyrna, TN
Posted: Thu Jul 01, 2004 7:49 pm Post subject: |
It works good Skim, just don't leave it on too long or it will eat through all the paint... _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
(T)exas (C)oalition (B)uses
(H)eidenhammer (B)ully (B)oyz
--1966 De Luxe Camper |
Skim Rants Master
Posted: Thu Jul 01, 2004 8:54 pm Post subject: |
is it the can that shows a lot of graffiti on the label? some are stronger than others. _________________ GFK
1953 Kabriolet
1954 Sunroof
Jawohl Got Ice?
Joined: January 05, 2004 Posts: 199 Location: Pit of Despair
type877 Samba Haiku Masta
Posted: Thu Jul 01, 2004 11:34 pm Post subject: |
Jawohl wrote: |
Graffiti Remover by klean strip
Dats the shiznit right there, uh huh! _________________ Ken
JHC |
Posted: Fri Jul 02, 2004 6:09 am Post subject: |
Yup, thats what I used... _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
Skim Rants Master
Posted: Fri Jul 02, 2004 2:39 pm Post subject: |
Thats what Im gonna get after work. Electric, you gotta keep us posted on your progress. _________________ GFK
1953 Kabriolet
1954 Sunroof
NAES Samba Member
Joined: September 10, 2003 Posts: 2069 Location: AREA-52 Southern Killafornia
Posted: Fri Jul 02, 2004 11:19 pm Post subject: |
All of you guys freakin rock. I'm glad more bus owners are trying to salvage the big F ups of the past and getting their buses looking good. _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
krusher Samba Member
Joined: September 24, 2002 Posts: 7650 Location: europe
Posted: Sat Jul 03, 2004 1:53 am Post subject: |
My Barndoor kombi was used at a fire station in holand, it came from the factory dove blue, and was re-paintet straight away fire truck red, over the last 50 years rain i guess has stripped most of the red off, I will be stripping the rest of once I get it on the road.
If any of you guys are trying to do touch ups see if you can buy celulose paint like the OG, you will never get a good touch up with modern 2 pack paint its to plastic and shiny.
My 54 next to my old 55.  _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
obus  Samba Member
Joined: March 08, 2001 Posts: 10619 Location: just off Garden State Parkway Exit 81
Posted: Sun Jul 04, 2004 6:31 am Post subject: |
SuperSkim wrote: |
Thats what Im gonna get after work. Electric, you gotta keep us posted on your progress. |
will do...  _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
BUCIOBATISTI Samba Member
Joined: April 17, 2002 Posts: 6948 Location: Carmel, California, USA
Posted: Sun Jul 04, 2004 8:49 am Post subject: |
obus wrote: |
OMG, i bought all the crap yesterday and tried it. i got graffiti remover, sprayed it on a small spot on the rear corner and where it gets round it went down to bare metal in a spot the size of a dime in like milli-seconds! but it worked in other areas a bit but damn!!! you guys are f-ing hardcore for doing the whole damn bus!!! just that little spot was tough. here are the other items i bought: 3 types of "fine" wet/dry sandpaper, sanding block, a plastic scraper, a putty knife(i already had one), 4 cans of graffiti remover. what do i use to neutralize it? water or baking soda? also should i use a razor blade and doesn't that take even longer? oh yeah, i tried abit above the beltline and the white is there too!  |
It's certainly not a spray on/wipe off process. It took me over 100 hours to do my '53. It has tons of fucked up spots too but it's just a matter of what you enjoy. Start slowly and pick up a little speed if you find a good system. Remember to always be careful too! I don't know what neutralizes the Graffiti Remover but water neutralizes the Jasco paint stripper that I used. It worked well but took several passes, loads of time, and even more patience. _________________ Please check us out on Instagram at @holygrailgarage
That's the best place to see the latest things we are up to as well as catch an occasional sneak peek of our latest car and parts listings! |
Skim Rants Master
Posted: Sun Jul 04, 2004 10:44 am Post subject: |
krusher wrote: |
My 54 next to my old 55.  |
Man That red looks like it would wash right off with a little warm water!  _________________ GFK
