kingkarmann Samba Member
Posted: Sun Nov 14, 2021 1:17 pm Post subject: Solex Pict3 Carb. Is it compatible with a 1500? |
I tried several ways of searching and found no specific answers.
I recently acquired a 67 Ghia with the original motor. AS I understand the "H" code engines received the PICT1 carburetor. At some point they replaced the carb with a PICT3.
Generally the carb looks to be in good shape and the car does run well overall but I'm getting some flat spotting on acceleration. I did a rebuild and suspect there is still some fine tuning to do. I also read that I may need to take a closer look at the accelerator pump adjustment.
Anyhow, I don't want to end up chasing my tail if the the PICT3 in not a great choice.
Thanks _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9828 Location: Oregon
Posted: Sun Nov 14, 2021 1:56 pm Post subject: Re: Solex Pict3 Carb. Is it compatible with a 1500? |
Is the carb a 34 pict 3? Paired with an 009 distributor?
That is a known bad combination.
You'd be better off with a 30 Pict 1 and a 205K distributor. That's a great pairing for the SP 67 engine. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sun Nov 14, 2021 2:14 pm Post subject: Re: Solex Pict3 Carb. Is it compatible with a 1500? |
67rustavenger wrote: |
You'd be better off with a 30 Pict 1 and a 205K distributor. That's a great pairing for the SP 67 engine. |
Original distributor
Mike Gerson
SevenOaks Samba Member
Joined: April 24, 2012 Posts: 264 Location: Friendswood, TX
Posted: Sun Nov 14, 2021 2:34 pm Post subject: Re: Solex Pict3 Carb. Is it compatible with a 1500? |
My SC has an H case engine, now 1600, and I added a 30 pict 3 carb rebuilt by Volksbitz. It runs great with the Bosch 205T sva distributor. The only thing I had to do was add a spacer between the carb and intake in order for the idle shutoff to clear the generator. _________________ David
1974 9-passenger bus
1969 Single cab
1966 Beetle |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6652 Location: Houston, Texas
Posted: Sun Nov 14, 2021 2:52 pm Post subject: Re: Solex Pict3 Carb. Is it compatible with a 1500? |
I assume this is a 30 PICT3.
How many degrees do you have your engine timed?
Are you able to get the engine to idle? _________________ www.vwnos.com [email protected]
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7241 Location: Videbaek Denmark
Posted: Sun Nov 14, 2021 3:16 pm Post subject: Re: Solex Pict3 Carb. Is it compatible with a 1500? |
No matter if it is the 30 or 31 Pict3, you need to replace either the carb to one that corresponds with the distributor, - or the distributor to one that corresponds with the carb.
Since it is a ´67 I lean towards replacing the carb with the right model. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
FarmerBill Samba Member
Joined: July 25, 2017 Posts: 769 Location: New England
Posted: Sun Nov 14, 2021 3:49 pm Post subject: Re: Solex Pict3 Carb. Is it compatible with a 1500? |
Starting in August 1966 (start of1967 model year) the 1500 Ghia would have had a 30 pict 1 with a base stamping number of vw107-1 or vw106-1, paired with a 113.905.205K distributor. I don't know if this carb/distributor combination was continued through all of 67 or not.
https://www.thesamba.com/vw/gallery/pix/550893.jpg |
Alstrup wrote: |
Since it is a ´67 I lean towards replacing the carb with the right model. |
Thanks
You’re confirming what I suspecting.
I haven’t worked on stock motors for a very long time.
Any suggestions for vendors an original stock PICT1?
Looks like I’ll have a nice PICT3 for sale in the future _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
Joined: April 27, 2002 Posts: 6375 Location: Pentwater, Michigan
Posted: Sun Nov 14, 2021 4:47 pm Post subject: Re: Solex Pict3 Carb. Is it compatible with a 1500? |
You could also run a 113 M distributor. It would have the appearance of the correct 1967 distributor with the short cap. The 113 T uses a taller cap and rotor like those on a 009. They are both vacuum advance distributors that use the same vacuum advance canister. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Sun Nov 14, 2021 4:52 pm Post subject: Re: Solex Pict3 Carb. Is it compatible with a 1500? |
heimlich wrote: |
Are you able to get the engine to idle? |
7.5 BTDC
Yes, idles well. _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
Posted: Sun Nov 14, 2021 4:54 pm Post subject: Re: Solex Pict3 Carb. Is it compatible with a 1500? |
FarmerBill wrote: |
Thanks for that.
I will double check the distributor stamping. I believe it’s original to the engine. _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
oprn Samba Member
Joined: November 13, 2016 Posts: 12815 Location: Western Canada
Posted: Sun Nov 14, 2021 6:52 pm Post subject: Re: Solex Pict3 Carb. Is it compatible with a 1500? |
Don’t overlook the heat riser condition. Lack of intake heat can do this too. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Mon Nov 15, 2021 1:11 am Post subject: Re: Solex Pict3 Carb. Is it compatible with a 1500? |
FarmerBill wrote: |
The 113 K distributor was continued all the way through 1967 model year production. _________________ Roads Scholar &
Posted: Mon Nov 15, 2021 7:12 am Post subject: Re: Solex Pict3 Carb. Is it compatible with a 1500? |
tasb wrote: |
FarmerBill wrote: |
The 113 K distributor was continued all the way through 1967 model year production. |
Thnaks for that! _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
Posted: Tue Nov 16, 2021 9:54 am Post subject: Re: Solex Pict3 Carb. Is it compatible with a 1500? |
Update,
I have found a nice core that will be sent off to Tim at Volksbitz for a rebuild/restore.
I guess I will have a nice Solex PICT3 up for sale at some point.
Thanks all for your help! _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
Posted: Thu Nov 18, 2021 9:15 am Post subject: Re: Solex Pict3 Carb. Is it compatible with a 1500? |
FarmerBill wrote: |
I confirmed that 113.905.205K is the distributor in my Ghia.
The PICT 1 I have is stamped "VW 75-1". It also has another stamp "B 6 140"
Would that be for a different model perhaps?
Mike Gerson
Posted: Thu Nov 18, 2021 6:08 pm Post subject: Re: Solex Pict3 Carb. Is it compatible with a 1500? |
VW 75-1 is for a 1300 beetle. You're looking for a 30 pict1 with what they called the "power fuel system". If you look down the throat of the carb with the float bowl closest to you you'll see a small brass tube just below and to the side of the float bowl vent tube, that's the power fuel tube. The VW 75-1 doesn't have this tube. I believe all 1500 engines had some version of the carb with the power fuel system while the 1300 engines did not. |
Posted: Thu Nov 18, 2021 6:24 pm Post subject: Re: Solex Pict3 Carb. Is it compatible with a 1500? |
FarmerBill wrote: |
Thank you for the info.
Looks like I have the wrong one or can mine be modified. _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
Posted: Thu Nov 18, 2021 6:41 pm Post subject: Re: Solex Pict3 Carb. Is it compatible with a 1500? |
kingkarmann wrote: |
FarmerBill wrote: |
Thanks |
Those other numbers are most likely manufacturing plant number shift and date of manufacture. _________________ Roads Scholar &
Posted: Thu Nov 18, 2021 6:47 pm Post subject: Re: Solex Pict3 Carb. Is it compatible with a 1500? |
tasb wrote: |
FarmerBill wrote: |
Thanks |
Those other numbers are most likely manufacturing plant number shift and date of manufacture. |
Thanks for that!
Sure wish I had known that there were variations of the PICT1😔
I’m on a fixed income! _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