1953 Kabriolet
1954 Sunroof
Posted: Sun Jul 04, 2004 10:58 am Post subject: |
obus wrote: |
what do i use to neutralize it? water or baking soda? also should i use a razor blade and doesn't that take even longer? |
obus, I see no reason to use a razor blade. From my experience, as long as the graffiti remover is completely wiped off, that neutralizes it. Don't use a towel for too long, otherwise you will be reapplying the graffiti remover as you're trying to wipe it off. Spray the remover in a small area directly onto the paint that you want to remove. Wait a couple of seconds and then get rubbing. Expect to go through a lot of towels. The terry towels work really good, I think their texture helps with the rubbing. <insert joke here>  _________________ Ken
JHC |
obus  Samba Member
Posted: Sun Jul 04, 2004 12:40 pm Post subject: |
thanks for the tips guys! i am going to do a little bit each night after i get home from work. i think water neutralizes it and i used a water soaked cheesecloth after i did a bit of scraping w/ the putty knife. i did a spot slightly bigger than my hand w/ the graffiti remover. this will be a true test of my patience which normally = NONE on mine it seems like it was almost a spray on/wipe off process because on the corners i put a little bit and walked away and that was the small spot that it burned through to metal!!! i waited the next time about 2 minutes after spraying the next time and once i started to scrape it started to come off. later i was able to get it to come off by using my fingernail!!! now do i need to wet sand it at all or is that when i get the sucka down to the green? _________________ early July 1959 Mango Standard Bus aka Obus L346 L347 https://www.thesamba.com/vw/forum/viewtopic.php?t=256592&highlight=
Late 66 21 window bus https://www.thesamba.com/vw/forum/viewtopic.php?t=777273 |
Jawohl Got Ice?
Posted: Sun Jul 04, 2004 12:51 pm Post subject: |
I would say the wet sand question depends on how your bus was prepped prior to the billy's getting their hands on it. If paint was just shot over OG paint, then my guess would be that you wouldn't need to wet sand, but if your bus were scuffed prior to the "new" paint, you might need to. Graffiti remover doesn't seem to bother the finish of the OG paint if done correctly, with patience and love. _________________ I have no problem with God.
It's his fan club I can't stand!
Reverend Peytons Big Damn Band.
http://www.bigdamnband.com
http://www.youtube.com/watch?v=9Ra0DsbiNs0
1957 Logo panel "We Sell ICE"
1966 Vert
1967 Westy
1963 Ragtop
1964 Single Cab |
Friedpotatoes Addicted4life
Joined: April 04, 2003 Posts: 1215 Location: Fresno California
Posted: Sun Jul 04, 2004 12:59 pm Post subject: |
i wanted to take my 65 down and i was doing that but there were o many hole burns (from someone sanding) and many spots that were stained cause the other paint
but that bus is gone
I would do my 67 knowing the origional is under the blue.......but i can tell there is body damage and bondo behind the cargo door.... it was strightened good but still had to use bondo ill have to fix that some day but not now cause that blue shines real well! _________________ 56- Wolfsburg Single Cab
57- Oval Window Bug (Agave Green) |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9653 Location: Exit 7, New Jersey
Posted: Sun Jul 04, 2004 1:55 pm Post subject: |
The solvent based graffitti removers cannot be "neutralized", they can only be wiped off or diluted. I would suggest a towel soaked in mineral spirits to dilute out the solvent from the remover. You are basically diluting a concentrated paint dissolving solvent with a much less aggressive solvent, thereby stopping the stripping action. Again, you will need to try it and find a combination which works for your paint. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all!  |
obus  Samba Member
Posted: Mon Jul 05, 2004 7:45 am Post subject: |
We just used the water hose to take off the graffiti remover after wiping down and then letting it sit about a minute... _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
